Ir para o conteúdo principal
Model A1051 / 4 or 6 GB hard drive
20 Perguntas Visualizar todos
iPod won't power on
I have replaced battery and new click wheel but the iPod will not power on
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
5 respostas
Pergunta mais útil
I recommend opening up the iPod and making sure everything is plugged in correctly. Sometimes a problem like this is caused by a simple loose connection. Will the iPod turn on if plugged into a computer? If it does, then you may need to restore the iPod and let the battery fully charge.
Esta resposta foi útil?
Pontuação 1
I don't know how to get music on it
Pontuação 1
The iPod has a battery symbol with a lightening bolt in it . what is the problem??
Update
How do i repair it??
Pontuação 0
1 comentário:
The mini shows the charging animation (battery w. lightning bolt) when it's charging in standby mode (only when it's not connected to itunes)
por
Replaced the battery-now the ipod will not go on only the applee logo stays on even i put it on the charger on?
Pontuação 0
how do i know if mi ipod needs new battery
Pontuação 0
1 comentário:
hi i need help how do i know if my ipod touch needs new battery it dont start i almos buy the battery
por
Adicionar a sua resposta
strilerscarecenter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 7,100
