Ir para o conteúdo principal
iPhone SE 2022 Battery Replacement
O que você precisa
  1. iPhone SE 2022 Battery Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Power off your phone before beginning disassembly.
    • Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
  2. iPhone SE 2022 Battery Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone SE 2022 Battery Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone SE 2022 Battery Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Responder
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Responder
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Responder
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Responder
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Responder
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Responder
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Responder
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Responder
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Responder
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Responder
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Responder
  3. iPhone SE 2022 Battery Replacement, Tape over any cracks: passo 3, imagem 1 %32 iPhone SE 2022 Battery Replacement, Tape over any cracks: passo 3, imagem 2 %32 iPhone SE 2022 Battery Replacement, Tape over any cracks: passo 3, imagem 3 %32
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone SE 2022 Battery Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone SE 2022 Battery Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone SE 2022 Battery Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone SE 2022 Battery Replacement: passo 5, imagem 1 %32 iPhone SE 2022 Battery Replacement: passo 5, imagem 2 %32 iPhone SE 2022 Battery Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone SE 2022 Battery Replacement: passo 6, imagem 1 %32 iPhone SE 2022 Battery Replacement: passo 6, imagem 2 %32 iPhone SE 2022 Battery Replacement: passo 6, imagem 3 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    It took a few tries to get this done -- with a broken screen the packing tape interferes with the suction cup hold. I eventually had to resort to a classic iSclack. Bear in mind that you don't need much of an initial opening, just enough to get a pick in. After a couple of minutes of the pick sitting there the surrounding adhesive will stretch and you'll be able to get two in for Step 9.
    Neal Sofge - Responder
  7. iPhone SE 2022 Battery Replacement, Heat the front panel adhesive: passo 7, imagem 1 %32
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  8. iPhone SE 2022 Battery Replacement, Insert an opening pick: passo 8, imagem 1 %32 iPhone SE 2022 Battery Replacement, Insert an opening pick: passo 8, imagem 2 %32 iPhone SE 2022 Battery Replacement, Insert an opening pick: passo 8, imagem 3 %32
    • Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
    • Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
    • If you have trouble creating a gap, apply more heat to the bottom half of the screen to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap under the screen's plastic bezel.
  9. iPhone SE 2022 Battery Replacement, Slice the adhesive: passo 9, imagem 1 %32 iPhone SE 2022 Battery Replacement, Slice the adhesive: passo 9, imagem 2 %32 iPhone SE 2022 Battery Replacement, Slice the adhesive: passo 9, imagem 3 %32
    • Slide the opening pick to the bottom right corner to slice the front panel adhesive.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  10. iPhone SE 2022 Battery Replacement, Slice the adhesive: passo 10, imagem 1 %32 iPhone SE 2022 Battery Replacement, Slice the adhesive: passo 10, imagem 2 %32 iPhone SE 2022 Battery Replacement, Slice the adhesive: passo 10, imagem 3 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  11. iPhone SE 2022 Battery Replacement: passo 11, imagem 1 %32 iPhone SE 2022 Battery Replacement: passo 11, imagem 2 %32 iPhone SE 2022 Battery Replacement: passo 11, imagem 3 %32
    • Slide the bottom right opening pick along the right edge of your phone to slice the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Stop near the top right corner of the display.
  12. iPhone SE 2022 Battery Replacement, Lift the screen: passo 12, imagem 1 %32 iPhone SE 2022 Battery Replacement, Lift the screen: passo 12, imagem 2 %32
    • Remove the opening picks.
    • Gently pull up on the suction handle to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Remove the suction handle.
  13. iPhone SE 2022 Battery Replacement, Slice the remaining adhesive: passo 13, imagem 1 %32 iPhone SE 2022 Battery Replacement, Slice the remaining adhesive: passo 13, imagem 2 %32 iPhone SE 2022 Battery Replacement, Slice the remaining adhesive: passo 13, imagem 3 %32
    • Slide an opening pick underneath the top left corner of the display.
    • Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
  14. iPhone SE 2022 Battery Replacement, Disengage the front panel clips: passo 14, imagem 1 %32 iPhone SE 2022 Battery Replacement, Disengage the front panel clips: passo 14, imagem 2 %32
    • Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
  15. iPhone SE 2022 Battery Replacement, Lift up the display: passo 15, imagem 1 %32 iPhone SE 2022 Battery Replacement, Lift up the display: passo 15, imagem 2 %32 iPhone SE 2022 Battery Replacement, Lift up the display: passo 15, imagem 3 %32
    • Open the phone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display from the phone assembly yet, as several fragile ribbon cables still connect it to the logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone SE 2022 Battery Replacement, Unfasten the lower display cable bracket screws: passo 16, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Remove the four Phillips screws securing the lower display cable bracket:
    • Two 1.2 mm-long screws
    • Two 2.8 mm-long screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  17. iPhone SE 2022 Battery Replacement, Remove the lower display cable bracket: passo 17, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the lower display cable bracket: passo 17, imagem 2 %32
    • Use a pair of tweezers to carefully remove the lower display cable bracket.
  18. iPhone SE 2022 Battery Replacement, Disconnect the battery: passo 18, imagem 1 %32 iPhone SE 2022 Battery Replacement, Disconnect the battery: passo 18, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
  19. iPhone SE 2022 Battery Replacement, Disconnect the display and digitizer cables: passo 19, imagem 1 %32 iPhone SE 2022 Battery Replacement, Disconnect the display and digitizer cables: passo 19, imagem 2 %32 iPhone SE 2022 Battery Replacement, Disconnect the display and digitizer cables: passo 19, imagem 3 %32
    • The display and digitizer cables run on top of each other. To avoid cable damage always start by disconnecting the upper cable first and never try to disconnect both at the same time.
    • Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
    • To re-attach press connectors like this, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  20. iPhone SE 2022 Battery Replacement, Unfasten the front sensor assembly bracket screws: passo 20, imagem 1 %32
    • Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
  21. iPhone SE 2022 Battery Replacement, Remove the front sensor assembly bracket: passo 21, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the front sensor assembly bracket: passo 21, imagem 2 %32
    • Use a pair of tweezers to carefully remove the front sensor assembly bracket.
  22. iPhone SE 2022 Battery Replacement, Disconnect the front sensor assembly cable: passo 22, imagem 1 %32 iPhone SE 2022 Battery Replacement, Disconnect the front sensor assembly cable: passo 22, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
  23. iPhone SE 2022 Battery Replacement, Remove the display assembly: passo 23, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the display assembly: passo 23, imagem 2 %32
    • Remove the display assembly.
  24. iPhone SE 2022 Battery Replacement, Unfasten the Lightning connector bracket screws: passo 24, imagem 1 %32
    • Unfasten the three screws securing the Lighting connector bracket:
    • One 1.2 mm-long Y000 screw
    • One 2.7 mm-long Phillips screw
    • One 2.9 mm-long Phillips screws
  25. iPhone SE 2022 Battery Replacement, Remove the Lightning connector bracket: passo 25, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the Lightning connector bracket: passo 25, imagem 2 %32
    • Use a pair of tweezers to remove the Lightning connector bracket.
  26. iPhone SE 2022 Battery Replacement, Loosen the Wi-Fi diversity antenna flex cable: passo 26, imagem 1 %32 iPhone SE 2022 Battery Replacement, Loosen the Wi-Fi diversity antenna flex cable: passo 26, imagem 2 %32 iPhone SE 2022 Battery Replacement, Loosen the Wi-Fi diversity antenna flex cable: passo 26, imagem 3 %32
    • Carefully slide an opening pick between the antenna flex cable and the top of the speaker.
    • This portion of the flex cable is lightly adhered to the speaker. If you're struggling to separate the cable from the speaker, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely.
  27. iPhone SE 2022 Battery Replacement, Disconnect the Wi-Fi diversity antenna: passo 27, imagem 1 %32 iPhone SE 2022 Battery Replacement, Disconnect the Wi-Fi diversity antenna: passo 27, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the Wi-Fi diversity antenna by prying its connector straight up from its socket.
    • The socket of this connector sits loosely between the speaker and the Taptic Engine and it's a bit fiddly to disconnect the cable. To make the disconnection easier, you can use an opening pick to hold down the connector socket during this procedure.
    • Reconnecting this cable can be tricky. Make it easier by using tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place.
  28. iPhone SE 2022 Battery Replacement: passo 28, imagem 1 %32 iPhone SE 2022 Battery Replacement: passo 28, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the Wi-Fi diversity antenna from the logic board by prying the connector straight up from its socket.
  29. iPhone SE 2022 Battery Replacement, Remove the Wi-Fi diversity antenna: passo 29, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the Wi-Fi diversity antenna: passo 29, imagem 2 %32
    • Use a pair of tweezers to remove the Wi-Fi diversity antenna.
  30. iPhone SE 2022 Battery Replacement, Unfasten the Taptic Engine screws: passo 30, imagem 1 %32
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the Taptic Engine:
    • One 2.1 mm Phillips screw
    • One 2.1 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  31. iPhone SE 2022 Battery Replacement, Remove the grounding bracket: passo 31, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the grounding bracket: passo 31, imagem 2 %32
    • Use a pair of tweezers to remove the grounding bracket at the left edge of the Taptic Engine.
  32. iPhone SE 2022 Battery Replacement, Pry the antenna cable socket: passo 32, imagem 1 %32 iPhone SE 2022 Battery Replacement, Pry the antenna cable socket: passo 32, imagem 2 %32
    • Use the pointed end of your spudger to pry the antenna cable socket up and away from the Taptic Engine connector below.
  33. iPhone SE 2022 Battery Replacement, Disconnect the Taptic Engine: passo 33, imagem 1 %32 iPhone SE 2022 Battery Replacement, Disconnect the Taptic Engine: passo 33, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
  34. iPhone SE 2022 Battery Replacement, Remove the Taptic Engine: passo 34, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the Taptic Engine: passo 34, imagem 2 %32
    • Use a pair of tweezers to carefully remove the Taptic Engine.
    Note that the grounding connector on the Taptic Engine's left side goes under the fixed contact, you'll need to remember than when reassembling.
  35. iPhone SE 2022 Battery Replacement, Battery stretch-release adhesive: passo 35, imagem 1 %32
    • The iPhone's battery is secured by four pieces of stretch-release adhesive—two at the top, and two at the bottom.
    • Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the front surface or sometime only to the short edge of the battery.
  36. iPhone SE 2022 Battery Replacement, Peel off the battery pull-tab: passo 36, imagem 1 %32 iPhone SE 2022 Battery Replacement, Peel off the battery pull-tab: passo 36, imagem 2 %32 iPhone SE 2022 Battery Replacement, Peel off the battery pull-tab: passo 36, imagem 3 %32
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire. If possible, use your fingernails or blunt tweezers. Only use pointed tweezers if you can't manage to peel off the adhesive with another tool.
    • Peel back the first battery adhesive tab from the bottom right edge of the battery.
  37. iPhone SE 2022 Battery Replacement, Remove the stretch-release adhesive: passo 37, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the stretch-release adhesive: passo 37, imagem 2 %32
    • Grab the first pull tab with your fingers or blunt nosed tweezers and slowly pull it away from the battery, toward the bottom of the iPhone.
    • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery. Hold the iPhone firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • Pull at a low angle so the strip doesn't snag on the edge of the battery.
    • The strip is less likely to tear if you use a combination of pulling and then reeling the strip around your tweezers. Slowly repeat this procedure until the strip is removed.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strips, and then proceed as instructed below.
  38. iPhone SE 2022 Battery Replacement: passo 38, imagem 1 %32 iPhone SE 2022 Battery Replacement: passo 38, imagem 2 %32 iPhone SE 2022 Battery Replacement: passo 38, imagem 3 %32
    • Grab the three other pull-tabs with your fingers or blunt nosed tweezers and pull them away from the battery, toward the bottom of the iPhone.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
  39. iPhone SE 2022 Battery Replacement, If the adhesive strips broke off: passo 39, imagem 1 %32 iPhone SE 2022 Battery Replacement, If the adhesive strips broke off: passo 39, imagem 2 %32 iPhone SE 2022 Battery Replacement, If the adhesive strips broke off: passo 39, imagem 3 %32
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use an opening pick or the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  40. iPhone SE 2022 Battery Replacement: passo 40, imagem 1 %32 iPhone SE 2022 Battery Replacement: passo 40, imagem 2 %32 iPhone SE 2022 Battery Replacement: passo 40, imagem 3 %32
    Plastic Cards
    $2.99
    • If you don't have any high concentration (over 90%) isopropyl alcohol at hand you can prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the stretch-release adhesive underneath the battery.
    • Insert a plastic card underneath the bottom edge of the battery.
    • Slide the plastic card along the edge of the battery to separate it from the rear case and to cut the adhesive.
    • Use your plastic card to carefully pry up the battery.
  41. iPhone SE 2022 Battery Replacement, Remove the battery: passo 41, imagem 1 %32 iPhone SE 2022 Battery Replacement, Remove the battery: passo 41, imagem 2 %32 iPhone SE 2022 Battery Replacement, Remove the battery: passo 41, imagem 3 %32
    • Remove the battery.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off with a coffee filter or lint-free cloth or allow it to air dry before installing your new battery.
    • If your new battery didn't come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
19 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
228.969 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
3 comentários
Caution: you'll get the Unknown Part message in Settings > Battery, even if you use a genuine part.
iFixIt has this documented at Apple can upgrade individual iPhone SE parts, can you?
Quoting the relevant section:
Installing a 3rd Gen iPhone SE 2022 battery in a 3rd Gen iPhone SE 2022: Possible, but…
This is the current standard, and a good sign for future battery replacements, but unfortunately you’ll still get the “unknown part” warning. The only feature you’ll lose is Battery Health. Yes even if you’re using a perfectly genuine battery, Apple considers the repairnongenuine” until they personally verify it.
Caveat: Apple will now let you pay for the privilege of verification, if you buy their part.
Colin Ng - Responder
Where can I get the replacement Battery? For the moment I only seem to find some for the SE 2020.
jenfab - Responder
Just did a battery replacement for somebody last night phone said 0% when I plugged it in. Used an iFixit battery. He left this morning and shortly after unplugging the phone it died plugged it back in works unplug it it dies. Battery is not charging, is this a defective battery or is this Apple anti-repair since they sell the same battery for 5 dollars less? (after you find the super secret code and return the old one, if not it's 75 $ just to place the order).
imark7777777 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 63
Últimos 7 dias: 555
Últimos 30 dias: 2,570
Duração total: 48,241
