Introdução
The Taptic Engine produces your iPhone's vibration and haptic feedback functions. Follow this guide to remove and/or replace the Taptic Engine in your iPhone XS Max.
This guide instructs you to fully remove the display assembly; this is intended to prevent accidental strain or damage to the display cables while you work. If you feel comfortable removing the Taptic Engine without endangering the display cables, you can skip the steps for disconnecting the display cables.
O que você precisa
Power off your iPhone before beginning disassembly.
Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Ferramenta utilizada neste passo:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Ferramenta utilizada neste passo:Magnetic Project Mat$16.96
Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
Two 1.1 mm screws
One 1.5 mm screw
One 3.7 mm screw
Remove the five 1.4 mm tri-point Y000 screws securing the bracket below the Taptic Engine and main speaker.
Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
20 outras pessoas executaram este guia.
