Ir para o conteúdo principal
Ajuda
MacBook Unibody Model A1278 Front Display Glass Replacement
Editando passo 2 —
Aviso: Você está editando um guia tipo pré-requisito. Todas as alterações que você fizer afetarão todos os 5 guias que incluem este passo.
Tipo de Passo:
Arraste para reorganizar
With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
Slowly and gently pull the corner of the display glass up off the display assembly.
If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
