Why is my computer won't turn on?
When every time I press the power button It just blink and the the blue A sign only light up. please help.!
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
It could be one of several different issues that you'll need to troubleshoot to find out what could possibly be causing it not to boot. You may have a corrupted RAM stick which might cause it not to boot up, you can try removing one of the ram sticks and turn on the computer with just one ram installed.
Also sometimes there is a pattern to the blinking light that you see and if you look up the specific blink code for that model it will tell you what the problem. Have a look at this service manual, it has the error blink codes and what you could do to solve the problem.
Esta resposta foi útil?
Good reference--+
issue not solved
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 3,932
1 comentário
WHY my computer screen turn on i have TV
por Devadass K Dass
