Ir para o conteúdo principal
iPhone 13 Pro Rear-Facing Camera Replacement
O que você precisa
  1. iPhone 13 Pro Rear-Facing Camera Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 Pro Rear-Facing Camera Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 13 Pro Rear-Facing Camera Replacement, Tape over any cracks: passo 3, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Tape over any cracks: passo 3, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Tape over any cracks: passo 3, imagem 3 %32
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 13 Pro Rear-Facing Camera Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 13 Pro Rear-Facing Camera Replacement: passo 5, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement: passo 5, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 Pro Rear-Facing Camera Replacement: passo 6, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement: passo 6, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement: passo 6, imagem 3 %32
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone 13 Pro Rear-Facing Camera Replacement, Heat the bottom edge: passo 7, imagem 1 %32
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 Pro Rear-Facing Camera Replacement, Insert an opening pick: passo 8, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Insert an opening pick: passo 8, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Insert an opening pick: passo 8, imagem 3 %32
    • Apply a suction handle to the bottom edge of the phone, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 13 Pro Rear-Facing Camera Replacement, Heat the right edge: passo 9, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Heat the right edge: passo 9, imagem 2 %32
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  10. iPhone 13 Pro Rear-Facing Camera Replacement, Separate the right adhesive: passo 10, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Separate the right adhesive: passo 10, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Separate the right adhesive: passo 10, imagem 3 %32
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  11. iPhone 13 Pro Rear-Facing Camera Replacement, Heat the top edge: passo 11, imagem 1 %32
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  12. iPhone 13 Pro Rear-Facing Camera Replacement, Separate the top adhesive: passo 12, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Separate the top adhesive: passo 12, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Separate the top adhesive: passo 12, imagem 3 %32
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  13. iPhone 13 Pro Rear-Facing Camera Replacement, Heat the left edge: passo 13, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Heat the left edge: passo 13, imagem 2 %32
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  14. iPhone 13 Pro Rear-Facing Camera Replacement, Screen information: passo 14, imagem 1 %32
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  15. iPhone 13 Pro Rear-Facing Camera Replacement, Separate the left adhesive: passo 15, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Separate the left adhesive: passo 15, imagem 2 %32
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  16. iPhone 13 Pro Rear-Facing Camera Replacement, Open the iPhone: passo 16, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Open the iPhone: passo 16, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Open the iPhone: passo 16, imagem 3 %32
    • Remove your suction handle from the screen.
    • Rotate your iPhone so the right edge faces you.
    • Open your iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 13 Pro Rear-Facing Camera Replacement, Remove the battery connector cover: passo 17, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the three 1.3 mm screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 13 Pro Rear-Facing Camera Replacement: passo 18, imagem 1 %32
    • Remove the battery connector cover.
  19. iPhone 13 Pro Rear-Facing Camera Replacement, Disconnect the battery: passo 19, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Disconnect the battery: passo 19, imagem 2 %32
    • Use the pointed end a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 13 Pro Rear-Facing Camera Replacement, Disconnect the display cable: passo 20, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Disconnect the display cable: passo 20, imagem 2 %32
    • Use the pointed end of a spudger or a clean fingernail to pry the display connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. iPhone 13 Pro Rear-Facing Camera Replacement, Unscrew the front sensor connector cover: passo 21, imagem 1 %32
    • Use a Y000 screwdriver to remove two 1.1 mm screws from the front sensor connector cover.
    • Use a Phillips screwdriver to remove the remaining two screws from the cover:
    • One 1.5 mm screw
    • One 1.8 mm screw
  22. iPhone 13 Pro Rear-Facing Camera Replacement: passo 22, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement: passo 22, imagem 2 %32
    • Remove the front sensor connector cover.
  23. iPhone 13 Pro Rear-Facing Camera Replacement: passo 23, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement: passo 23, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the front sensor assembly cable connector.
  24. iPhone 13 Pro Rear-Facing Camera Replacement: passo 24, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement: passo 24, imagem 2 %32
  25. iPhone 13 Pro Rear-Facing Camera Replacement, Unscrew the camera cover: passo 25, imagem 1 %32
    • Use a Y000 driver to remove the four screws securing the rear-facing camera sensor cover:
    • Three 1.4 mm screws
    • One 1.3 mm screw
    • Use a Phillips screwdriver to remove one 1.6 mm screw.
  26. iPhone 13 Pro Rear-Facing Camera Replacement, Remove the camera cover: passo 26, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Remove the camera cover: passo 26, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Remove the camera cover: passo 26, imagem 3 %32
    • Lift the camera cover from the edge closest to the logic board, and remove it.
  27. iPhone 13 Pro Rear-Facing Camera Replacement, Reassembly tip: passo 27, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Reassembly tip: passo 27, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Reassembly tip: passo 27, imagem 3 %32
    • When reinstalling the camera module cover, ensure the lip along the right edge slides underneath the phone's chassis.
  28. iPhone 13 Pro Rear-Facing Camera Replacement, Disconnect the camera assembly: passo 28, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Disconnect the camera assembly: passo 28, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Disconnect the camera assembly: passo 28, imagem 3 %32
    • Pry up with the pointed end of a spudger to disconnect the two camera cables from the logic board.
  29. iPhone 13 Pro Rear-Facing Camera Replacement, Remove the rear-facing cameras: passo 29, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Remove the rear-facing cameras: passo 29, imagem 2 %32
    • Use the tip of a spudger to lift the camera assembly out of the iPhone.
  30. iPhone 13 Pro Rear-Facing Camera Replacement: passo 30, imagem 1 %32
    • Remove the rear-facing cameras.
  31. iPhone 13 Pro Rear-Facing Camera Replacement, Reassembly tips: passo 31, imagem 1 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Reassembly tips: passo 31, imagem 2 %32 iPhone 13 Pro Rear-Facing Camera Replacement, Reassembly tips: passo 31, imagem 3 %32
    • During reassembly, you'll need to insert the two camera assembly cables into the gap between the upper battery wall and lower camera wall.
Conclusão
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Pro Answers community for help.
14 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
83.715 Reputação
Autoria de 290 guias
4 comentários
Hi, i replaced the camera with a new one and now the camera only shows a black screen.
Laga Mobilen - Responder
I need to replace the camera glass for one of the rear cameras. Is the process from this point to removing and replacing the glass as simple as pushing out the current glass and adhesive, cleaning it, and replacing with new glass and adhesives?
Luke Rein - Responder
@luke Rein. I have the same question
Tom Sowa - Responder
Luke & Tom: unless the rear facing itself is broken, there is no need to dissemble the phone. If it is only the lens, replacement lens kits are available on Amazon and, much more cost effective, eBay - along with tempered glass lens protectors: you can peel the affected lenses from the housing; just be cautious if you are using heat to soften the adhesive - the camera sensors are very sensitive and are easily damaged - and be sure to dislodge all glass fragments (tip the phone upside down and tap lightly; a little compressed air won't harm either). Hope this helps.
samwise3006 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 43
Últimos 7 dias: 249
Últimos 30 dias: 1,144
Duração total: 43,474
