Ir para o conteúdo principal
A portable e-book reader developed by Amazon. Repair is straightforward and requires only prying tools and screwdrivers.
20 Perguntas Visualizar todos
My kindle isn't switching on?
Normally when I open the case my Paperwhite automatically switches on but not today!! I've also tried pressing the on button at the bottom but still to no avail :-( it looks like it's frozen and I don't know how to rectify it. Any help much appreciated.
Esta é uma boa pergunta?
Pontuação 4
2 comentários
Your question/answer resolved my issue - kindle would turn on to Swipe to Unlock Kindle, I'd swipe and it would open to a blank white screen!
por
This did not solve my problem what should I do?
por
Adicionar um comentário
6 respostas
Pergunta mais útil
Hi Ladybugs,
Can't say l know what the problem is with your Kindle but if as you say it won't turn on you probably need to reset it. I found the following info on the Amazon site.
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart.
Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
Beware: if you reset your Kindle you will lose all your downloads. If you have all your content on your Amazon account you can easily download it again should this happen. Let me know how you go.
There is lots more troubleshooting info on the Amazon site.
My interest, I also own a paperwhite Kindle.
Esta resposta foi útil?
Pontuação 9
3 comentários:
Brilliant, thank you so much, it looks like resetting has fixed the problem. I don't know what I'd do without my Kindle.
por
Great. My Kindle life has been restored at the press of a button.
por
perfect. Thank you
por
For me none of the restart approaches helped. The ad was still displayed on the screen, the display light did not go on, nothing happened. The one and only thing that worked for me was to put on the USB cable and charging the device, which I did all night. Hint: The power LED to the side of the connector must turn on while charging, if not, you may have a bad cable.
After having the device charged, I still couldn’t turn it on. So I tried all the restart possibilities described (push the button for 7s, 40s, 45s, 60s). All the descriptions tell to unplug the device before restarting it. After nothing worked I connected it to a power source (my laptop) again and pushed the button for a long time again and after letting it go the display light went on and the ad changed to the battery symbol with the “!” mark on it.
I think now it’s charging.
Pontuação 1
2 comentários:
So at the end a working cable did the trick. Tried 5 cables at least though, so it's not trivial.
por
Thanks so much for the tip. My kindle started working instantly.
por
I think it’s a common fault on the Paperwhite. I’ve just taken mine apart and replaced the power button flexistrip; not really a job for anyone who doesn’t dabble in electronics regularly.
But before that, I used this ‘workaround’: Plug it into a computer via USB. On mine, this bypassed the power button and it came on. I then ‘disabled’ the sleep mode so that it stayed on by entering ~ds in the search box. By turning the brightness down when I had finished reading, it stayed on for quite a few days before needing re-charging but at least I could read my book! If it went flat, I could just repeat the process.
The ‘button’ appears to be a very thin piece of ‘foil’ behind a gel pad which is pushed in by the black rubber button that is visible. The foil, when pressed in, touches two metal pads thereby activating the circuit. In mine, there appeared to be some black residue or dirt between the foil and the pads so they were not being connected. Some Isopropol Alcohol spray cleaned it sufficiently to make it work but then I managed to destroy the flexi-strip so had to fit a new one.
Pontuação 0
I had the same problem of not being able to reopen a paperwhite. Tried all the usual methods to no avail so plugged it into my PC. It showed up in Explorer with all its contents which I download to my PC as a backup. Unplugged the Kindle and restarted it. The Kindle response was slow so I did a full power down by holding in the power button for a few seconds and now it is functioning correctly. (Fingers crossed)
Pontuação 0
My paper white is new it’s charged but won’t open
Pontuação 0
i did everything - resetting, charging overnight, plugging into the computer... but the light stays completely off and the screen froze on 'low battery'. it seems it is truly dead, any advice?
Pontuação 0
1 comentário:
try another cable, see my comment up there
por
Adicionar a sua resposta
ladybugs será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 28,440
