Ir para o conteúdo principal
The Nissan Xterra is an SUV that was manufactured and marketed by Nissan Motors across two generations, utilizing its Nissan F-Alpha platform shared with the Nissan Frontier pickup.
acts like it's not getting fuel
Acts like it's going to die at a stop. Like it's not getting enough fuel.
Esta é uma boa pergunta?
Pontuação -1
2 comentários:
How does it act while accelerating? Any check engine light on? Have you done a OBD scan? Any codes? What year is it and what engine size does it have?
por
Check the MAS air sensor. As the I had that problem and the check engine light did not come on. dbamm1
por
Adicionar um comentário
1 resposta
In order of expense troubleshooting...
Fuel filter, ~$25.00
Fuel pressure regulator, ~$55.00
Fuel pump, ~$550.00
Let me know how it pans out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Shawn Burk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 300
