Why won't my Hp Stream 7 turn on?
I can't turn my tablet on and it's starting to frustrate me >:( any ideas on how to fix this problem?
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Hey Brennan!
Sorry to hear about your struggle, but I think I have some ideas that could help!
- Try charging your device. It's most likely dead and a little charge could do the trick
- Try changing the screen. While opening the device, look for any connections that need to be reconnected or clean.
- Water damage is a possibility. If you have soaked your device recently, you may have some luck dissembling it, and soaking the parts in rice or salt; neither will guarantee your device will work when put back together, but success stories have brought devices back from the dead.
Best of luck!
Esta resposta foi útil?
Hey Brennan!
- Try Changing the screen. While opening the device, look for any connections that need to be reconnected or clean.
Best of luck!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 585
