Ir para o conteúdo principal
The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
20 Perguntas Visualizar todos
Why isn't my battery holding a charge?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
You may have used the wrong charger, please see our troubleshooting page for more information. Also the battery may have been damaged.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
If your computer isn't holding a charge your battery is likely just old. Many laptops batteries support around 400 recharges which ends up to be around one or two years, and from then on only hold a fraction of the charge. This is a easy fix though, you should just follow this guide on which battery to get and how to replace it in your computer yourself.
Pontuação 2
Adicionar a sua resposta
John Luckmann será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 908
