Ir para o conteúdo principal
Released in 2013, this multifunction laptop is a part of the Satellite C50 laptop series. It has a 15.6" display screen and comes with Windows 8.
11 Perguntas Visualizar todos
Why won't my laptop's screen go on
It was one day when my laptop's battery was low at around 10% until I used it until 7% then I closed it.When I put it in charging it gave me a black screen then I tried to repair it but it's screen spot going on
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Make sure you have a charge and that your power supply is functioning What do you mean by"it's screen spot going on".A little more info on what you mean would help in the mean time A static discharge is also an option . Unplug the machine and pull the battery then hold down the power button for a full 60 seconds then release and do it again then put the battery back in plug in the laptop and try to reboot.. Hope this helps
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Isaac Rego será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 211
