Ir para o conteúdo principal
Contrary to popular belief, Linux is not an operating system but an operating system kernel that is used as the base for an operating system and is mostly used on servers, however, it can also be used on a standard desktop.
Can't mount USB device in Ubuntu live?
I have an SD card on the FAT format and windows wont allow me to view them unless i format them which i dont want to do as it will cause me to lose all the data.
any suggestions?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
This question was migrated from http://meta.ifixit.com/Answers.
por
Adicionar um comentário
1 resposta
Solução escolhida
You're lucky, Ubuntu can read the data. Just copy the data over to the hard drive, then format the SD in win7- fat32 would be perfectly fine. After that copy the data over to the win7 computer.
Esta resposta foi útil?
Pontuação 1
8 comentários:
Ubuntu cant read the disc as it needs to be mounted? I cannot do this?
por
what were you viewing the data with originally?
por
a phone, but the phone supported FAT16?
por
have you tryed to Reboot with the SDcard in the slot.
than Do a PCI re-scan?
por
echo 1 | sudo tee /sys/bus/pci/rescan
por
Exibir mais 3 comentários
Related Parts and Tools
Adicionar a sua resposta
Ryan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 1,128
