Ir para o conteúdo principal
Xbox One X Disc Drive Replacement
O que você precisa
Vídeo de Apresentação
  1. Xbox One X Disc Drive Replacement, Remove the sticker: passo 1, imagem 1 %32 Xbox One X Disc Drive Replacement, Remove the sticker: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    Pergunte ao FixBot
    Comentar
  2. Xbox One X Disc Drive Replacement, Remove the external screws: passo 2, imagem 1 %32
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
    Pergunte ao FixBot
    Comentar
  3. Xbox One X Disc Drive Replacement, Slide the upper case horizontally: passo 3, imagem 1 %32 Xbox One X Disc Drive Replacement, Slide the upper case horizontally: passo 3, imagem 2 %32
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
    Pergunte ao FixBot
    Comentar
  4. Xbox One X Disc Drive Replacement, Lift the upper case off the lower case: passo 4, imagem 1 %32 Xbox One X Disc Drive Replacement, Lift the upper case off the lower case: passo 4, imagem 2 %32
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
    Pergunte ao FixBot
    Comentar
  5. Xbox One X Disc Drive Replacement: passo 5, imagem 1 %32 Xbox One X Disc Drive Replacement: passo 5, imagem 2 %32 Xbox One X Disc Drive Replacement: passo 5, imagem 3 %32
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
    Pergunte ao FixBot
    Comentar
  6. Xbox One X Disc Drive Replacement: passo 6, imagem 1 %32 Xbox One X Disc Drive Replacement: passo 6, imagem 2 %32
    • Push the upper plastic case down and away from the console to remove it completely.
    Pergunte ao FixBot
    Comentar
  7. Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: passo 7, imagem 1 %32 Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: passo 7, imagem 2 %32 Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: passo 7, imagem 3 %32
    • Use the pointed end of a spudger, an opening tool, or your fingernail to flip down the small, hinged locking flap on the ribbon cable ZIF connector on the front circuit board.
    Pergunte ao FixBot
    Comentar
  8. Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: passo 8, imagem 1 %32
    • Use blunt tweezers to pull the ribbon cable down out of the connector.
    Pergunte ao FixBot
    Comentar
  9. Xbox One X Disc Drive Replacement, Remove the front circuit board screws: passo 9, imagem 1 %32
    • Use a T8 Torx screwdriver to remove the three 13.3 mm screws securing the front circuit board to the upper metal case.
    Pergunte ao FixBot
    Comentar
  10. Xbox One X Disc Drive Replacement, Remove the front circuit board: passo 10, imagem 1 %32 Xbox One X Disc Drive Replacement, Remove the front circuit board: passo 10, imagem 2 %32
    • Pull the front circuit board straight out away from the upper metal case and set it aside.
    • Grip the board on either side of where it is plugged in to avoid bending and damaging it.
    Pergunte ao FixBot
    Comentar
  11. Xbox One X Disc Drive Replacement, Remove the upper metal case screws: passo 11, imagem 1 %32
    • Use a T10 Torx screwdriver to remove the six 47.7 mm screws securing the upper metal case to the lower plastic case.
    • Use a T8 Torx screwdriver to remove the two 7.5 mm screws securing the press connector to the upper metal case.
    Pergunte ao FixBot
    Comentar
  12. Xbox One X Disc Drive Replacement, Detach the press connector: passo 12, imagem 1 %32 Xbox One X Disc Drive Replacement, Detach the press connector: passo 12, imagem 2 %32
    • Insert the flat end of a spudger underneath the press connector on the side opposite of the ribbon cable.
    • Use the spudger to lift the press connector up and away from the upper metal case.
    • Don't push the spudger all the way to the socket. Prying up the socket may damage it.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Pergunte ao FixBot
    Comentar
  13. Xbox One X Disc Drive Replacement, Remove the lower plastic case: passo 13, imagem 1 %32 Xbox One X Disc Drive Replacement, Remove the lower plastic case: passo 13, imagem 2 %32 Xbox One X Disc Drive Replacement, Remove the lower plastic case: passo 13, imagem 3 %32
    • Flip the console over.
    • Hold on to the lower plastic case because it is no longer attached to the metal case.
    • Lift the lower plastic case up from the metal case and set it aside.
    Pergunte ao FixBot
    Comentar
  14. Xbox One X Disc Drive Replacement, Remove the lower metal case screws: passo 14, imagem 1 %32
    • Remove the two T10 Torx screws securing the lower metal case:
    • One 7.7 mm screw
    • One 11.4 mm screw
    Pergunte ao FixBot
    Comentar
  15. Xbox One X Disc Drive Replacement, Remove the lower metal case: passo 15, imagem 1 %32
    • Lift the lower metal case up off the upper metal case and internal components.
    • The disc drive may lift up with the lower metal case. Hold it down during this step.
    • Set the lower metal case aside.
    Pergunte ao FixBot
    Comentar
  16. Xbox One X Disc Drive Replacement, Unscrew the power supply: passo 16, imagem 1 %32
    • The disc drive is only attached to the motherboard by two cable connectors. Hold the disc drive when flipping the console over to avoid damaging it.
    • Use a T10 Torx screwdriver to remove the two 11.4 mm screws securing the power supply to the upper metal case
    Pergunte ao FixBot
    Comentar
  17. Xbox One X Disc Drive Replacement, Loosen the disc drive: passo 17, imagem 1 %32 Xbox One X Disc Drive Replacement, Loosen the disc drive: passo 17, imagem 2 %32
    • Lift the disc drive so that its metal tab is unhooked from the power supply.
    • The disc drive is plugged into the motherboard. Don’t bend the wires more than necessary to avoid damaging them.
    • Place the disc drive on the upper metal case so that it sits over the hard drive. You'll need enough space to unplug the power supply from the motherboard.
    Pergunte ao FixBot
    Comentar
  18. Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: passo 18, imagem 1 %32 Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: passo 18, imagem 2 %32 Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: passo 18, imagem 3 %32
    • Insert the flat end of the spudger underneath the dark grey foam tape starting at the corner closest to the power supply and edge of the console.
    • Lift up the corner.
    • Slowly push the spudger through to the other side of the tape until you can see the flat end emerge.
    • Remove the spudger slowly. There are two grey cables underneath the foam tape. Try to avoid hitting them with the spudger so that you don't damage them.
    Pergunte ao FixBot
    Comentar
  19. Xbox One X Disc Drive Replacement, Unplug the power supply: passo 19, imagem 1 %32 Xbox One X Disc Drive Replacement, Unplug the power supply: passo 19, imagem 2 %32
    • Lift the power supply directly upward to unplug it from the motherboard.
    • Move the disc drive further away from the power supply if you need more space.
    Pergunte ao FixBot
    Comentar
  20. Xbox One X Disc Drive Replacement, Set the power supply to the side: passo 20, imagem 1 %32 Xbox One X Disc Drive Replacement, Set the power supply to the side: passo 20, imagem 2 %32 Xbox One X Disc Drive Replacement, Set the power supply to the side: passo 20, imagem 3 %32
    • After the power supply is unplugged from the motherboard, rotate and lift it away from the console.
    • The two grey cables are still attached to the console by the dark grey foam tape and the power supply socket beneath the fan case. Avoid bending the cables more than necessary to prevent damage.
    • Place the power supply so that it is sitting on its side just outside the upper metal case.
    Pergunte ao FixBot
    Comentar
  21. Xbox One X Disc Drive Replacement, Unplug the disc drive: passo 21, imagem 1 %32 Xbox One X Disc Drive Replacement, Unplug the disc drive: passo 21, imagem 2 %32
    • Unplug the SATA cable connecting the disc drive to the motherboard by pulling directly upward.
    Pergunte ao FixBot
    Comentar
  22. Xbox One X Disc Drive Replacement: passo 22, imagem 1 %32 Xbox One X Disc Drive Replacement: passo 22, imagem 2 %32
    • Unplug the bundled cable connector connecting the disc drive to the motherboard by pulling directly upward.
    Pergunte ao FixBot
    Comentar
  23. Xbox One X Disc Drive Replacement, Remove the disc drive: passo 23, imagem 1 %32
    • Lift the disc drive out of the console.
    Pergunte ao FixBot
    Comentar
  24. Xbox One X Disc Drive Replacement, Remove the vibration dampener: passo 24, imagem 1 %32 Xbox One X Disc Drive Replacement, Remove the vibration dampener: passo 24, imagem 2 %32 Xbox One X Disc Drive Replacement, Remove the vibration dampener: passo 24, imagem 3 %32
    • Slide the rubber vibration dampener off of the disc drive.
    Pergunte ao FixBot
    Comentar
  25. Xbox One X Disc Drive Replacement, Remove the external disc drive connectors: passo 25, imagem 1 %32 Xbox One X Disc Drive Replacement, Remove the external disc drive connectors: passo 25, imagem 2 %32
    • Unplug the bundled cable connector from the disc drive.
    Pergunte ao FixBot
    Comentar
  26. Xbox One X Disc Drive Replacement: passo 26, imagem 1 %32 Xbox One X Disc Drive Replacement: passo 26, imagem 2 %32
    • Unplug the SATA cable from the disc drive.
    Pergunte ao FixBot
    Comentar
  27. Xbox One X Disc Drive Replacement, Remove the cover: passo 27, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 3.7 mm screws securing the disc drive cover.
    • You don't need to remove the foam covering the two right-side screws. Move the foam aside just enough to expose the screw.
    Pergunte ao FixBot
    Comentar
  28. Xbox One X Disc Drive Replacement: passo 28, imagem 1 %32 Xbox One X Disc Drive Replacement: passo 28, imagem 2 %32
    • Remove the cover from the disc drive.
    Pergunte ao FixBot
    Comentar
  29. Xbox One X Disc Drive Replacement, Disconnect the three ZIF connectors: passo 29, imagem 1 %32 Xbox One X Disc Drive Replacement, Disconnect the three ZIF connectors: passo 29, imagem 2 %32
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the large ribbon cable ZIF connector.
    Pergunte ao FixBot
    Comentar
  30. Xbox One X Disc Drive Replacement: passo 30, imagem 1 %32 Xbox One X Disc Drive Replacement: passo 30, imagem 2 %32
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the small ribbon cable next to the large ribbon cable ZIF connector.
    Pergunte ao FixBot
    Comentar
  31. Xbox One X Disc Drive Replacement: passo 31, imagem 1 %32 Xbox One X Disc Drive Replacement: passo 31, imagem 2 %32
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the long ribbon cable in the corner of the disc drive ZIF connector.
    Pergunte ao FixBot
    Comentar
  32. Xbox One X Disc Drive Replacement: passo 32, imagem 1 %32 Xbox One X Disc Drive Replacement: passo 32, imagem 2 %32 Xbox One X Disc Drive Replacement: passo 32, imagem 3 %32
    • Use blunt tweezers to pull out each of the three ribbon cables in the direction of the cable.
    Pergunte ao FixBot
    Comentar
  33. Xbox One X Disc Drive Replacement, Desolder the two wires: passo 33, imagem 1 %32 Xbox One X Disc Drive Replacement, Desolder the two wires: passo 33, imagem 2 %32
    • Use a soldering iron to desolder the red wire in the corner of the disc drive circuit board.
    • Then, desolder the adjacent black wire. Use blunt tweezers to hold and pull away the wires from the circuit board.
    • Follow general soldering safety guidelines such as wearing eye protection, working in a well-ventilated area, and washing your hands with soap and water after soldering.
    • Excessive heat may damage electrical components. Don't apply the soldering iron to the board for long amounts of time.
    • When you install the original circuit board into the replacement disc drive, solder the red wire to the solder pad labeled "R." Solder the black wire to the solder pad labeled "B."
    Pergunte ao FixBot
    Comentar
  34. Xbox One X Disc Drive Replacement, Remove the circuit board screws: passo 34, imagem 1 %32
    • Use a Phillips screwdriver to remove the three 3.4 mm screws securing the circuit board to the disc drive case.
    Pergunte ao FixBot
    Comentar
  35. Xbox One X Disc Drive Replacement, Remove the disc drive circuit board: passo 35, imagem 1 %32 Xbox One X Disc Drive Replacement, Remove the disc drive circuit board: passo 35, imagem 2 %32
    • Lift the circuit board out of the disc drive case and transfer it to the replacement drive.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox One X Answers community for help.
22 outras pessoas executaram este guia.
Kyle Smith
Membro desde: 02/01/21
52.520 Reputação
Autoria de 124 guias
3Comentários do guia
I bought a One X for cheap and it worked but the Disc drive didn't - it couldn't pull in the discs; I opened it up, discovered that it was very dusty, cleaned that out and also cleaned the Disc drive, especially the rollers of the mechanism that pushes the disc out or pulls it in, of course also the laser lens, then reassembled it and it works absolutely fine again.
Marcel Pape - Responder Compartilhar
Ive replaced the dvd drive with mine but the game discs will not load
David Chan - Responder Compartilhar
would it work if i got the Disc drive from my old xbox one ? i think they are the same exact size though !
AbuObaid Home - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 144
Últimos 30 dias: 718
Ao todo: 43,713
