Ir para o conteúdo principal
iPhone 6s LCD and Digitizer Replacement
O que você precisa
  1. iPhone 6s LCD and Digitizer Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
  2. iPhone 6s LCD and Digitizer Replacement, Tape over the display: passo 2, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement, Tape over the display: passo 2, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement, Tape over the display: passo 2, imagem 3 %32
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  3. iPhone 6s LCD and Digitizer Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 6s LCD and Digitizer Replacement: passo 4, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 4, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  5. iPhone 6s LCD and Digitizer Replacement, Opening Procedure: passo 5, imagem 1 %32
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  6. iPhone 6s LCD and Digitizer Replacement: passo 6, imagem 1 %32
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  7. iPhone 6s LCD and Digitizer Replacement: passo 7, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 7, imagem 2 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
  8. iPhone 6s LCD and Digitizer Replacement: passo 8, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 8, imagem 2 %32
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
  9. iPhone 6s LCD and Digitizer Replacement: passo 9, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 9, imagem 2 %32
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
  10. iPhone 6s LCD and Digitizer Replacement: passo 10, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 10, imagem 2 %32
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
  11. iPhone 6s LCD and Digitizer Replacement: passo 11, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 11, imagem 2 %32
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
  12. iPhone 6s LCD and Digitizer Replacement: passo 12, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 12, imagem 2 %32
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
  13. iPhone 6s LCD and Digitizer Replacement: passo 13, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 13, imagem 2 %32
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
  14. iPhone 6s LCD and Digitizer Replacement: passo 14, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 14, imagem 2 %32
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
  15. iPhone 6s LCD and Digitizer Replacement: passo 15, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 15, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement: passo 15, imagem 3 %32
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • During reassembly, pause here if you wish to replace the adhesive around the edges of the display.
    • During reassembly, the camera end of the screen body needs to hook under the edge of the body. The hooks of the screen frame need to be under the rim of the main body and snugged toward the camera end to easily close the cover and have it properly clip.
    • These hooks are not really a proper hinge but clasps that need to be under the rim of the main phone frame/edge!! This way the screen easily will return to its closed state nicely gently snapping into place.
    • During reassembly, reverse order for getting the screen clipped back in means pressing along the right side top to bottom corner. Then the left.
  16. iPhone 6s LCD and Digitizer Replacement, Battery Connector: passo 16, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  17. iPhone 6s LCD and Digitizer Replacement: passo 17, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 17, imagem 2 %32
    • Remove the battery connector bracket from the iPhone.
  18. iPhone 6s LCD and Digitizer Replacement: passo 18, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 18, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement: passo 18, imagem 3 %32
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  19. iPhone 6s LCD and Digitizer Replacement: passo 19, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 19, imagem 2 %32
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
  20. iPhone 6s LCD and Digitizer Replacement, Unfasten the display cable bracket: passo 20, imagem 1 %32
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
  21. iPhone 6s LCD and Digitizer Replacement: passo 21, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 21, imagem 2 %32
    • Remove the display cable bracket.
  22. iPhone 6s LCD and Digitizer Replacement: passo 22, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 22, imagem 2 %32
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
  23. iPhone 6s LCD and Digitizer Replacement: passo 23, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 23, imagem 2 %32
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  24. iPhone 6s LCD and Digitizer Replacement: passo 24, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 24, imagem 2 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
  25. iPhone 6s LCD and Digitizer Replacement: passo 25, imagem 1 %32
  26. iPhone 6s LCD and Digitizer Replacement, Home Button Assembly: passo 26, imagem 1 %32
    • Remove the three 1.7 mm Phillips screws securing the home button bracket.
    • Do not over-tighten these screws as these can damage the front of the display.
  27. iPhone 6s LCD and Digitizer Replacement: passo 27, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 27, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement: passo 27, imagem 3 %32
    • Lift the lower edge of the home button bracket until it clears the small peg on the right side.
    • Slide the bracket out from under the EMI shield to remove it.
  28. iPhone 6s LCD and Digitizer Replacement: passo 28, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 28, imagem 2 %32
    • Use a spudger to disconnect the home button connector by popping it out of its socket on the back of the display panel.
  29. iPhone 6s LCD and Digitizer Replacement: passo 29, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 29, imagem 2 %32
    iOpener
    $24.99
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
  30. iPhone 6s LCD and Digitizer Replacement: passo 30, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 30, imagem 2 %32
    • Use the pointed tip of a spudger to carefully separate the home button flex cable from the back of the display panel.
  31. iPhone 6s LCD and Digitizer Replacement: passo 31, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 31, imagem 2 %32
    • Remove the home button assembly.
  32. iPhone 6s LCD and Digitizer Replacement, Earpiece Speaker: passo 32, imagem 1 %32
    • Remove the following three Phillips screws securing the earpiece speaker bracket:
    • Two 2.3 mm screws
    • One 1.9 mm screw
  33. iPhone 6s LCD and Digitizer Replacement: passo 33, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 33, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement: passo 33, imagem 3 %32
    • Lift up and remove the earpiece speaker bracket, peeling up the bracket gasket as you go.
    • Peel up the gasket carefully, as it is thin and can tear easily.
  34. iPhone 6s LCD and Digitizer Replacement: passo 34, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 34, imagem 2 %32
    • Use the flat end of a spudger to nudge the front-facing camera from its housing.
  35. iPhone 6s LCD and Digitizer Replacement: passo 35, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 35, imagem 2 %32
    • Pull back the front-facing camera to access the earpiece speaker.
    • Remove the earpiece speaker.
    • Be careful not to touch the golden contacts as you remove and replace the speaker. Oil from your skin can interfere with the contacts and interrupt the connection. If you accidentally touch them with your skin, wipe them off with a little isopropyl alcohol (rubbing alcohol) before reinstalling them.
  36. iPhone 6s LCD and Digitizer Replacement, Front-Facing Camera and Sensor Assembly: passo 36, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement, Front-Facing Camera and Sensor Assembly: passo 36, imagem 2 %32
    • Holding the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel.
  37. iPhone 6s LCD and Digitizer Replacement: passo 37, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 37, imagem 2 %32
    • Fold the front-facing camera and sensor cable up to allow access to the microphone.
  38. iPhone 6s LCD and Digitizer Replacement: passo 38, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 38, imagem 2 %32
    • Use the flat end of a spudger to gently break up the adhesive securing the microphone to the front panel.
  39. iPhone 6s LCD and Digitizer Replacement: passo 39, imagem 1 %32
    • Remove the front-facing camera and sensor cable.
  40. iPhone 6s LCD and Digitizer Replacement, Display EMI Shield: passo 40, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement, Display EMI Shield: passo 40, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement, Display EMI Shield: passo 40, imagem 3 %32
    • Remove the following seven 1.3 mm Phillips screws:
    • Three screws each on the left and right edges of the display panel.
    • A single screw recessed 1.5 cm from the right edge of the screen.
  41. iPhone 6s LCD and Digitizer Replacement: passo 41, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 41, imagem 2 %32 iPhone 6s LCD and Digitizer Replacement: passo 41, imagem 3 %32
    • Prepare an iOpener and lay it over the top edge of the phone to loosen the tape connecting the EMI shield to the front panel.
    • After a minute, insert an opening pick between the tape and display data cable.
    • Push the pick downwards until it is flush with the upper edge of the EMI shield.
  42. iPhone 6s LCD and Digitizer Replacement: passo 42, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 42, imagem 2 %32
    • Use a pair of tweezers to peel up the piece of tape from the EMI shield, near the front camera housing.
  43. iPhone 6s LCD and Digitizer Replacement: passo 43, imagem 1 %32 iPhone 6s LCD and Digitizer Replacement: passo 43, imagem 2 %32
    • Remove the EMI shield.
    • When installing the EMI shield, orient it so that the metal cutout (shown at bottom center) lays over the top of the display cable assembly, while the piece of tape slides behind it.
  44. iPhone 6s LCD and Digitizer Replacement, LCD and Digitizer: passo 44, imagem 1 %32
    • Only the LCD and digitizer remains.
Conclusão
473 outras pessoas executaram este guia.
Evan Noronha
Membro desde: 02/05/15
228.114 Reputação
Autoria de 168 guias
50Comentários do guia
Swapping out the home button/main board flex cable on the iPhone 6 disabled TouchID. I assume it was also digitally signed like the home button. Is this also true of the 3D Touch panel now that it supplies that cable? In short, Is the original 3D Touch panel necessary for TouchID to work or will the replacement 3D Touch panel built into the replacement work?
Joe - Responder
I've had touchID work after replacing the flex cable... I cant imagine there would be a problem with it this year...
Andrew -
Does the 6S need the home button flex cable to be moved for touch ID to work like the 6?
John Pampalone - Responder
Nope! The home button flex cable is integrated into the display and cannot be transferred to the new one.
Evan Noronha -
And then on the Iphone 6s the original flex cable hasn't to be moved. Only the button itself because it is paired with the CPU.
revher -
Comentar
Visualizações:
Últimas 24 horas: 75
Últimos 7 dias: 322
Últimos 30 dias: 719
Ao todo: 373,414
