Ir para o conteúdo principal
A 4-cycle straight shaft string trimmer manufactured by Troy-Bilt. This model is identified by TB675 EC.
starter cord won't retract back
my recoil cord won't retract
Esta é uma boa pergunta?
Pontuação 2
1 comentário
the pawls are broken. THewy are easy to replace. go to youtube and search "How to replace or repair my tb675ec pawls" https://www.youtube.com/watch?v=V7KduhbV...
bery detailed instruction I did it myself
por
Adicionar um comentário
2 respostas
Pergunta mais útil
@Mike, txhunter2 , it sounds like you both may have a broken recoil. The spring has broken on txhunter2 recoil and on Mike's the flywheel engagement tang's have broken. At the link below I believe the whole recoil assy./housing can be replaced for just over $13.00. Good luck. See below links that may help repair/replace the required part. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.troybilt.com/equipment/ARIPar...
https://www.youtube.com/watch?v=2eSWBmhl...
Esta resposta foi útil?
Pontuação 2
Starter cord won't retract
Pontuação 0
Adicionar a sua resposta
txhunter2 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 7,789
