Ir para o conteúdo principal
iPhone 12 Pro Taptic Engine Replacement
O que você precisa
  1. iPhone 12 Pro Taptic Engine Replacement, Eject the SIM card tray: passo 1, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Eject the SIM card tray: passo 1, imagem 2 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone 12 Pro Taptic Engine Replacement, Remove the SIM card tray: passo 2, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Remove the SIM card tray: passo 2, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement, Remove the SIM card tray: passo 2, imagem 3 %32
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
  3. iPhone 12 Pro Taptic Engine Replacement, Remove the pentalobe screws: passo 3, imagem 1 %32
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  4. iPhone 12 Pro Taptic Engine Replacement, Mark your opening picks: passo 4, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Mark your opening picks: passo 4, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement, Mark your opening picks: passo 4, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  5. iPhone 12 Pro Taptic Engine Replacement, Tape over any cracks: passo 5, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Tape over any cracks: passo 5, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement, Tape over any cracks: passo 5, imagem 3 %32
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  6. iPhone 12 Pro Taptic Engine Replacement, Anti-Clamp instructions: passo 6, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Anti-Clamp instructions: passo 6, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement, Anti-Clamp instructions: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Clamp
    $24.95
    Comprar
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  7. iPhone 12 Pro Taptic Engine Replacement: passo 7, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement: passo 7, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement: passo 7, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  8. iPhone 12 Pro Taptic Engine Replacement: passo 8, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement: passo 8, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement: passo 8, imagem 3 %32
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the plastic screen bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  9. iPhone 12 Pro Taptic Engine Replacement, Heat the bottom edge: passo 9, imagem 1 %32
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  10. iPhone 12 Pro Taptic Engine Replacement, Apply a suction cup: passo 10, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Apply a suction cup: passo 10, imagem 2 %32
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  11. iPhone 12 Pro Taptic Engine Replacement, Lift the screen slightly: passo 11, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Lift the screen slightly: passo 11, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement, Lift the screen slightly: passo 11, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  12. iPhone 12 Pro Taptic Engine Replacement, Heat the right edge: passo 12, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Heat the right edge: passo 12, imagem 2 %32
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 12 Pro Taptic Engine Replacement, Separate the right adhesive: passo 13, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Separate the right adhesive: passo 13, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement, Separate the right adhesive: passo 13, imagem 3 %32
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  14. iPhone 12 Pro Taptic Engine Replacement, Heat the top edge: passo 14, imagem 1 %32
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 12 Pro Taptic Engine Replacement: passo 15, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement: passo 15, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement: passo 15, imagem 3 %32
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Leave the pick in the top left corner before continuing.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
  16. iPhone 12 Pro Taptic Engine Replacement, Heat the left edge: passo 16, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Heat the left edge: passo 16, imagem 2 %32
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  17. iPhone 12 Pro Taptic Engine Replacement, Screen information: passo 17, imagem 1 %32
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  18. iPhone 12 Pro Taptic Engine Replacement, Separate the left adhesive: passo 18, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Separate the left adhesive: passo 18, imagem 2 %32
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  19. iPhone 12 Pro Taptic Engine Replacement, Open the iPhone: passo 19, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Open the iPhone: passo 19, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement, Open the iPhone: passo 19, imagem 3 %32
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  20. iPhone 12 Pro Taptic Engine Replacement, Unscrew the battery and display connector cover: passo 20, imagem 1 %32
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  21. iPhone 12 Pro Taptic Engine Replacement, Remove the battery connector cover: passo 21, imagem 1 %32
    • Remove the cover.
  22. iPhone 12 Pro Taptic Engine Replacement, Disconnect the battery: passo 22, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Disconnect the battery: passo 22, imagem 2 %32
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  23. iPhone 12 Pro Taptic Engine Replacement, Disconnect the display cable: passo 23, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Disconnect the display cable: passo 23, imagem 2 %32
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  24. iPhone 12 Pro Taptic Engine Replacement, Disconnect the digitizer cable: passo 24, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Disconnect the digitizer cable: passo 24, imagem 2 %32
    • Use a spudger or a fingernail to disconnect the digitizer cable connector.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  25. iPhone 12 Pro Taptic Engine Replacement, Unscrew the front sensor connector cover: passo 25, imagem 1 %32
    • Use a Y000 driver to remove four screws securing the front sensor connector cover.
    • Three 1.1 mm-long screws
    • One 1.4 mm-long screw
  26. iPhone 12 Pro Taptic Engine Replacement, Remove the front sensor connector cover: passo 26, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Remove the front sensor connector cover: passo 26, imagem 2 %32 iPhone 12 Pro Taptic Engine Replacement, Remove the front sensor connector cover: passo 26, imagem 3 %32
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
  27. iPhone 12 Pro Taptic Engine Replacement, Disconnect the front sensors: passo 27, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Disconnect the front sensors: passo 27, imagem 2 %32
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  28. iPhone 12 Pro Taptic Engine Replacement, Remove the display assembly: passo 28, imagem 1 %32
  29. iPhone 12 Pro Taptic Engine Replacement, Unscrew the loudspeaker: passo 29, imagem 1 %32
    • Use a Phillips driver to remove the four 1.6 mm screws securing the loudspeaker.
  30. iPhone 12 Pro Taptic Engine Replacement, Remove the loudspeaker: passo 30, imagem 1 %32
    • Remove the loudspeaker.
  31. iPhone 12 Pro Taptic Engine Replacement, Unscrew the SIM card reader connector cover: passo 31, imagem 1 %32
    • Use a Y000 driver to remove the two 1.4 mm long screws securing the SIM card reader connector cover.
  32. iPhone 12 Pro Taptic Engine Replacement, Remove the SIM card reader cable connector cover: passo 32, imagem 1 %32
    • Remove the SIM card reader cable connector cover.
  33. iPhone 12 Pro Taptic Engine Replacement, Disconnect the SIM card reader: passo 33, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Disconnect the SIM card reader: passo 33, imagem 2 %32
    • Use the point of a spudger to pry the SIM card reader cable connector straight up and out of its socket on the logic board.
  34. iPhone 12 Pro Taptic Engine Replacement, Unscrew the SIM card reader: passo 34, imagem 1 %32
    • Use a Y000 driver to remove the three screws securing the SIM card reader.
    • Two 1.4 mm screws
    • One 1.1 mm screw
  35. iPhone 12 Pro Taptic Engine Replacement, Remove the Taptic Engine cable connector bracket: passo 35, imagem 1 %32
    • Remove the Taptic Engine cable connector bracket.
  36. iPhone 12 Pro Taptic Engine Replacement, Unscrew the SIM card reader: passo 36, imagem 1 %32
    Standoff Screwdriver for iPhones
    $5.49
    Comprar
    • Use a standoff or a small flathead driver to remove the 2.82 mm long standoff screw securing the SIM card reader.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  37. iPhone 12 Pro Taptic Engine Replacement, Remove the SIM card reader: passo 37, imagem 1 %32
    • Remove the SIM card reader.
    • Before reinstallation, make sure the SIM eject plunger is pushed into the edge of the phone.
  38. iPhone 12 Pro Taptic Engine Replacement, Disconnect the Taptic Engine: passo 38, imagem 1 %32 iPhone 12 Pro Taptic Engine Replacement, Disconnect the Taptic Engine: passo 38, imagem 2 %32
    • Use the point of a spudger to pry the Taptic Engine cable connector straight up and out of its socket on the logic board.
  39. iPhone 12 Pro Taptic Engine Replacement, Unscrew the Taptic Engine: passo 39, imagem 1 %32
    • Remove the three screws securing the Taptic Engine.
    • Two 2.8 mm long standoff screws
    • One 1.8 mm Phillips screw
  40. iPhone 12 Pro Taptic Engine Replacement, Remove the Taptic Engine: passo 40, imagem 1 %32
    • Remove the Taptic Engine.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Pro Answers community for help.
7 outras pessoas executaram este guia.
Adam O'Camb
Membro desde: 04/11/15
197.214 Reputação
Autoria de 416 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 55
Últimos 30 dias: 231
Duração total: 6,398
