Why won't my Fit turn on?
I have tried to turn on my fit by pressing the on button multiple times, I have also made sure the battery is charged but it still will not turn on. What can I do?
Esta é uma boa pergunta?
I too had this situation where my Gear Fit appeared to be 'Dead' even after charging for 24 hours, I noticed however that my Phone still had the Gear Fit Icon showing.
I disconnected the Bluetooth and reconnected and noticed it connected fine so I held the power button down on gear fit for around 5 seconds (maybe longer) and it appeared to perform a 'Soft Reset' and started up fine.
Esta resposta foi útil?
I had the same issue, I just turned off my Android phone blue tooth, went to Gear fit and held the power button for 10seconds and it finally turned on and had a message to connect, I went to the Fit software on my Android and I was prompted to turn on Bluetooth, once I did turn on blue tooth via the Gear Fit program the Gear Fit screen had a check mark I was prompted to push and so far everything is working.
Thanks Ben this "reset" you used worked for me as well. You saved me a trip back to the new Samsung store.
This worked for mine too! It wouldn't charge at all and after turning off my Bluetooth on my phone, the reset (holding gearfit button for 10-15 seconds) allowed the device to start charging.
this happened to me just today. my gear fit is not turning on. not charging. totally dead! i panicked. luckily, i have a very patient partner and adviced me to leave it for a few hours to charge. after 6 hours, i pressed the power button for 10 seconds the voila! i came to life. horray! i hope this comment will help others with this problem.- charlotte, auckland, nz
Wow thanks ben been trying all day to work out what was wrong and it worked perfect. You are a life saver.
Mine has a black screen, but when on the charger, indicates 100% charged. I tried holding the power button down for a long time, with no result. Then I tried pressing BOTH buttons, and immediately, it came on.
That just worked for me after trying all the many suggestions that I've been reading for the past 2 days! Thank you so much for this!!!
I try all hold buttons put change it vibrates and still gets notifications from the phone but no screen and I didn't do anything apart from put it on charge only overnight
I try all hold buttons put change it vibrates and still gets notifications from the phone but no screen and I didn't do anything apart from put it on charge only overnight. This is only two months old and they're not dropped it and looked after it very well it was on 8% battery life so I put on change when bed I noticed the charging screen was on when I woke up. So I going let battery die completely then I'll put it back on charge. but pressing the buttons does not do anything even resetting it from the phone does not do anything but when I get a text message it still vibrate
I had the same problem. I had 80% battery and the screen turned off. If I held the power button down it would vibrate but that was it. I cleaned the charging points, turned off Bluetooth on my phone. Connected the charger and was able to get it to turn on again. Turned Bluetooth back on my phone and it fixed itself. Weird
Bryan,
Please make sure you're holding, not just pressing, the power button for at least 3 seconds. Simply pressing the button quickly does not boot your device.
If this fails it may be due to battery failure. This may be the case if you have dropped/possibly damaged your Gear Fit recently. The battery may also simply have expended all of it's charge permanently. The estimated lifetime of the battery used in the Gear Fit (210mAh according to Gizmodo) is 1000+ "cycles" which is one complete drain from 100% to 0%. This translates to roughly two years for the average user. Extensive use (especially while simultaneously charging) can reduce this and cause early battery death. Either of these causes will require battery replacement which is covered here*. If you need further assistance, please do not hesitate to ask.
Kyle
My problem is different. The battery died and I can't charge again. When I put the charger in it doesn't vibrate and start charging. What can I do?
The contacts on the back of the gear fit may be dirty. You can clean using a pencil eraser for both the charger clip and gear fit. I have cleaned mine this way and do far so good.
My Power Button doesn't seem to be working. The fit works fine, but when I press the power button nothing happens and when I hold it down it won't shut off or restart. I just got it last month as a Christmas gift.
Mine just shut off at 30% charge. Putting it in the charger did nothing. As stated above, I held the button for a good 10 seconds and it restarted.
Just had the exact same thing happen to my gear fit watch. I tried everthing to start it but nothing worked until I pressed the on button for at least 10 seconds. It then vibrated and began the charging cycle!
Thank you for all good advice taken, mine has been in complete darkness most of the day but when I connected the charger it didn't seem to be doing anything. A lot of patience does go along way cos hey presto it's back on! Thank you everyone
A T T E N T I O N :
G e a r F i t 2 u s e r s
if your Samsung Gear Fit2 does not power on when power is pressed, or if it does not reboot when holding the power button, place it in the charging dock and press power once while on the charging dock. If that doesn't work, press and hold the power button for more than 10 seconds while on the cbarging dock.
About a week and a half ago I went to sleep and put my gear fit2 in the dock to charge overnight. After the mentioned time, I decided to wear it today and no matter how many times or for how long I held down the power button, it will not power on. When i got home I did the steps included above: I put it on the charging dock or base and pressed the power button (I can't remember if one quick time or for a few seconds) and it lit up with a 0% charge.
I don't understand after 1 and a half weeks of sitting on the charging dock how it would show 0% charge. But right now it's been charging for 10 minutes and it shows 23%.
No clue. Maybe it's a battery saving feature that makes the fit2 stop accepting charge after an extended period sitting on the dock?
- Milton
I just experienced the same issue. My Gear Fit just disconnected and went black. Holding the button down would make the device vibrate, but the screen remained black. Just charged the device yesterday and should have over 50% battery life left. These devices are, in my opinion, too new to be experiencing battery failure.
I put mine on the charging cradle for grins, but still no response. Interestingly, and this may be a completely random coincidence, I checked my phone (Galaxy S4 Actove) for a software update and my Gear Fit came back online. Lost my step count for the day, but my exercise history was still on the device. I can't for the life of me think of a reason why or how the phone could keep the device from turning on, so again...this was likely a coincidence.
I experienced the same problem as you all did. It turned out that the charging point on my gear fit was a bit dirty. Try to clean it up even if it looks okay. If that doesn't work, try to clean the charging adapter too. It worked for me and I hope it works for y'all folks too. Cheers..
Just had the same issues. Just randomly turned off and wouldn't turn back on again. Tried the reset thing and it vibrated a few times then showed 0% battery even though I know it was fully charged. Got it back on charge currently so fingers crossed. At least its turned back on.
Well, I was told by a computer geek that when he cannot get a response from a computer hard drive or some other device that has an internal battery, he puts it in a bag, in the freezer, he claims you let it cool a couple hours then when you take it out, you don't have long before it warms up, so put the charger back on or try and turn it on. Maybe it will help, beats replacing and its cheap. P.S. If that works and you have to repeat it, likely you have a connection issue internal to the Fit and cooling contracts components or internal components have a thermal issue. Good luck
Well, couldn't find a new Gear Fit, so, got a refurbished one. That was only 2 weeks ago and already it won't work. Have to take it back tomorrow. Geek Squad won't guarantee the ones THEY work on. lol Glad I didn't waste $100.00 and it last 6 weeks. I have had a lot of trouble with the apps too. Won't work with my Samsung Galaxy Tab 3. I got the Gear Fit just for that reason! When I downloaded the Manager it said "For security reasons, your device is currently set to block installation of applications not obtained from Play Store. To change this. go to Settings > Security > Unknown sources." Where else would I have gotten the app?? lol Anyway, it won't charge. The charger just vibrates. We will see I guess.
Thanks for this. Mine wouldn't respond to the button for turning the screen on/off or turning the device on/off. I turned off BT at the Gear Fit several times and did a reset from the settings function several times. Nothing seemed to work and it was down to 1% battery.
I found this forum, turned off BT at the phone and the Fit immediately started charging; all functionality returned as well. Turned BT back on at the phone and everything is fine and working properly!
MY fit has gone completely dead three times so far. Each time, it takes 2 to 3 days to recoup, and then out of the clear blue, it begins to work again after hanging on to the charge line. I can't depend on this gizmo to work for me when I really need it. I'm forced to do a return, sadly.
same problem. I had to hold down the power button for about a minute (first pressed the power button a bunch of times due to frustration), it finally turned back on and is charging.
rebooting the device fixed the issue with mine.
I did the same. I rebooted and now it is charging. Almost had a mini heart attack. I love it and would be lost without it.
Thanks for the help, folks. My Gear Fit absolutely refused to charge last night, no matter what I did (different charge cradles, different cords, left it plugged in all night)... but after it was plugged in all night and reset it (15 sec hold), I reconnected the bluetooth on my Note4 and now all is well... I think LOL.
I had been trying to figure out a good way to clean the contacts. I never thought about a pencil eraser. I was just wetting it a little and that had helped before but the corrosion has been getting worse. The eraser helped a lot!
Thank you so much. I use my Fit for everything and wasn't looking forward to having to buy a new one, as this one's just out of warranty!
I was having a problem with mine last night. All of the sudden the battery dropped to 2% so I plugged it in for the night only to find out after I got to work that it didn't charge. I got home and put it back on and it still didn't seem to do anything even after cleaning the contacts and all. So I finally grabbed a separate phone cord and plugged it into my computer and it popped on and started to charge so I don't know if my power cord has gone bad already or if it just needed a jump from another power source to jump start it. But it's something that people may try.
I just took mine out of the box and it was unresponsive. I plugging it into my computer, into the wall socket, cleaning the contacts on the watch and on the dock, holding the power button, holding both buttons, i tried to power it up while it was sitting on the dock....nothing. When I read this, I grabbed a Fast Charge plug from an old phone and attached the USB cord on the dock to that and it fired right up. The battery was at 0% and slowly clicked over to 1%. I'm still holding my breath and I'm glad I purchased the 2 year warranty just in case, but hopefully everything works out. Hope this helps someone.
I have had this problem several times, and this works for me:
Turn off bluetooth on your phone
depress the on/off button on the watch for approx 10 seconds
phone will then reboot, even though it had been 'dead' beforehand
Turn back on bluetooth on your phone
Job done :-)
I took my Gear Fit to an accredited dealer. All they had to do was boost the system. Almost like shocking a person who has had a heart attack. Once done there should be no further problems.
5 years ago for this comment ... Eesh. Just bought a spare fit2 and it won't turn on.... Sort need interested what this accredited dealer did to give your device a "system boost"
Push and hold it longer (3-4 seconds). Or untill it turns on.
I had the same thing happen to my Gearfit 2 twice now. The first time I followed the instructions below and it fired back up, and I had to perform the Soft Re-start. This time it would not power up no matter how long I depressed the power button.
So I put the Gearfit 2 on its charger and then pressed the power button and held it down. It took about 12-15 seconds and then came to life.
The interesting thing thing is, I always power mine down when charging. When I powered it down it still had 42% battery life. Now it is totally dead. What happened to the charge it had?
Kirk C.
just got mine working again…. it’s been over a year!!!!! and it’s simple
put watch on the charging station for about 5-10 mins (that’s what i did, don’t know if that’ll make a difference) while watch is on charging station hold down power button for about 20 seconds (OR MORE), device will reboot and begin to charge!!!!!!
please make sure device is on charging station…. a little maneuvering is in order!!!!!
i tried it without it being on the charging station (like it says online) but it didn’t work.
hope it works!!!!
I tried everything. I cannot restart the Fitbit. I cleaned it, shut off my Bluetooth, held 1 & then 2 buttons, changed the docking station outlet, and let it charge for 2 days. Nothing.
I think the battery needs rebooting. How do I do that, or where can I bring the watch. It was a gift.
Hi all, this was my fix when my gearfit just stopped working for no reason.
I turned off bluetooth on my phone n tried connecting again….did not work…
after a few seconds…i held down the lower button…the smaller one….for about 7 seconds and it started rebooting.
hope that helps.
I have this problem that Fitbit doesn’t charge on the docking station for 5-6 days and suddenly after a week it will charge once, work for a day and poof again dead.
@Ranjana N , in experience its usually due to the syncing between your gearfit and your phone.
When it doesnt work, try shutting down bluetooth
wait for 5 mins ( have a tea)
then hold down the smaller second button for 10 seconds
if that too doesnt work then its ur gearfit, hope u have warranty
This solution worked for me. I did forget device from bluetooth connection and tried reconnecting later while charging gearfit2 long pressed power button. It started working. Thank you for posting solution.
Alright, so i recently had my gear fit 2 charge last night took it off the charger when i took it off it was at 1% it died i tried to charge and nothing. So cleaned the charging pins, took it on and off the charger while holding the power button while it on or putting on it then nothing happened no charge indicator or anything . It was fine the other night now its dead to the point of not turning on any solutions ??
So i have read all the comments and tried all the solutions to no avail. black screen of death. every now and then a little charge bolt will appear.
The only thing I haven't done is the freezer trick. but last i checked it's @ 100%.
Últimas 24 horas: 5
Últimos 7 dias: 44
Últimos 30 dias: 234
Ao todo: 126,921
27 comentários
My Samsung Gear Fit is trying to reboot but keeps failing. It appears to keep recycling and retrying to reboot.... just can't do it. I called their customer service number and got NO WHERE. I've not dropped or damaged my device in any way and its less that 90 days old so I don't believe its the battery. Serious concerns - service tech was not helpful and in closing was told that someone else will call me within 48 hours :-( Not at all happy here today!
por D Wolford
I am having similar issues as well. After wanting an activity tracket for around 2 years I finally decided to take the plunge and buy one. I was looking at the fitbit chargehr and charge 2 but decided to go with the gearfit 2 as I had heard it was better than the fitbit and also had phone notification connection and touchscreen. I absolutely LOVE the look of this watch and the comfort is out of this world. I aactually forget I have it on. I have had this almost 4 weeks and am now having issues. It freezes up or shuts off and won't restart up unless I put it on the charger for a long period of time. I charge it at night so I know it is not happening due to a low or dead battery. I have not worn this in the rain or shower as I never trust that any device is actually water proof or resistant. I also did not purchase a warranty because I am very careful with any device I own. I was super excited for this watch and to have an extra push towards a more fit life yet I am now finding myself disappointed and less motivated that I was previously. After spending $180 US I expected a better, more functional and less buggy device. I feel I should have gone with the fitbit as a lot of those I know own and love theirs and have no problems whatsoever.
por Hannah
Everyone I charge my watch I have trouble getting it to charge
por suz62
When my gear fit failed, it started to vibrate for a long time! It lasted about 5
minutes until BAM!!! For the next 48 hours I left it charging and no response. So disappointed :-(
Gear Fit (March 25, 2016-August 13,2016)
por Juan Marquez
I have a Gear Fit which is unresponsive. When I do get it to "power" up I get a dimly lit screen with four white vertical bars and five black/grey vertical bars. I inadvertently had it on when I was swimming, maybe 15 minutes, but did not go underwater with it. I believe the specs say it is safe in 5 meters of water for thirty minutes. Any idea of whether or not this is fixable? Thanks.
por Don K
Exibir mais 22 comentários
