It won't start or turn on
Washer will not start
Kenmore 110
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
If your Kenmore 110 Series Washing Machine refuses to turn on, see the Kenmore 110 Series Washing Machine Won’t Turn On problem page for possible causes and solutions.
Check and make sure circuit feeding washer is live try plugging a working lamp into the plug with the washer to check
If the lamp doese’t work go to the inside breaker panel and look for tripped breaker normally it will be a 15amp or 20 amp depending on how the circuit is run
Esta resposta foi útil?
Unplug the machine for 5 minutes to allow it to reset.
Mine worked by resetting
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 7,848
