Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Apple Watch Series 3, use o nosso manual de serviço.
  1. Apple Watch Series 3 Teardown, Apple Watch Series 3 Teardown: passo 1, imagem 1 %32
    • What's that in your shiny new Apple Watch?
    • Second-generation OLED Retina display with Force Touch
    • Consistent with the original Apple Watch, the Series 3 comes in two sizes: 38 mm (272 × 340 pixels, 290 ppi) and 42 mm (312 × 390 pixels, 302 ppi).
    • Custom-designed Apple S3 SiP (System in Package)
    • Optional LTE and UMTS, built in GPS/GLONASS + NFC + Wi-Fi 802.11b/g/n 2.4 GHz + Bluetooth 4.2
    • Accelerometer + gyroscope + heart rate sensor + microphone + speaker + barometric altimeter + ambient light sensor
    • Water resistance rating (up to 50 meters)
    • WatchOS 4
  2. Apple Watch Series 3 Teardown: passo 2, imagem 1 %32 Apple Watch Series 3 Teardown: passo 2, imagem 2 %32
    • Before we get inside, put on your X-ray glasses for a sneak peek.
    • Many Bothans died to bring us this information. Just kidding. This image is courtesy of the friendly X-ray experts at Creative Electron.
    • While the overall layout is fairly unchanged from the original Apple Watch we tore down and X-rayed in 2015, it looks like there may be a few extra solder pads under the speaker (top right of this image).
  3. Apple Watch Series 3 Teardown: passo 3, imagem 1 %32 Apple Watch Series 3 Teardown: passo 3, imagem 2 %32 Apple Watch Series 3 Teardown: passo 3, imagem 3 %32
    • Time for a quick check of the back to make sure we bought the right watch.
    • Yep, this here is an Apple Watch Series 3, the most exclusive and top of the line Apple wrist computer, offering unparalleled computing power and fashion for the next 51 weeks.
    • We even got the LTE model!
    • Next to that secret diagnostic port we picked out a new model number: A1889.
  4. Apple Watch Series 3 Teardown: passo 4, imagem 1 %32 Apple Watch Series 3 Teardown: passo 4, imagem 2 %32 Apple Watch Series 3 Teardown: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    iOpener
    $17.99
  5. Apple Watch Series 3 Teardown: passo 5, imagem 1 %32 Apple Watch Series 3 Teardown: passo 5, imagem 2 %32
    • Cables de-ZIF'd, we're clear to get a look at the display.
    • Spec-wise, the display is unchanged from the Series 2, with one key difference—it now functions as a multifrequency (LTE?) antenna.
    • We'll be testing compatibility to see if the displays really are interchangeable.
    • This display has one fewer IC than last year. Probably wasn't important.
    • Analog Devices 343S00092 touch controller
    • NXP Semiconductor PN80V NFC module
    • Texas Instruments TPS36372 display power management (likely)
    • Empty solder pad (20211CP TD1628A goes here?)
    天线馈点在什么地方,怎么解决天线净空问题呢?
    emouse - Responder
    It will be interesting to see the compatibility between series 2 display and series 3. This will also be a good test for LTE.
    Thomas - Responder
    …and? are the series 2 and 3 displays compatible?
    arjandeboer - Responder
    are the series 2 series 3 (non cellular) screens Interchangeable?
    Close Fan - Responder
  6. Apple Watch Series 3 Teardown: passo 6, imagem 1 %32 Apple Watch Series 3 Teardown: passo 6, imagem 2 %32 Apple Watch Series 3 Teardown: passo 6, imagem 3 %32
    Mako Driver Kit - 64 Precision Bits
    $39.95
    • As in the prior version, further access is barred by a tiny tri-point screw—one of 64 possible contingencies we've come prepared for.
    • The top third of the watch is labeled "Taptic Engine," and that's mostly true—but the label also hides a bracket that guards, among other things, the battery connector we're searching for.
    • Time to pick away the power pack and see what gives this watch its all-day go-juice.
    • Professional teardown engineer on a closed track. Do not attempt battery replacement on the go.
  7. Apple Watch Series 3 Teardown: passo 7, imagem 1 %32 Apple Watch Series 3 Teardown: passo 7, imagem 2 %32
  8. Apple Watch Series 3 Teardown: passo 8, imagem 1 %32 Apple Watch Series 3 Teardown: passo 8, imagem 2 %32 Apple Watch Series 3 Teardown: passo 8, imagem 3 %32
    • So far so good. We pull out the standard Force Touch sensor/gasket, equipped with the same Analog Devices AD7149 capacitance sensor controller that we found in the Series 2.
    • Continuing our parts-picking spree, we pluck out the Taptic Engine, seemingly unchanged from watches yore.
    • Then out pops the antenna array, including what we believe to be the GPS antenna.
    on the side opposite the crown on the taptic engine is a convoluted maze of connected ribbon cables that is actually soldered to the taptic engine - right under the ribbon cable underneath what looks to be BGA chip (black, square - similar in size to a tristar chip) and trying to lift this ribbon cable to remove the taptic engine in the order this teardown indicates will result in torn pads - either a max total of 4 or in my case, i only tore 2. this teardown shown here resulted in 4 torn pads, which you can see in step 10 first photo. the photo shows the cable flipped back over and you can clearly see the torn pad area. and by also folding the ribbon cable back, it can also tear away at the underlying solder connecting the ribbon cable to the motherboard. atm, it appears to me that to properly remove the taptic, it needs to stay where it is and remove the whole motherboard including the taptic engine. so to replace just the taptic engine - would involve a large amount of risk and work.
    greg - Responder
    It would’ve been really nice if ifixit called this out. I didn’t see your comment until after I removed that ribbon cable. At first it looks like it’s some kind of adhesive, but I suppose it is actually soldered? Anyway, time for me to buy a new watch. Thanks ifixit!
    Insu -
  9. Apple Watch Series 3 Teardown: passo 9, imagem 1 %32 Apple Watch Series 3 Teardown: passo 9, imagem 2 %32 Apple Watch Series 3 Teardown: passo 9, imagem 3 %32
    • The plucking continues, as we remove the self-emptying speaker, designed to sonically blast out water after your watch takes a dip.
    • After an entirely Series 2-ish experience, we're finally rewarded with something new—a whole new section of RF chips, surely responsible for handling the added LTE functionality.
    • In another new twist, the air vent hole next to the microphone is now populated by what looks like a barometric pressure sensor.
    • Apple touted a new barometric altimeter when it introduced the Series 3 at the Steve Jobs Theater—much to our confusion, since we already found a barometer in last year's model.
    • Time to pull this board!
    Speaker of my watch isn't working. Please guide me what to do.
    Manish Phukela - Responder
  10. Apple Watch Series 3 Teardown: passo 10, imagem 1 %32 Apple Watch Series 3 Teardown: passo 10, imagem 2 %32
    Hi iFixit,
    is it possible to see what’s inside the Apple S6 module ? I suspect LTE modem and others are inside ?? Thanks
    Bagan Tech - Responder
    Hate to do this but someone else removed the cap to show the components hiding underneath , heres the link http://techinsights.com/about-techinsigh...
    Don’t worry ifixit, you are still the first place I go to for teardowns, but its always good to look around for more info.
    aaronzvz -
    @aaronzzz We’re fans of TechInsights and have worked with them a time or two on collaborative teardowns. So, no hard feelings! They do fantastic work. Thanks for the link!
    Jeff Suovanen -
    After a comparison of X-Ray picture above with the teardown, we came to believe that there are at least 3-4 chips missing on the teardown, and they’re most likely located under the “S3” marked radiator sink, glued to it from the other side. These chips likely include the Apple CPU itself, the modem and possibly the RF.
    William Bakshi - Responder
  11. Apple Watch Series 3 Teardown: passo 11, imagem 1 %32 Apple Watch Series 3 Teardown: passo 11, imagem 2 %32 Apple Watch Series 3 Teardown: passo 11, imagem 3 %32
    • Last call: back cover. It's press-fit over a teflon-like O-ring, but a thumbs-up and a firm push relieves it of duty.
    • The material has been standardized across watch models and souped up to snazzy ceramic, replacing the previous Ion-X or Sapphire options.
    • It also houses the PPG sensor array that is responsible for sensing heart rate.
    • It would've been cool to see some change from the Series 2 after complaints about accuracy in previous models. As far as wearables go, however, the Apple Watch is the best of the bad.
    • Also it appears that the wireless charging coil has been slightly modified to support most Qi wireless chargers.
    • Lastly, with the new barometric altimeter taking the spot next to the microphone, where did the air vent go? Answer: hiding out right here, next to the diagnostic port.
    the non-cellular variant is still that composite back, while the higher end versions have always been ceramic. Sapphire or Ion-X is only the front display cover.
    Josh Calvetti - Responder
    The watch back is ceramic on the GPS + Cellular Series 3, but it’s composite on the GPS-only model. Previous watches have had a composite or ceramic back, never sapphire or Ion-X. Source: https://support.apple.com/en-us/HT204507
    Ryan Steele - Responder
    hey do any one know why i cant pop out the ppg sensor out. i think it has something to do with this metal ring around it, but i can not figure out how to get it off.
    briana1987be - Responder
  12. Apple Watch Series 3 Teardown: passo 12, imagem 1 %32 Apple Watch Series 3 Teardown: passo 12, imagem 2 %32 Apple Watch Series 3 Teardown: passo 12, imagem 3 %32
    • Here's all the clockwork watchwork!
    • Final big thanks to Circuitwise for giving up a bit of their weekend to help us out!
    • And thanks again to Creative Electron for putting the X(-ray) in "excellent!"
    WARNING ON THE TEARDOWN ABOVE
    Whilst it's an excellent starting point, the pictures and procedures of the teardown above do not resemble the insides of the Series 3 LTE version.
    Maybe there are a few versions of this hardware but I recently rebuilt one from scratch and there are several parts that don't seem to match and some serious caveats. On the series 3 LTE (red-dot aka cellular) there are a few of booby traps that are not mentioned above:
    * You cannot remove the haptic engine without desoldering a ribbon cable from the motherboard (or desoldering from the haptic itself)
    * The main PCB is glued to the casing. It is very hard to pry w/o damaging the ICs on the border.
    * The microphone cannot be removed independently w/o desoldering even more ribbon cables.
    * The complete teardown and rebuild CAN be done but it is not as trivial as described above.
    I have pictures of an actual complete Series 3 cellular complete teardown rebuild but I can't attach them here.
    May link them in the future.
    Alejandro I - Responder
  13. Considerações finais
    • Watch band replacements remain fast and simple.
    • Screen replacements are difficult but do-able—it's the first thing to come off, and detaches via simple ZIF connectors.
    • Battery replacements are tricky but fairly straightforward once you're inside, provided you're armed with a Y000 screwdriver.
    • While not proprietary, incredibly tiny tri-point screws are a repair hinderance.
    • Replacing any of the component cables requires microsoldering.
    • The mostly resin-encased S3 system makes most board-level repairs impossible.
    Índice de reparabilidade
    6
    Reparabilidade 6 de 10
    (10 é o mais fácil de reparar)
47Comentários do guia
Great ! I was waiting for this since the day it was shown at the launch ! First to comment as well I guess
Yolo - Responder
is the rear housing the same as the series 2 as well?
during the announcement, they claimed the watch was made a little thicker.
karl - Responder
What’s the purpose of the air vent that began with Series 2? It’s clearly not for barometric readings since Series 2 lacked a barometric altimeter.
Andrew Estock - Responder
Not sure of I didn't See a barometer at the Apple Watch
eisblock -
does apple tv 4k teardown coming soon? i am curious about power supply voltage and ampere. nice btw.
Muhammad Faisal Kemal - Responder
wait, which chip is the LTE chip? Rumor was that it would be Intel…..
bdan629 - Responder
If there is no Intel Baseband chip, then all this point to Apple will be making their own Wireless Chip! About time!
K Sec - Responder
What that SIM-tray lookalike beside model no. which appears in step 3?
Abedoss - Responder
I think you’re referring to the “Top Secret” 6 pin diagnostic port (under the cover) that’s been there since the series 0. For Apple Use Only!
Nikon1 -
Does the 38mm GPS only and the 38mm GPS+LTE share the same battery? Or is there a difference between the two 38mm Series 3 models?
Bort - Responder
Can a series 2 be used with a iPhone 8 plus or X
Scott Green - Responder
Could you show the detail of “Screen as LTE antenna” that introduced during the Apple Event on 12 Sept.?
Show Siong LIM - Responder
Apple was “economical” with the truth. The antenna is glued to the back of the screen and made by a different process.
Thanh Tran -
Wow that taptic engine is taking up at least 30% of space.
dennisonphillips - Responder
Is the battery capacity the same in the larger 42mm version?
BilMcKelvy - Responder
looks like the “Screen antenna” is really on the force touch sensor? (step 8)
that would make sense, it goes all around the border of the screen.
karl - Responder
Do you think that after replacing the battery, the watch could still be waterproof?
Dan - Responder
whats the GPS module used in this watch
vamshi gajjela - Responder
Are the series 2 and 3 screens changeable
bnharris92 - Responder
Are the series 2 and 3 lcd screens interchangeable???
Twee Tang - Responder
Same question about interchangeable screens. I need a replacement, but 38mm Series 3 screens are hard to come by.
Dana Hallenbeck - Responder
screens are not interchangable.
karl - Responder
Bonjour j’ai cassé le lcd de ma série 3 Apple Watch puis je mettre un lcd de Apple Watch serie 2 beaucoup moin chère pour ma série 3??
robby46 - Responder
We’re do I get a new screen
Felix Juan - Responder
Where can I found Apple Watch 3 screen?? I need a replacement.
Thanks
gabbo_-_95 - Responder
Although board level repairs aren’t viable, is it possible to replace the board of an apple watch? When putting the watch back together, did it still seem waterproof?
Logan Jung - Responder
What is the design name of the self-emptying speaker?
Anthony Gabrian - Responder
Can the rear sensors be replaced without soldering?
bdwayneh - Responder
Where is the LTE-Antenna? Respectively the ground plane for the antenna?
Stefan Remmel - Responder
Where can i buy screen replacement?
meriganu - Responder
Hello, I was wondering if anyone has compared the rear shell of the series 2 to the series 3 GPS models yet. If so are the cases identical?
axilelyk - Responder
I need to replace the back housing/battery cover. Mine is shattered after running it over with my truck!!! The screen didn’t even crack! Just the back button/glass. Can I order that part here?
Michele Giel - Responder
Can you purchase a new speaker. The current speaker I have no longer works
Kevin Parker - Responder
Is it possible to pull out the logic board without soldering?
John - Responder
For the life of me, I cannot find the zif connector latch on my Apple series 3 display. I can pull the cables out and slide them back in, but there is no latch or any other pivoting mechanism that I can find. I completely boogered up my old display zif connectors trying to find a swinging latch. Every YouTube video mentions them and shows how to open them but not in enough detail to actually enable you to see what is happening. My new display does not work, so I can only assume that either the latch is not closed on the new display or was not opened when I inserted the cables.
Tom Baldauff - Responder
Where is the WiFi / Bluetooth antenna?
brutoboy63 - Responder
What a mess, this is very badly explained! who has been the one who uploaded this? They break a connector and there are steps that have not explained them, nor did they dare to open an Apple Watch with this guide.
Moiky - Responder
Hallo,
wo bekomme ich den die winzige Y000 Tri-Point Schraube für meine iWatch3 her….???
Meine hat sich im wahrsten Sinne aus dem Staub gemacht und sie wieder zu finden ist ja fast aussichtslos….
LG Andreas
Andreas Glauche - Responder
Hello,
you can recommend me, where can I find instructions to change a case at Apple watch serie 3 Well I have to buy and change new cases, but I can't find any instructions on the internet. Thanks
veacom - Responder
Hello,
Email: veacom@gmx.de
veacom - Responder
The digital crown can be removed. I’ve done it. Takes a lot of patience and a little heat.
John Pedigo - Responder
My Series 3 displayed popped off (swollen battery maybe) and the side with display cables are as seen here, but the top part of the display is anchored by another a cable or something. Can’t lift it away enough to see and don’t want to force it.
Tarun Vijjali - Responder
Display is totally intact and working, no scratches or cracks. Just the touchscreen is wacked out since it popped off.
Tarun Vijjali -
Where can I get the speaker for this watch?
Ben Sudworth - Responder
Is the display or any other part is tied to the motherboard? Can I change the motherboard with another one?
DnzDra Krks - Responder
Is there a way to fix a stuck button? Otherwise my Watch series 3 works fine
Allen Berrebbi - Responder
So can I take a 38mm series 3 and put it in a 42mm body with a 42mm screen? I’ve been looking EVERYWHERE for this info and can’t find it!
bigscripforever@gmail.com - Responder
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 109
Últimos 30 dias: 566
Ao todo: 251,139
