Ir para o conteúdo principal
Steam Deck Right Button Board Replacement
O que você precisa
  1. Steam Deck Right Button Board Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 1 %32 Steam Deck Right Button Board Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 2 %32 Steam Deck Right Button Board Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 3 %32
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Right Button Board Replacement, Remove the back cover screws: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
    there should be a picture of the SD card slot at the start of every Steam Deck teardown. i know the note is there but i generally use the pictures to guide me and forgetting to remove the SD card is a very critical step
    Nathan Barrow - Responder
    I agree, I just broke mine...
    Camille B -
    What is the the #1 philips used for? Only the #0 is mentioned in the instructions.
    Christopher Martin - Responder
    I wish they would specify which size to use for which screws.
    Mark D -
    I found it easiest to use a PH1 for the red screws, and PH0 for the rest (including the internals.)
    Chris Clawson -
    Be careful you can strip the screws take your time
    I use PH00 bit
    jaybush74 - Responder
    I used the PH1 bit for this. You can use smaller bits but ideally there should be no play of the bit in the screw head.
    Charles Semple - Responder
    are there playstation replacements (circle,square,cross,triangle)
    Deór - Responder
    I used the ifixit tools and used the 00 size for the screws on the back.
    Luis B - Responder
    I've completed the guide and found it very helpful!
    I think somewhere in this part it would be helpful to name the size of the correct Phillips driver to use:
    Four 9.5 mm screws
    Four 5.8 mm screws
    Maynard - Responder
    I used the PH1 for the 9.5mm screws and PH00 for the 5.8mm screws. The PH0 wanted to strip one of the small ones.
    Pol Llovet - Responder
    FYI - 512gb version has blue threadlocker on the Orange screws.
    Kyle - Responder
    Just a point for knowledge sake, the Four 5.8mm screws on this step are factory installed with a version of locktite. Not sure why but there will be slight resistance when removing the first time.
    Derek Schmidlin - Responder
    Stripped two of the 5.8mm screws, feel pretty dumb, now I'm stuck at step 2 of 43 :|
    Yareyous - Responder
    The screw bit that came with my fix kit just stripped the screws of my steam deck. I guess I should've just sent it in...
    Randy Jackson - Responder
    Model 1030 SteamDeck uses Torque #6 (CR-V T6) 5.0mm for all 8 screws making it far less likely to damage the screw heads.
    seaniepie - Responder
    Model 1030 is the OLED version, which we have separate guides for! See here: Steam Deck OLED
    Carsten Frauenheim -
  3. Steam Deck Right Button Board Replacement, Unclip the back cover: passo 3, imagem 1 %32 Steam Deck Right Button Board Replacement, Unclip the back cover: passo 3, imagem 2 %32
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
    I found it easiest to start this process at the top of the device near the fan exit.
    Peter Lindberg - Responder
    second that and inserting the pick in the bottom middle and sliding the pick to each side
    Sub -
    I also found the top near the fan exit to be easier
    Travis Patton -
    Thank you for this tip, it definitely was easy starting at the top instead of by the bumper/triggers. After I opened the top I did the bottom and then it was way easier to gently open the sides. be very careful and go slowly to make sure that none of the clips are damaged
    Luis B -
    this as suggested above:
    1. open the top
    2. open the bottom
    3.gently open the sides
    austrasier -
    same; i pried from the top of the screen area. I was unable to find an opening on the side
    Dennis Wu - Responder
    I also started from the middle of the deck and worked my way out since I couldn't get a grip with the pick on the deck's side grips. Since this is a common step for pretty much all guides for opening the deck I think it's also worth noting that you should be careful not to bend the trims/seams where the front and back covers meet with the pick. When I first opened my deck you can definitely see where I nudged the pick in between the covers since I was probably using too much force on the pick itself.
    Kaleb McKone - Responder
    It would be useful to note here that if you want to insert the little blue triangular iFixit opening picks into the right side along the edge, there isn't actually a gap as the directions say, at least not on newer Decks. You'll be making the initial gap using the pick. Brace it on something because you will need to use enough downward force that you're flexing the pick a bit and it'll probably be digging into the skin of a bare hand. With enough force suddenly it will make a click and go in just a bit, and then you're in business.
    CaptFrost - Responder
    plastic picks didnt work for me but finger males did the job on prying this open
    jacobbagsic - Responder
    I found it easiest to open starting with R1 or L1 buttons and proceeding to the center of the top edge
    Karol Gro - Responder
    This step was the hardest by far. First I didn't find an opening at the sides, and it did take a really long time until I finally got it open... Then, when I had the one side opening open it didn't just pop out, I needed to slide all the way to the other side with the pick and open everything. I guess they made it even more drop resistant.
    Dollique - Responder
  4. Steam Deck Right Button Board Replacement, Remove the back cover: passo 4, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the back cover: passo 4, imagem 2 %32 Steam Deck Right Button Board Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
    If you have an SD card, you will want to take it out. I followed the guide and didn't think about the SD card I had inside. When I went to snap the case back on it clapped shut on the exposed SD card, shearing it in half and leaving the bottom half stuck in the SD card slot. I am still endeavoring to get it out.
    Novice - Responder
    you can use the case that comes with the steam deck to support it once the lid is removed
    Luis Barbosa (Armored Saint) - Responder
    You can get the pry pick inserted easier if you start in the gap for the shoulder buttons. A lego brick separator works well here
    Andrew Borsje - Responder
  5. Steam Deck Right Button Board Replacement, Uncover the hidden shield screw: passo 5, imagem 1 %32 Steam Deck Right Button Board Replacement, Uncover the hidden shield screw: passo 5, imagem 2 %32
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
    Use some heat here from a hairdryer to make this part easier.
    If you screw up here you can replace the little aluminium square with some aluminium tape from Amazon. No less than 50 microns thick, slightly thicker is fine. and the square is 13mm both ways.
    Matt S - Responder
    Thanks for that Matt, i destroyed the original tape and i had no solution since i read your comment.
    Cihan Kocaman -
    there are other new version of board shield from 2023.
    Gorf Woo - Responder
    Is it alright to use the deck without the tape?
    Jake - Responder
    You should not. This is EM shielding to protect your processor and ram from radio waves in the air
    Andrew Borsje -
    I found out my 3 Weeks new Steam Deck is a old Version... gg. Valve...
    Miller Schiffer - Responder
    wenn ich aluminium foile benutze, womit soll ich sie dann verkleben?
    Christian Dud - Responder
    If we have the new version with the black shield, how do we access the SSD?
    James Bennett - Responder
    I need this part, does anyone know where to get it?
    rolando norica - Responder
    PSA: The only purpose of steps 5–8 is to enable you to disconnect the battery, which is not essential. I skipped steps 5–8 and did not have any trouble with the repair.
    David H - Responder
  6. Steam Deck Right Button Board Replacement, Remove the shield screws: passo 6, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the shield screws: passo 6, imagem 2 %32
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
    The procedure ended here for me, used an ifixit PH 00 bit on the screw behind the aluminium tape, bit wouldnt bite too great, one wrong twist and the screw was stripped. Not sure who or what initially screwed in that particular screw as the rest of the screws on the shield were fine, but boy is it in there tight. So now i have a stripped screw and a botched ssd replacement, don't think valve will let me RMA for this, but i'll give it a try and update accordingly.
    Y. van S - Responder
    Any updates? Did they let you RMA?
    Emanuel Gjoni -
    I found one screw to be ridiculously tight too, managed to undo it without stripping thanks to reading your comment beforehand and going extra careful. Not going to lie, it was a tense moment :D
    Andy HL -
    I'm stuck in the same place. I haven't fully stripped it, but I can tell you that if I try and make it budge it will strip. The thing is massively overtightened. The driver fit fine, the metal just gives way before the screw will budge.
    Robert Boswell Johnson -
    I think the tendency is to go too small on the screwdriver bits because you're working on small electronics.
    I used the PH1 bit on the screw under the foil and the PH0 bit for the two remaining screws without any problems.
    What does this shield actually do? Some kind of magnetic protection?
    Corey Cleric - Responder
    if I had to replace the key (R2) and that's it, can I directly remove it or do I have to act here on the motherboard too?
    pujattidanny - Responder
    have you gotten an answer yet? trying to change mines as well but dont wanna do too much to the deck
    briaNN -
    button Not key, i’m sorry
    I used the ifixit tools and used the 00 PH for these screws with no issue
    Luis B - Responder
    If only swapping the SSD, it is not necessary to remove the top left 3.7mm screw. The heat shield is flexible enough that you can move it out of the way to access the SSD screw. For me this was necessary as the 3.7mm screw was completely unmovable and quickly stripped.
    Scott A - Responder
    FYI there is a little pin on the cover that slots into the board. It is located near the top screw. I needed that to be inserted for the cover to go back down properly.
    Seth Robinson - Responder
    For anyone who may have stripped a 3.7mm screw, Steam Support states it's M1.6 diameter with a 0.35 thread pitch and a 3mm length. Hopefully that'll help anyone trying to locate a replacement screw. Hoping iFixIt can make an internal screws kit as they're kinda hard to find the right one online.
    Michael Dyer - Responder
    Did valve change the shield recently as my new 64gb deck has a black shield with no hidden screw.
    David Alexander Hubbard - Responder
    Yes there's a new hardware revision out there that some people are getting. Consider stopping at this point and putting your deck back together if you have one of these new hardware revisions (the fan is quite different as well to the pictures) until iFixit has an updated repair guide.
    Simon M. -
    There are only 2 screws now, but be careful taking the shield off, because there are still thermal pads under it sticking it to a heat pipe.
    Rudolfs Skurulis -
    Are they m2 3.7mm screws? I am looking to replace mine because they instantly stripped and I had to remove them with needle nose pliers because they were over tightened.
    Nick - Responder
    I need this piece, can someone help me where can I find it please?
    Hi, is it possible to buy these shields somewhere? I am extremely interested in buying a replacement.
    Yannick B. - Responder
    The refreshed model 1030 has 2 T6 torx screws instead of Philips
  7. Steam Deck Right Button Board Replacement, Remove the shield: passo 7, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the shield: passo 7, imagem 2 %32 Steam Deck Right Button Board Replacement, Remove the shield: passo 7, imagem 3 %32
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
    When putting back on, run a pick along the edge of the shield between the wires to make sure nothing is pinching and the wires are clear of the shield before screwing down.
    Matt S - Responder
    Are you saying that the fan cable should be positioned above the board shield instead of being pressed down by it? Just like the image shows, where it 'lays on the side of the board shield'?
    James - Responder
    Necesito esta pieza la mía no la traía se ve que se la quitaro
  8. Steam Deck Right Button Board Replacement, Disconnect the battery: passo 8, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the battery: passo 8, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the battery: passo 8, imagem 3 %32
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
    After fully reassembling my device I found that my battery was not showing any stats anymore. I couldn't start the device without being plugged in, however if I restarted it would stay on even if my power cable was detached. Battery showed 0%. It turns out I had not fully reinserted the battery cable at this stage during reassembly. MAKE SURE YOU PUSH IT ALL THE WAY BACK IN!
    Michael Hoffmann - Responder
    Awesome thanks for this tip!
    petergeranio -
    It is helpful to lift up gently with a the tapered end of a spudger underneath the tucked-in portion of the battery cable, creating a bit of flex in the cable before pulling on the pull tab. I found that without doing so, the fabric pull-tab simply tore off of the cable under light-to-moderate force (the fabric itself ripped cleanly across, like a paper towel). Careful, gentle pressure with a spudger can be used to remove the plug by prying gently on the rear ridge of the plastic plug (not the wire!) if this happens.
    Gene Eckser - Responder
    This is exactly what happened to me. Maybe it was a pull tab previously, mine was a ribbon cable that tore - captured the image here: https://www.ianwootten.co.uk/2022/11/22/...
    Ian Wootten -
    This was the best approach (and I feel safest for the wiring) for me. Mostly push pressure on the plastic ridge with some minor pull tension on the fabric.
    Victor -
    I found it less scary and easier to remove the battery connection by using a fingernail on the ridge and pushing it off the connector. I felt like pulling on the battery cable was too harsh.
    montgomery mchargue - Responder
    Yeah, pulling cables like these is usually ill advice. They might be fine if it's a new device, but for old devices that have been sitting there for years, there's a good chance the connector has grown brittle and the cable might just come off separately (something I learnt the hard way).
    skzm -
    I second this approach. For me, the cable felt way to flimsy and the connector wouldn't budge even under moderate force. Except I used the flat end of a spudger to "scrape" it out.
    Misza -
    Upon plugging the battery back in, I found it easy to use two spudgers- one on each side- to pull/push the connector back into it's port. Be careful to not put any pressure on the battery wires themselves.
    When reconnecting the battery cable, you'll know when it's inserted and power is restored, because the white LED will illuminate at the top of the Deck near the power button. You should be able to see it while you're reconnecting the battery cable
    Michael Davis - Responder
    This is only true if you haven't put the deck into battery storage mode as directed.
    Ean Manley -
    Why not just let the battery discharge completely and then not have to disconnect it?
    Jeffrey Martin - Responder
    Completely discharging a battery reduces its lifespan. It's completely unnecessary.
    Stefan Camporese (CENTER) -
    Because no lipo battery is ever completely discharged -- you would not be able to recharge it if it was. There will always be enough power left in it to cause damage if shorted even if it isn't charged enough to power up the device it's connected to.
    David Cameron -
    I would personally not recommend pulling the tab. It doesn’t apply force at the correct angle. You should revise these instructions to advise using a combination of pulling on the tab, and careful pressure on the connector towards the right of the mainboard to carefully work it out.
    Using the pull tab alone could cause problems if not done extremely carefully.
    William Winborne - Responder
    This part was wayyyyy easier than I anticipated and I worried for nothing because I used the ifixit spudger to push it out a bit and then I literally used my finger nail and was able to slide it right off. Dont be afraid, its not that difficult and its not that delicate to break if you do it patiently
    Luis B - Responder
    I inserted the cable very firmly with a spunger, being careful not to press down too hard on the cables, and even tried redoing it, but I don't see any LED illumination. I am now unable to boot the deck into the boot manager. Any additional tips?
    junefish - Responder
    What is the risk of not unplugging the battery? Just curious!
    Nick Hight - Responder
    Once I was changing termal paste on my Windows based expensive tablet PC... And I was so scared to disconnect any cables (there was many of them), so I did it all with battery connected (I didn't even knew where is battery cable). When I tried to put board shield back... it didn't go right into needed place... and short circuit some small component. It flashed. That was the end of my repair. Dudies from repair service later told me that multiple components fried including CPU, so repairing is too hard. That's what can happen if you don't disconnect battery.
    bugwarlabs -
    To pull the battery out I used my spunger, but the batter had actually not space to be pulled out completely. I needed to lift the cable up with the spunger to get the cable fully out. When plugging it in again I had to press the battery down kinda hard so it would fit again. This was really scary and I recommand using two spunger as someone said above.
    Does it have to be a clean fingernail?
    Steven Murphy - Responder
    I disagree with the order here: I think the battery should be disconnected right after step 4. You can do that before touching anything else by gently pulling the pull tab to the right.
    If all you want to do is to disconnect and reconnect your battery (because your Steam Deck is not booting up... again...) then with a bit of finesse, luck and a flat plastic tool you can even push it back in without removing the shield. Make sure it went all the way back in.
    Fozi - Responder
    Be very careful with this tab, it rips easily!
    Tom Sid - Responder
  9. Steam Deck Right Button Board Replacement, Unclip the right trigger: passo 9, imagem 1 %32 Steam Deck Right Button Board Replacement, Unclip the right trigger: passo 9, imagem 2 %32
    • The right trigger will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
    This is unnecessary on the revised Model 1030 if you only need to access the Quick Access button. Jump to Step 13.
  10. Steam Deck Right Button Board Replacement, Remove the right trigger: passo 10, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the right trigger: passo 10, imagem 2 %32
    • Remove the right trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
    This is by far the hardest part of the entire assembly. I don't know if its because I dropped mine but the trigger takes an incredible amount of force to get off, don't be afraid to break it. I still have no idea how to put the trigger back on, it just wont budge.
    J4CK T - Responder
    In case the spring gets lost, it's 19 mm long with about 14 coils.
    Claudiu Avram - Responder
    Thank you this is helpful
    reconbot -
    When putting this back on be sure to note the instructions for reassembly above. Catch the outer peg, align the inner one, and push. Having a flashlight on the inner peg helped me get it lined up.
    Aaron Newton - Responder
  11. Steam Deck Right Button Board Replacement, Remove the trigger bracket screws: passo 11, imagem 1 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
  12. Steam Deck Right Button Board Replacement, Remove the trigger bracket: passo 12, imagem 1 %32
    • Remove the right trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
    The right bumper button on my switch deck stopped working after the deck was accidentally dropped from 5ft. When I got to this step of the instructions, I was able to see that the momentary switch that the button triggers had been bent backwards from the impact, making it difficult for the button to trigger the switch. I bent the switch back to its original position, which fixed the mechanical problem. Unfortunately the solder joints for the switch cracked when I pressed the switch forward. I re-flowed the solder joints with a tiny Weber iron that I filed down to a narrow point. The button works properly now.
    Paul Krakow - Responder
  13. Steam Deck Right Button Board Replacement, Disconnect the right thumbstick: passo 13, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the right thumbstick: passo 13, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the right thumbstick: passo 13, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  14. Steam Deck Right Button Board Replacement, Remove the thumbstick screws: passo 14, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the thumbstick screws: passo 14, imagem 2 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
    This is unnecessary if you only need to access the Quick Access button on the revised Model 1030. Jump to step 16.
  15. Steam Deck Right Button Board Replacement, Remove the right thumbstick: passo 15, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the right thumbstick: passo 15, imagem 2 %32
    • Remove the right thumbstick.
  16. Steam Deck Right Button Board Replacement, Disconnect the button board cable: passo 16, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the button board cable: passo 16, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the button board cable: passo 16, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
    On the revised Model 1030 it is all black and you will need to raise the ribbon slightly to remove it. Don’t just try to pull it backwards as there is a notched retainer.
  17. Steam Deck Right Button Board Replacement, Disconnect the interconnect cable: passo 17, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the interconnect cable: passo 17, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the interconnect cable: passo 17, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
    Be very mindful of this cable during re-assembly, if this cable isn't fully seated properly the deck will turn on slowly and not be able to recognize any inputs besides the touch screen.
    Hmm, I wonder if this is my problem. I replaced my case with the Clear JSAUX one. Everything went fairly well, until I closed it up and noticed none of my buttons worked anymore. By "seated properly", how do you tell? When I look at it, it looks the same as the picture, with the white line showing
    Eric Merriweather -
    Eric, flip up the white locking flap and remove the cable. Then reinsert the cable — it should go in smoothly with no resistance, hence its name (ZIF = "Zero Insertion Force") — if you feel resistance, there might be something blocking the cable or its connection. If it slides in smoothly, make sure it bottoms out evenly and isn't at an odd angle. If everything looks good, your problem is probably elsewhere.
  18. Steam Deck Right Button Board Replacement, Disconnect the remaining button board cables: passo 18, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the remaining button board cables: passo 18, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the remaining button board cables: passo 18, imagem 3 %32
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the action buttons cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
    Be especially careful disconnecting and reconnecting the touchpad cable. It is short and can pull out on the touchpad side fairly easily. Reconnecting it requires splitting open the touchpad itself which is difficult to do without damaging the springs.
    acey_zero - Responder
  19. Steam Deck Right Button Board Replacement, Disconnect the right haptics: passo 19, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the right haptics: passo 19, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the right haptics: passo 19, imagem 3 %32
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
    Personally, i think this should just be a suggested step, since the connector is different and requires more force to disconnect than the ribbon cable connectors and you can leave this connected and lay the board over to the side without disconnecting this and still access the buttons.
    I agree with Peter on this. I tried fixing my right bumper before ordering a replacement and during disassembly I followed these instructions exactly and still broke the bracket that holds the haptics connector. Luckily my haptics seem to still be working after putting it back together but I have a feeling it will disconnect on its own after some time and I will be needing a whole new button board.
    Biscuits - Responder
    I did this very carefully and the bracket still broke
    Christian McCarthy - Responder
    I broke the down part of the bracket as well. Glued it back on with some crazy glue applied with a wooden toothpick (to make sure to not touch anything else). Haptics still working. Next time I don't think I'll remove that connector.
    Sébastien M - Responder
    Leave the haptic connector on and just move the button board out of the way. You will likely brake the haptic connector bracket by trying to remove it.
    Frank - Responder
    I agree with everyone above. Attempting to disconnect the haptics is not worth it as it breaks extremely easily
    Vince Gmerek - Responder
    Please remove this step. It is virtually impossible to remove this without breaking the housing and it's ultimately not necessary.
    Eric Benante - Responder
    Wish I had seen this beforehand. My right connector just broke off. Ughhh.
    Eric Merriweather - Responder
    This also screwed up my haptics as it basically fell apart as soon as it was touched
    Cassie - Responder
    Can this just be soldered back on or do I need a new button board? Because I have looked online and they seem impossible to find.
  20. Steam Deck Right Button Board Replacement, Remove the button board screws: passo 20, imagem 1 %32
    • Use a Phillips driver to disconnect the four screws securing the right button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
    Once again, for the revised Model 1030, all of these screws are T6 of varying sizes, nothing like the original. Use your favourite way of keeping track of where to return the screws in their correct holes.
  21. Steam Deck Right Button Board Replacement, Remove the button board: passo 21, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the button board: passo 21, imagem 2 %32
    • Remove the right button board.
    • Keep track of the quick access button and its membrane, as once the right button board is removed, they're no longer secured in place.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
6 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
136.514 Reputação
Autoria de 371 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.648 guias
42Comentários do guia
When will this part be available?
Eric Canals - Responder
Is there any update to when this part will be available?
Tim Ceesay - Responder
Will this part not be available due to their need being a special calibration or hardware step? Having past six months this makes one think the part is not possible with end user due to another factor.
zZz - Responder
Is there any estimated time to when this part will become available?
David Chan - Responder
Parroting everyone else. When will this part be available?
Mario Noriega - Responder
Yes, I need this part, as well. The plastic bumper piece is fine... the button on the board itself is my issue with my R1 button. Need this part... but don't want to send my Steam Deck away for several weeks on warranty... would rather fix it myself.
Dan Lnenicka - Responder
I fixed the micro switch myself, see my comment: Steam Deck Right Button Board Replacement
Shane Qi -
Same issue, it just came loose of the solder for me. Seems to take alot of the force of button press.
Michael -
I finally broke my screen (kid stepped on it next to my bed!) and I was going to buy both this part and a screen from iFixit and do the repairs myself.
This part isn't available! I guess I'll try and send it on warranty.
Andrew Ballinger - Responder
Man, I have an issue with my right R1 bumper. & they want me to send it in for that, @ NO CHARGE that's great & all but I STILL DONT TRUST THE SYSTEMS in place to protect my device I just can't see it being worth it in the long run scares TF outta me.
Don't get me wrong The Steam Deck is not that hard to obtain especially in the location I live. There are at least 5 Steam Decks being sold a day on Facebook Market Place. So, if it really came down to it I'd jus buy a new 1 while waitin for their idiot @%^!* to replace mines or figure out the issue/issue's. There is ALWAYS, I MEAN ALWAYS a dam issue when goin this route.
I hate being the negative Ned here, but its the dam truth. I have heard some of the narlyest Horror stories about people sending in for repairs to Valve on Redit. I know alot of the people posting on Redit are jus trolls but still if even 20% of the stories were true that's insane. & I jus don't care to deal with ANY of it, if I don't have too.
🎮👍-Best of luck to you buddy-👍🎮
sgtkickazzttv -
What you mean you Finely broke your screen it's like you already predicted your Steam Dexks fate with bad JuJu.
LolLz did the Steamy Deck ever have a chance with an outlook like that?!? I don't think the Steam Deck REALLY ever had a chance . SADGE!!
Oh well as long as your able too fix her up I am happy! Haha. Also if your already gonna be buying a new screen I would suggest to upgrade too the newer anti glare screen it helps a WHOLE LOT MORE & if I am not mistaken the upgraded LCD is ONLY $99.99 WHICH IS SO WORTH IT!! Especially, if your already looking to replace the screen. Just some advice buddy. I mean other than that the "upgraded screen" wouldn't really be worth it. But in this case so worth it.
sgtkickazzttv -
Hello I want to buy this part please
Blake N. - Responder
Same here daughter dropped my deck and right button ripped from the board would really like to replace the board ASAP
Tom Just - Responder
I fixed the micro switch myself, see my comment hope it helps: Steam Deck Right Button Board Replacement
Shane Qi -
When is this part going to be available to purchase? It's ridiculous that people have been asking the same question for months without any response at all
Jake Guest - Responder
Installing these boards in the Steam Deck requires special calibration that isn't currently publicly available. As of right now we don't know if/when these could be available for purchase.
Carsten Frauenheim - Responder
If you are here because the L1/R1 micro switch is broken, you can replace just the micro switch. I've done it recently:
1. the micro switch I used was the sync/pair button of the Xbox controller, and it works just fine (iFixit sells the Xbox controller motherboard for $15 each)
2. later, I found the micro switch's model number: "TL3340AF160QG" (<$1 each)
3. I used a soldering iron to install it. It's not easy, but DIY-able. I have very little soldering experience, and I fixed it myself.
4. If you use hot air, don't blow directly on the plastic part of the micro switch because it could easily melt.
Here is the thread where I documented this project: https://mastodon.social/@shaneqi/1100088...
Shane Qi - Responder
This only works if the solder pads don't rip off. I think a lot of us have broken pads and need alternate points of contact
@christianm74231 good point. In that case, we'd still need to wait for the board to be available, or RMA the deck.
Shane Qi -
I don’t suggest others do this, but this is what I did to “fix” my 512 GB deck:
All I had to do was buy a brand new 64 GB Steam Deck and I swapped DBs … The only problem (besides the fact that I had just paid $400 for a new Steam Deck when I only needed the DB) was that the L and R DB were connected by a different number of ribbon cables. My 512 GB Deck had one ribbon cable connecting the L and R DB together whereas the 64 GB Deck had two smaller ribbon cables, so I couldn’t just swap out the one side. Once I swapped both DBs and cables and put it all together, the shoulder buttons worked, but the trackpads could no longer detect pressure, so I couldn’t “click” with them. It wasn’t a huge loss though because I could still use Steam+LT/RT to perform mouse clicks.
Ewww, that's rough honestly seems like an extremely cringe time, AkA " Headache central. "
Hope the best buddy! Things will get better they always do maybe not as fast as we want them too but things WILL GET BETTER I promise!
sgtkickazzttv -
I would also like to know if this part will be restocked again.
Angad - Responder
Will the right button board be restocked?
Angad - Responder
I need THIS PART when will it be available as much trust as I have with Valve Inc. I STILL DONT TRUST ENOUGH TO SEND MY DEVICE FOR REPAIRS ESPECIALLY, when I can repair myself VERY EASLIY, especially since I am extremely electronically inclined THANK GOD! I couldn't imagine being dumb founded working on electronic devices like these.
sgtkickazzttv - Responder
I need.
Valve false claiming water damage so wont repair the bumper tactile button which came loose.
Michael - Responder
A lot of Steam Decks are now past warranty. When will this part be available?
rhomagus.asclepiot - Responder
Parroting x2, when will this piece be available to the public?
chesii - Responder
adding another comment in support - need this button board replaced!
natemate - Responder
jeez.... also need same part.. this is a depressing comment thread.
David Mullen - Responder
I need a Right Button Board. When will it be available?
Chadathan inta - Responder
Bumping like every one else. Any updates on availability for the right daughter board? ZIF connector doesn't want to seat properly so I can no longer use the start button. All I need is the right-hand daughter board (Rev G for the 512GB).
ZW7 - Responder
ZW7,
Unfortunately, the Steam Deck button boards require Valve's special calibration software that still isn't publicly available. We still don't know if/when the boards could be available for purchase.
When will this part be available? Need one. Steam won’t repair mine unless I pay some ridiculous amount.
Collin - Responder
This is honestly really disappointing from Valve. Most Steam Decks are way past their warranty periods and this part should've been made available from day one! I know they have more important things to take care of but then why promise when you can't deliver? I'm hoping this will be made available soon.
Abubakar - Responder
Being annoying like everyone else. Any plans to have the button board(s) back in stock?
BBandos - Responder
Please make this available !
Frank Andrew - Responder
Und wo bestelle ich das Ersatzteil?
Claas P. - Responder
When will this be available....?
Mitchell - Responder
Is this part avalable yet? My R1 button have an issue missclicking alot.
francis théberge - Responder
翁国彬 - Responder
if anyone is reading this, from what I've gathered from threads, Ifixit does not offer this part because it requires factory calibration that no one but valve has access to, so don't blame them for not offering the part. If your bumper switch is broken, and your solder pads are still intact, your best bet is to buy a replacement switch and solder it on yourself or find someone else to do it, that or pay the valve fine for them to fix your deck. It is truly tragic that this part is such a hassle, I know.
Elliott Wood - Responder
A placa não está disponível? Só as ferramentas?
Steves Dias - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 83
Últimos 30 dias: 455
Ao todo: 20,560
