Ir para o conteúdo principal
iPhone 5c Rear Case Replacement
O que você precisa
    1. iPhone 5c Rear Case Replacement, Taping the display glass: passo 1, imagem 1 %32 iPhone 5c Rear Case Replacement, Taping the display glass: passo 1, imagem 2 %32 iPhone 5c Rear Case Replacement, Taping the display glass: passo 1, imagem 3 %32
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Pergunte ao FixBot
      Comentar
    2. iPhone 5c Rear Case Replacement, Removing the Pentalobe screws: passo 2, imagem 1 %32
      • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
      Pergunte ao FixBot
      Comentar
    3. iPhone 5c Rear Case Replacement, Starting the iSclack Opening Procedure: passo 3, imagem 1 %32 iPhone 5c Rear Case Replacement, Starting the iSclack Opening Procedure: passo 3, imagem 2 %32 iPhone 5c Rear Case Replacement, Starting the iSclack Opening Procedure: passo 3, imagem 3 %32
      • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5c that we recommend for anyone doing more than one repair on an iPhone 5, 5s, or 5c. If you aren't using the iSclack, skip to Step 5.
      • Close the handle on the iSclack, opening the suction-cup jaws.
      • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
      • The top suction cup should rest just above the home button.
      • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
      Pergunte ao FixBot
      Comentar
    4. iPhone 5c Rear Case Replacement, Finishing the iSclack Opening Procedure: passo 4, imagem 1 %32 iPhone 5c Rear Case Replacement, Finishing the iSclack Opening Procedure: passo 4, imagem 2 %32
      • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
      • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
      • Peel the two suction cups off your iPhone.
      • Skip the next three steps and continue on to Step 8.
      Pergunte ao FixBot
      Comentar
    5. iPhone 5c Rear Case Replacement, Manual Opening Procedure: passo 5, imagem 1 %32
      • Press a suction cup onto the screen, just above the home button.
      • Be sure the cup is completely on the screen to get a tight seal.
      Pergunte ao FixBot
      Comentar
    6. iPhone 5c Rear Case Replacement, Start lifting the front panel assembly: passo 6, imagem 1 %32 iPhone 5c Rear Case Replacement, Start lifting the front panel assembly: passo 6, imagem 2 %32
      • Make sure the suction cup is firmly attached to the front panel assembly.
      • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
      • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
      • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
      • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
      Pergunte ao FixBot
      Comentar
    7. iPhone 5c Rear Case Replacement: passo 7, imagem 1 %32
      • Pull the plastic nub to release the vacuum seal on the suction cup.
      • Remove the suction cup from the display assembly.
      Pergunte ao FixBot
      Comentar
    8. iPhone 5c Rear Case Replacement, Opening up the phone: passo 8, imagem 1 %32 iPhone 5c Rear Case Replacement, Opening up the phone: passo 8, imagem 2 %32
      • Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
      • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
      • In a pinch, you can use an unopened canned beverage to hold the display.
      • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
      Pergunte ao FixBot
      Comentar
    9. iPhone 5c Rear Case Replacement: passo 9, imagem 1 %32
      • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
      Pergunte ao FixBot
      Comentar
    10. iPhone 5c Rear Case Replacement: passo 10, imagem 1 %32
      • Remove the metal battery connector bracket from the iPhone.
      Pergunte ao FixBot
      Comentar
    11. iPhone 5c Rear Case Replacement, Disconnecting the battery connector: passo 11, imagem 1 %32
      • Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
      • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
      Pergunte ao FixBot
      Comentar
    12. iPhone 5c Rear Case Replacement: passo 12, imagem 1 %32
      • Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
      • Two 1.3 mm screws
      • One 1.7 mm screw
      • One 3.25 mm screw
      • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 3.25 mm screw or the 1.7 mm screw in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
      • Be careful not to over-tighten the screws. If they don't fit easily when you are securing them, they may be the wrong size—don't force them.
      Pergunte ao FixBot
      Comentar
    13. iPhone 5c Rear Case Replacement: passo 13, imagem 1 %32
      • Remove the front panel assembly cable bracket from the logic board.
      Pergunte ao FixBot
      Comentar
    14. iPhone 5c Rear Case Replacement, Disconnecting the front panel assembly cables: passo 14, imagem 1 %32 iPhone 5c Rear Case Replacement, Disconnecting the front panel assembly cables: passo 14, imagem 2 %32
      • Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
      • Be sure to only pry up on the connector, and not on the socket on the logic board.
      Pergunte ao FixBot
      Comentar
    15. iPhone 5c Rear Case Replacement: passo 15, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 15, imagem 2 %32 iPhone 5c Rear Case Replacement: passo 15, imagem 3 %32
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
      • The LCD and Digitizer connectors are on the same cable assembly, so prying the LCD connector up should disconnect both connectors. Double check that the two cables are fully disconnected before removing the display.
      • When reassembling your phone, the LCD cable may pop off its connector. A blank screen, or white lines on the display could be caused by a loose connection. Should this happen, reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
      Pergunte ao FixBot
      Comentar
    16. iPhone 5c Rear Case Replacement, Separating front panel assembly and rear case: passo 16, imagem 1 %32
      • Remove the front panel assembly from the rear case.
      Pergunte ao FixBot
      Comentar
    1. iPhone 5c Rear Case Replacement, SIM Card: passo 17, imagem 1 %32 iPhone 5c Rear Case Replacement, SIM Card: passo 17, imagem 2 %32
      • Shut your phone down completely before removing the SIM card and tray.
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
      • Press the SIM card eject tool inwards to eject the tray.
      • This may require a significant amount of force.
      Pergunte ao FixBot
      Comentar
    2. iPhone 5c Rear Case Replacement: passo 18, imagem 1 %32
      • Remove the SIM Card tray assembly from the iPhone.
      • During reassembly, ensure that the SIM card is in the proper orientation relative to the tray.
      Pergunte ao FixBot
      Comentar
    1. iPhone 5c Rear Case Replacement, SIM Ejector: passo 19, imagem 1 %32
      • Remove the 2.0 mm Phillips #000 screw securing the SIM ejector.
      Pergunte ao FixBot
      Comentar
    2. iPhone 5c Rear Case Replacement: passo 20, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use a set of tweezers to remove the SIM ejector from the phone.
      • Note the orientation for reassembly: the raised portion of the ejector should be closest to the bottom of the phone.
      Pergunte ao FixBot
      Comentar
    1. iPhone 5c Rear Case Replacement, Battery: passo 21, imagem 1 %32 iPhone 5c Rear Case Replacement, Battery: passo 21, imagem 2 %32 iPhone 5c Rear Case Replacement, Battery: passo 21, imagem 3 %32
      • Run the tip of a spudger between the battery and the headphone jack to unfold the battery adhesive tab.
      Pergunte ao FixBot
      Comentar
    2. iPhone 5c Rear Case Replacement: passo 22, imagem 1 %32
      • Pull the battery adhesive tab away from the phone.
      Pergunte ao FixBot
      Comentar
    3. iPhone 5c Rear Case Replacement: passo 23, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 23, imagem 2 %32
      • Cut the black battery adhesive tab between the two white adhesive strips, separating them.
      Pergunte ao FixBot
      Comentar
    4. iPhone 5c Rear Case Replacement: passo 24, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 24, imagem 2 %32
      • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
      • Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone.
      • Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
      • Guide the strip carefully around the corner and up the side of the battery. Be careful not to snag it on any of the other internal iPhone components.
      • The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
      Pergunte ao FixBot
      Comentar
    5. iPhone 5c Rear Case Replacement: passo 25, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 25, imagem 2 %32
      • Repeat to remove the second strip.
      Pergunte ao FixBot
      Comentar
    6. iPhone 5c Rear Case Replacement: passo 26, imagem 1 %32
      • Remove the battery from your iPhone.
      • If one, or both, of the adhesive strips tears, and you are unable to retrieve it with a set of tweezers, do not pry the battery out of the phone. Continue on to the next steps to safely remove your battery.
      Pergunte ao FixBot
      Comentar
    7. iPhone 5c Rear Case Replacement, Battery removal with latent adhesive: passo 27, imagem 1 %32 iPhone 5c Rear Case Replacement, Battery removal with latent adhesive: passo 27, imagem 2 %32
      Plastic Cards
      $2.99
      • Apply a few drops of isopropyl alcohol (90% or greater) under the battery and let it flow around the adhesive to help weaken it. High concentration isopropyl alcohol acts as a solvent and dries without leaving any residue, so it will not hurt your iPhone.
      • Carefully wedge a plastic card under the battery on the side nearest the logic board.
      • Do not pry against the logic board or you may damage the phone.
      • Avoid prying near the top edge of the battery, or you may damage the upper component ribbon cable.
      • Slide the card from the top of the battery to the bottom, pushing toward the edge of the case.
      • If necessary, repeat the same procedure with the case side of the battery.
      Pergunte ao FixBot
      Comentar
    8. iPhone 5c Rear Case Replacement: passo 28, imagem 1 %32
      • If the battery is still stuck to the case, follow our iOpener heating instructions or use a hair dryer to heat the adhesive securing your battery to the rear case.
      • Lay the iOpener flat on the backside of the iPhone to the right of the camera. Smooth it out so that there is good contact between the back of the iPhone and the iOpener.
      • Let the bag sit on the iPhone for approximately 90 seconds before attempting to remove the battery.
      • If using a hair dryer or heat gun, heat the back of the iPhone until it's slightly too hot to touch.
      • Do not apply heat directly to the battery.
      • Overheating the iPhone may ignite the battery.
      Pergunte ao FixBot
      Comentar
    9. iPhone 5c Rear Case Replacement: passo 29, imagem 1 %32
      • Lift and remove the battery from the iPhone.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
      • There should be no resistance. If the battery remains stuck, reheat the iOpener and pry again.
      • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
      • Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
      • Adhere the battery, disconnect it, and continue reassembling your device.
      • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
      • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
      Pergunte ao FixBot
      Comentar
    1. iPhone 5c Rear Case Replacement, Lightning Connector Assembly: passo 30, imagem 1 %32 iPhone 5c Rear Case Replacement, Lightning Connector Assembly: passo 30, imagem 2 %32
      • Use a plastic opening tool to peel the home button spring contact cable up from the speaker enclosure.
      Pergunte ao FixBot
      Comentar
    2. iPhone 5c Rear Case Replacement: passo 31, imagem 1 %32
      • Remove the following screws securing the speaker enclosure to the rear case:
      • Two 2.7 mm Phillips #000 screws
      • One 2.2 mm Phillips #000 screw
      Pergunte ao FixBot
      Comentar
    3. iPhone 5c Rear Case Replacement: passo 32, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 32, imagem 2 %32
      • Use the flat end of a spudger to gently pry the speaker enclosure up from the rear case.
      Pergunte ao FixBot
      Comentar
    4. iPhone 5c Rear Case Replacement: passo 33, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 33, imagem 2 %32
      • Remove the speaker enclosure. Be careful not to snag it on the antenna cable.
      Pergunte ao FixBot
      Comentar
    5. iPhone 5c Rear Case Replacement: passo 34, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 34, imagem 2 %32
      • The far right screw hole on the speaker has a contact bracket wrapped around it. This small part may fall off unexpectedly, so it's best to remove it and note the orientation for reassembly.
      • The flat portion of the contact clip should rest against the speaker, as shown.
      • The alignment bracket on the far end of the speaker assembly is adhered, but may fall off if handled aggressively.
      • The angled end should face up and line up with the outside edge of the speaker.
      Pergunte ao FixBot
      Comentar
    6. iPhone 5c Rear Case Replacement: passo 35, imagem 1 %32
      • Use a plastic opening tool to disconnect the Lightning connector ribbon cable from its socket on the logic board.
      Pergunte ao FixBot
      Comentar
    7. iPhone 5c Rear Case Replacement: passo 36, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 36, imagem 2 %32
      • The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
      Pergunte ao FixBot
      Comentar
    8. iPhone 5c Rear Case Replacement: passo 37, imagem 1 %32
      • Disconnect the cellular antenna connector from the base of the logic board.
      Pergunte ao FixBot
      Comentar
    9. iPhone 5c Rear Case Replacement: passo 38, imagem 1 %32
      • Remove the following screws securing the Lightning connector to the rear case:
      • Two 3.4 mm Phillips #000 screws
      • One 2.7 mm Phillips #000 screw
      Pergunte ao FixBot
      Comentar
    10. iPhone 5c Rear Case Replacement: passo 39, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 39, imagem 2 %32
      • Gently peel the Lightning connector assembly up from the rear case.
      Pergunte ao FixBot
      Comentar
    11. iPhone 5c Rear Case Replacement: passo 40, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 40, imagem 2 %32
      • You may need to use the flat end of a spudger to completely free the assembly.
      Pergunte ao FixBot
      Comentar
    12. iPhone 5c Rear Case Replacement: passo 41, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 41, imagem 2 %32
      • Remove the Lightning connector assembly.
      • There is a small rubber gasket attached to the microphone. Be sure to transfer it to the new assembly.
      Pergunte ao FixBot
      Comentar
    1. iPhone 5c Rear Case Replacement, Logic Board: passo 42, imagem 1 %32 iPhone 5c Rear Case Replacement, Logic Board: passo 42, imagem 2 %32
      • Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
      • Disconnect the rear facing camera cable connector from its socket on the logic board.
      Pergunte ao FixBot
      Comentar
    2. iPhone 5c Rear Case Replacement: passo 43, imagem 1 %32
      • A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
      Pergunte ao FixBot
      Comentar
    3. iPhone 5c Rear Case Replacement: passo 44, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 44, imagem 2 %32
      • Remove the following screws securing the logic board grounding clip to the rear case:
      • 1.2 mm Phillips #000 in the top side-wall
      • 2.5 mm Phillips #000
      Pergunte ao FixBot
      Comentar
    4. iPhone 5c Rear Case Replacement: passo 45, imagem 1 %32
      • Use tweezers to remove the logic board grounding clip.
      Pergunte ao FixBot
      Comentar
    5. iPhone 5c Rear Case Replacement: passo 46, imagem 1 %32
      Standoff Screwdriver for iPhones
      $5.49
      • Remove the following screws securing the logic board to the rear case:
      • Two 2.3 mm Phillips screws
      • Three 2.7 mm standoff screws
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Pergunte ao FixBot
      Comentar
    6. iPhone 5c Rear Case Replacement: passo 47, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 47, imagem 2 %32 iPhone 5c Rear Case Replacement: passo 47, imagem 3 %32
      • Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
      • Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
      • Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
      Pergunte ao FixBot
      Comentar
    7. iPhone 5c Rear Case Replacement: passo 48, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 48, imagem 2 %32
      • Flip the logic board up toward the volume control buttons to expose the antenna connector.
      • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
      Pergunte ao FixBot
      Comentar
    8. iPhone 5c Rear Case Replacement: passo 49, imagem 1 %32
      • Disconnect the antenna connector from the back of the logic board.
      Pergunte ao FixBot
      Comentar
    9. iPhone 5c Rear Case Replacement: passo 50, imagem 1 %32
      • Remove the logic board from the rear case.
      Pergunte ao FixBot
      Comentar
    1. iPhone 5c Rear Case Replacement, Audio Control and Power Button Cable: passo 51, imagem 1 %32
      • Remove the two 1.5 mm Phillips #000 screws securing the rear camera cover to the rear case.
      Pergunte ao FixBot
      Comentar
    2. iPhone 5c Rear Case Replacement: passo 52, imagem 1 %32
      • Remove the rear facing camera cover.
      Pergunte ao FixBot
      Comentar
    3. iPhone 5c Rear Case Replacement: passo 53, imagem 1 %32
      • Remove the rear facing camera.
      Pergunte ao FixBot
      Comentar
    4. iPhone 5c Rear Case Replacement: passo 54, imagem 1 %32
      • Remove the following screws securing the vibrator motor to the rear case:
      • 2.2 mm Phillips #000
      Pergunte ao FixBot
      Comentar
    5. iPhone 5c Rear Case Replacement: passo 55, imagem 1 %32
      • Remove the vibrator motor.
      Pergunte ao FixBot
      Comentar
    6. iPhone 5c Rear Case Replacement: passo 56, imagem 1 %32
      • Remove the following screws securing the upper assembly contact bracket to the rear case:
      • 3.0 mm standoff screw
      • 1.5 mm Phillips #000 screw
      Pergunte ao FixBot
      Comentar
    7. iPhone 5c Rear Case Replacement: passo 57, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 57, imagem 2 %32
      • Remove the upper assembly contact bracket from the rear case.
      • A small rubber bumper may fall off the top of the bracket—take care not to lose it.
      Pergunte ao FixBot
      Comentar
    8. iPhone 5c Rear Case Replacement: passo 58, imagem 1 %32
      • Remove any foam tape obscuring the screws near the camera cavity.
      Pergunte ao FixBot
      Comentar
    9. iPhone 5c Rear Case Replacement: passo 59, imagem 1 %32
      • Remove the two 1.4 mm Phillips #000 screws securing the power/sleep button bracket.
      Pergunte ao FixBot
      Comentar
    10. iPhone 5c Rear Case Replacement: passo 60, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 60, imagem 2 %32 iPhone 5c Rear Case Replacement: passo 60, imagem 3 %32
      • Use the pointed end of a spudger to gently fold the power/sleep button bracket down from the top of the rear case.
      • Use tweezers to grab and remove the button.
      • For reassembly, note the orientation—the metal bar should be flush with the bottom of the button.
      • If you can't get a hold on the power button from inside the case, use a spudger to slightly push it in from the outside.
      Pergunte ao FixBot
      Comentar
    11. iPhone 5c Rear Case Replacement: passo 61, imagem 1 %32
      • Remove the two 1.6 mm Phillips #000 screws from the mute/silent switch bracket.
      Pergunte ao FixBot
      Comentar
    12. iPhone 5c Rear Case Replacement: passo 62, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 62, imagem 2 %32
      • Remove this mute/silent switch bracket clip and set it aside.
      • During reassembly, the bracket clip goes over the mute/silent switch bracket. Ensure the angled portion is to the right.
      • Use the tip of a spudger to flip the mute/silent switch bracket down.
      Pergunte ao FixBot
      Comentar
    13. iPhone 5c Rear Case Replacement: passo 63, imagem 1 %32
      • Use tweezers to remove the mute/silent switch.
      • Note the orientation for reassembly: The red line should be at the top of the button. The notch in the back of the switch should be in the same position as, and mate with, the mechanical switch on the cable.
      Pergunte ao FixBot
      Comentar
    14. iPhone 5c Rear Case Replacement: passo 64, imagem 1 %32
      • Remove the 1.6 mm Phillips #000 screw securing the volume rocker bracket to the side wall.
      Pergunte ao FixBot
      Comentar
    15. iPhone 5c Rear Case Replacement: passo 65, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 65, imagem 2 %32
      • Use the tip of a spudger to fold the volume rocker bracket down from the side wall. Remove the volume rocker.
      Pergunte ao FixBot
      Comentar
    16. iPhone 5c Rear Case Replacement: passo 66, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 66, imagem 2 %32
      • Use the tip of a spudger to peel the power/sleep button cable off of the rear case.
      Pergunte ao FixBot
      Comentar
    17. iPhone 5c Rear Case Replacement: passo 67, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 67, imagem 2 %32
      • Run a spudger gently under the flash assembly cable to separate it from the phone.
      Pergunte ao FixBot
      Comentar
    18. iPhone 5c Rear Case Replacement: passo 68, imagem 1 %32 iPhone 5c Rear Case Replacement: passo 68, imagem 2 %32
      • Peel the upper assembly cable up from right to left to separate the adhesive holding it to the case.
      Pergunte ao FixBot
      Comentar
    19. iPhone 5c Rear Case Replacement: passo 69, imagem 1 %32
      • Take extra care in peeling the vibrator contact end of the cable off of the phone.
      • Do not touch the contacts; finger oils can corrode the metal and prevent a solid connection.
      • You can now remove the assembly from the phone.
      Pergunte ao FixBot
      Comentar
Conclusão
45 outras pessoas executaram este guia.
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 86.243 guias
3Comentários do guia
crucial information is missing:
when removing the lightning connector module, not only the black "rubber gasket" attached to the microphone needs to be carefully transfered to the new rear case, but also
-the rectangular black plastic microphone filter with the small cylindrical extrusion, which is stuck to the case
-the grid/foam frame protecting the speaker, which is also glued to the case
-the 2 gold connector rings around the screw holes on the upper black plastic part at the bottom of the case.
-the metal piece remotely similar to a "bone" shape, two rings connected by a longer part, stuck to the lower black plastic part at the bottom of the case.
-in general the 4 metal parts screwed to the side of the case, functioning as snap-locks for the front display. (3x with 2 snap lock elements, 1x with only 1, next to the volume rocker
-the black ring round the hole where the wifi/bluetooth antenna goes, underneath the vibration motor.
depending on the case you're getting, all of these need to be transfered.
David - Responder Compartilhar
Also the transfer of the WiFi/Bluetooth antenna is completely missing. In my case the antenna to logic board connector cable broke, so i had to replace it
where is this located Apple Part Number: 821-1769
I replaced old back body with the new one and when I finished this part was still on my desk and gps doesn't get signal anymore :)
Fiiu - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 27
Últimos 30 dias: 131
Ao todo: 125,056
