Introdução
Follow this guide to remove and replace a broken screen for your Samsung Galaxy S10. This involves removing the back cover in order to disconnect the screen from the motherboard.
This guide shows how to destructively remove the screen while retaining the original frame.
O que você precisa
Unplug and power off your phone before you begin.
Heat an iOpener and apply it to the back cover's right edge for two minutes.
As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
Press the edge of an opening tool into the seam between the back cover and the frame.
With the opening tool in place in the seam, slide it back and forth along the seam to loosen the back cover.
Heat an iOpener and apply it to the same edge of the phone for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again. The glass is heated enough when it is barely too hot to touch.
You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Slide the opening pick along the edge of the phone, slicing through the adhesive.
Leave a pick in the seam to prevent the adhesive from re-sealing.
Apply a heated iOpener to the bottom edge of the phone for two minutes.
Insert an opening pick into the right edge near the bottom right corner.
Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
Leave an opening pick in the seam to prevent the adhesive from re-sealing.
Remove the eight 4 mm Phillips screws securing the top midframe to the phone.
Lift the midframe from the top corners and remove it from the phone.
To reinstall the top midframe:
Align the midframe's top edge to the phone and lay the frame down on the phone.
Use fingers to apply pressure along the midframe perimeter to snap the midframe clips back into place. The edges should sit flush against the phone edge.
Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
Pry upwards to disconnect the connector from its socket.
Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
Remove the seven 4 mm Phillips screws securing the lower midframe.
Use the flat edge of a spudger to pry up and disconnect the display connector from its motherboard socket.
Flip the phone over so that the display is facing up.
Apply a heated iOpener to the right edge of the screen for two minutes.
Thread the display panel connector through the frame.
If you're having trouble, you can choose to cut the display panel cable in order to remove the display.
After you've completed the repair, follow this guide to test your repair.
30 outras pessoas executaram este guia.
3 comentários
Bonjour, est ce que le téléphone retrouve sa norme ip68 après le changement de l’écran ? merci d’avance
Hello! The repair will not restore IP68 resistance. You normally need specialty presses in order to seal a phone to IP ratings.
Bonjour! Ça ne sera pas. Vous avez besoin de machines spéciales pour restaurer le téléphone sur IP68.
Can the rear lens cover be removed without having to remove the entire back? I have a foggy lens that needs cleaning.
