Ir para o conteúdo principal
Ajuda
liftmaster garage will not open, red/yellow led blink and beep
Editando passo 2 —
Tipo de Passo:
Arraste para reorganizar
Flip up the cover, remove the screw. Then slide the opener up the wall. Turn around and you'll see a wire attached to two screws. Remove those screws and pull up the back paper. You'll need to pry the PCB board up from the top and then pull up and out.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
