Ir para o conteúdo principal
iPhone 7 Logic Board Replacement
O que você precisa
Vídeo de Apresentação
  1. iPhone 7 Logic Board Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Pergunte ao FixBot
    Comentar
  2. iPhone 7 Logic Board Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone 7 Logic Board Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone 7 Logic Board Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Pergunte ao FixBot
    Comentar
  3. iPhone 7 Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPhone 7 Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPhone 7 Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Pergunte ao FixBot
    Comentar
  4. iPhone 7 Logic Board Replacement: passo 4, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 4, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Pergunte ao FixBot
    Comentar
  5. iPhone 7 Logic Board Replacement: passo 5, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 5, imagem 2 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Pergunte ao FixBot
    Comentar
  6. iPhone 7 Logic Board Replacement, Heat the display: passo 6, imagem 1 %32
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    Pergunte ao FixBot
    Comentar
  7. iPhone 7 Logic Board Replacement, Separate the display: passo 7, imagem 1 %32 iPhone 7 Logic Board Replacement, Separate the display: passo 7, imagem 2 %32
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Pergunte ao FixBot
    Comentar
  8. iPhone 7 Logic Board Replacement: passo 8, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 8, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 8, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Pergunte ao FixBot
    Comentar
  9. iPhone 7 Logic Board Replacement: passo 9, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 9, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 9, imagem 3 %32
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    Pergunte ao FixBot
    Comentar
  10. iPhone 7 Logic Board Replacement, Screen information: passo 10, imagem 1 %32
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Pergunte ao FixBot
    Comentar
  11. iPhone 7 Logic Board Replacement: passo 11, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 11, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 11, imagem 3 %32
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Pergunte ao FixBot
    Comentar
  12. iPhone 7 Logic Board Replacement: passo 12, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 12, imagem 2 %32
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Pergunte ao FixBot
    Comentar
  13. iPhone 7 Logic Board Replacement: passo 13, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 13, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 13, imagem 3 %32
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    Pergunte ao FixBot
    Comentar
  14. iPhone 7 Logic Board Replacement: passo 14, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 14, imagem 2 %32
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Pergunte ao FixBot
    Comentar
  15. iPhone 7 Logic Board Replacement: passo 15, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 15, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 15, imagem 3 %32
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Pergunte ao FixBot
    Comentar
  16. iPhone 7 Logic Board Replacement, Battery Disconnection: passo 16, imagem 1 %32
    Tri-point Y000 Screwdriver
    $5.99
    Pergunte ao FixBot
    Comentar
  17. iPhone 7 Logic Board Replacement: passo 17, imagem 1 %32
    • Remove the lower connector bracket.
    Pergunte ao FixBot
    Comentar
  18. iPhone 7 Logic Board Replacement: passo 18, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 18, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 18, imagem 3 %32
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    Pergunte ao FixBot
    Comentar
  19. iPhone 7 Logic Board Replacement, Display Assembly: passo 19, imagem 1 %32 iPhone 7 Logic Board Replacement, Display Assembly: passo 19, imagem 2 %32 iPhone 7 Logic Board Replacement, Display Assembly: passo 19, imagem 3 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    Pergunte ao FixBot
    Comentar
  20. iPhone 7 Logic Board Replacement: passo 20, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 20, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 20, imagem 3 %32
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
    Pergunte ao FixBot
    Comentar
  21. iPhone 7 Logic Board Replacement: passo 21, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 21, imagem 2 %32
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Pergunte ao FixBot
    Comentar
  22. iPhone 7 Logic Board Replacement: passo 22, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  23. iPhone 7 Logic Board Replacement, SIM Card: passo 23, imagem 1 %32 iPhone 7 Logic Board Replacement, SIM Card: passo 23, imagem 2 %32 iPhone 7 Logic Board Replacement, SIM Card: passo 23, imagem 3 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Pergunte ao FixBot
    Comentar
  24. iPhone 7 Logic Board Replacement, Logic Board Connectors: passo 24, imagem 1 %32 iPhone 7 Logic Board Replacement, Logic Board Connectors: passo 24, imagem 2 %32
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
    Pergunte ao FixBot
    Comentar
  25. iPhone 7 Logic Board Replacement: passo 25, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 25, imagem 2 %32
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
    Pergunte ao FixBot
    Comentar
  26. iPhone 7 Logic Board Replacement: passo 26, imagem 1 %32
    • Remove the bracket.
    Pergunte ao FixBot
    Comentar
  27. iPhone 7 Logic Board Replacement: passo 27, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 27, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
    Pergunte ao FixBot
    Comentar
  28. iPhone 7 Logic Board Replacement: passo 28, imagem 1 %32
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
    Pergunte ao FixBot
    Comentar
  29. iPhone 7 Logic Board Replacement: passo 29, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 29, imagem 2 %32
    • Remove the upper cable bracket.
    Pergunte ao FixBot
    Comentar
  30. iPhone 7 Logic Board Replacement: passo 30, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 30, imagem 2 %32
    • Use the flat end of a spudger to disconnect the upper cable connector.
    Pergunte ao FixBot
    Comentar
  31. iPhone 7 Logic Board Replacement: passo 31, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 31, imagem 2 %32
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    Pergunte ao FixBot
    Comentar
  32. iPhone 7 Logic Board Replacement: passo 32, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 32, imagem 2 %32
    • Remove the top left antenna.
    Pergunte ao FixBot
    Comentar
  33. iPhone 7 Logic Board Replacement: passo 33, imagem 1 %32
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
    Pergunte ao FixBot
    Comentar
  34. iPhone 7 Logic Board Replacement: passo 34, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 34, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  35. iPhone 7 Logic Board Replacement: passo 35, imagem 1 %32
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Pergunte ao FixBot
    Comentar
  36. iPhone 7 Logic Board Replacement: passo 36, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 36, imagem 2 %32
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
    Pergunte ao FixBot
    Comentar
  37. iPhone 7 Logic Board Replacement, Logic Board: passo 37, imagem 1 %32 iPhone 7 Logic Board Replacement, Logic Board: passo 37, imagem 2 %32 iPhone 7 Logic Board Replacement, Logic Board: passo 37, imagem 3 %32
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    Pergunte ao FixBot
    Comentar
  38. iPhone 7 Logic Board Replacement: passo 38, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 38, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 38, imagem 3 %32
    • Use tweezers to gently derout the antenna cables from the metal bracket on the logic board.
    Pergunte ao FixBot
    Comentar
  39. iPhone 7 Logic Board Replacement: passo 39, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 39, imagem 2 %32
    • Use the point of a spudger to disconnect the lower cable connector.
    Pergunte ao FixBot
    Comentar
  40. iPhone 7 Logic Board Replacement: passo 40, imagem 1 %32
    $5.49
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    • Standoff screws are best removed using a standoff driver.
    Pergunte ao FixBot
    Comentar
  41. iPhone 7 Logic Board Replacement: passo 41, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 41, imagem 2 %32
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    Pergunte ao FixBot
    Comentar
  42. iPhone 7 Logic Board Replacement: passo 42, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 42, imagem 2 %32
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
    Pergunte ao FixBot
    Comentar
  43. iPhone 7 Logic Board Replacement: passo 43, imagem 1 %32 iPhone 7 Logic Board Replacement: passo 43, imagem 2 %32 iPhone 7 Logic Board Replacement: passo 43, imagem 3 %32
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
    Pergunte ao FixBot
    Comentar
Conclusão
167 outras pessoas executaram este guia.
Evan Noronha
Membro desde: 02/05/15
229.544 Reputação
Autoria de 168 guias
14Comentários do guia
I had an accident where my iphone has got some damage (cracked screen, metal frame slightly bent).. I can see a lot of iCloud locked devices for sale, some of them for a cheap price. Would replacing the logic board and home button give me a non-damaged working phone? Or what parts would need to be moved for this? Sure I can buy a brand new phone but I like a bit of a challenge :)
Steve - Responder Compartilhar
the logic board holds the OS, so yes if you were to replace the mother board of the iPhone it should work like a new phone but without touch id
Vegas Uprising - Responder Compartilhar
I have the same idea and i found to buy this one
https://www.aliexpress.com/item/For-iPho...
You think it will work?
alexandros papadopoulos - Responder Compartilhar
Hi,
I’ve got a problem with my iphone7. I just took some videos under the water using my iphone. But later it’s finger id has gone and it’s fully damaged. Now the phone is not working. Is there any option to repair this ….?
muhammed faisal - Responder Compartilhar
Hi Muhammed, sounds like some water got inside your phone. Check out our iPhone liquid damage guide for some basic troubleshooting you can do on your own. When you have the phone open check connectors and pins on the board for any corrosion. If the damage is serious enough that cleaning won’t fix it, you can take your phone to a local repair shop for more extensive repairs.
Adam O'Camb - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 21
Últimos 7 dias: 128
Últimos 30 dias: 472
Ao todo: 292,651
