Ir para o conteúdo principal
A 10-megapixel, point-and-shoot camera developed by Canon in 2010.
Why isn't my camera's screen showing pictures/images?
When I turn on my camera and the light is on which shows it is powered on, nothing appears on my screen when I aim to shoot. I am not in a dark environment, there is nothing on the outside lens, and I have never had this problem before. What can I do to fix this and what could be wrong?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
  • The screen is cracked or water damaged. The screen may need to be replaced.
  • The wires that connect to the screen are faulty or disconnected. Disassemble the camera to reconnect the wires or determine other types of internal issues.
Esta resposta foi útil?
Pontuação 1
Hi, it's possible that your screen may be damaged or there's an internal issue. There's a replacement guide for this if you're interested: Canon PowerShot G12 LCD Screen Replacement
Pontuação 0
It's a common failure, a mechanical problem on the lens shutter :-(
Pontuação 0
1 comentário:
How do I fix it
por
Adicionar a sua resposta
Nathan Meuwissen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 2,679
