Ir para o conteúdo principal
Right Joy-Con Joystick Replacement
O que você precisa
  1. Right Joy-Con Joystick Replacement, Remove the back panel screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Remove the four tri-point Y00 screws from the back panel of the Joy-Con.
    • These screws are each 6.2 mm long, but it's still a good idea to keep them organized and make sure they go back in their proper holes!
    Pergunte ao FixBot
    Comentar
  2. Right Joy-Con Joystick Replacement, Open the case: passo 2, imagem 1 %32 Right Joy-Con Joystick Replacement, Open the case: passo 2, imagem 2 %32 Right Joy-Con Joystick Replacement, Open the case: passo 2, imagem 3 %32
    • Insert an opening pick under the lower side of the back panel (opposite the R and ZR buttons).
    • Slide the flat edge of an opening pick up the side of the Joy-Con.
    • Be careful not to slide the opening pick too far inside the Joy-Con. This may damage the inner components. The back panel has shallow interference-fit tabs on the side opposite the charging rail. These loosen fairly easily, so not much pressure is needed.
    Pergunte ao FixBot
    Comentar
  3. Right Joy-Con Joystick Replacement, Open the case: passo 3, imagem 1 %32 Right Joy-Con Joystick Replacement, Open the case: passo 3, imagem 2 %32
    • Open the Joy-Con like a book, with the charging rail facing away from you.
    • Don’t try to fully remove the back panel yet. There are still two cables connecting the charging rail to the motherboard.
    • During reassembly, make sure the SL/SR cable is lightly bent under the battery compartment before clipping the two halves of the joy‑con together. Otherwise, you might crease the cable and damage it.
    Pergunte ao FixBot
    Comentar
  4. Right Joy-Con Joystick Replacement, Disconnect the battery: passo 4, imagem 1 %32 Right Joy-Con Joystick Replacement, Disconnect the battery: passo 4, imagem 2 %32
    • Use a spudger to gently pry the battery connector from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
    • Be extremely careful while you pry up the battery connector. If it does not come up easily, try gently pulling on the wires to disconnect it.
    Pergunte ao FixBot
    Comentar
  5. Right Joy-Con Joystick Replacement, Remove the battery: passo 5, imagem 1 %32 Right Joy-Con Joystick Replacement, Remove the battery: passo 5, imagem 2 %32 Right Joy-Con Joystick Replacement, Remove the battery: passo 5, imagem 3 %32
    • The following two steps show the removal of the battery and the coaxial antenna cable from the midframe. These two steps make for a less cluttered repair, but are not essential. If you want, you can leave the battery and the grey coax cable in place here and proceed to step 7.
    • Insert an opening pick between the battery and the Joy-Con housing. Gently pry out the battery, which is lightly taped in place.
    • Be careful not to deform or puncture the battery—it can catch fire or explode if damaged.
    Pergunte ao FixBot
    Comentar
  6. Right Joy-Con Joystick Replacement, Remove the antenna: passo 6, imagem 1 %32 Right Joy-Con Joystick Replacement, Remove the antenna: passo 6, imagem 2 %32
    • Before you perform this step, take note of how the antenna cable and its PCB are seated for proper reassembly later.
    • Carefully de-thread the upper half of the grey antenna cable out of the battery cavity.
    Pergunte ao FixBot
    Comentar
  7. Right Joy-Con Joystick Replacement, Disconnect the antenna: passo 7, imagem 1 %32 Right Joy-Con Joystick Replacement, Disconnect the antenna: passo 7, imagem 2 %32
    • Pry up with the pointy end of a spudger to disconnect the antenna cable's coaxial connector from the motherboard.
    • Remove the grey antenna cable.
    • During reassembly, reconnect the antenna cable, then make sure it is routed through the battery cavity in the midframe as it was before you took it out.
    Pergunte ao FixBot
    Comentar
  8. Right Joy-Con Joystick Replacement: passo 8, imagem 1 %32
    • Remove the three 3.5 mm Phillips #00 screws on midframe.
    • Do not attempt to remove the midframe yet. There is a fragile cable that still connects the ZR button on the midframe to the motherboard underneath.
    Pergunte ao FixBot
    Comentar
  9. Right Joy-Con Joystick Replacement, Remove the midframe: passo 9, imagem 1 %32 Right Joy-Con Joystick Replacement, Remove the midframe: passo 9, imagem 2 %32
    • Carefully flip the midframe over and away from the motherboard.
    • Do your best not to stress the short ribbon cable attached to the ZR button during this step.
    Pergunte ao FixBot
    Comentar
  10. Right Joy-Con Joystick Replacement, Disconnect the midframe (optional): passo 10, imagem 1 %32 Right Joy-Con Joystick Replacement, Disconnect the midframe (optional): passo 10, imagem 2 %32 Right Joy-Con Joystick Replacement, Disconnect the midframe (optional): passo 10, imagem 3 %32
    • The ZR button cable in this Joy-Con is short and can be tricky to reconnect. You can skip this step and leave it connected, but be careful not to strain it.
    • If you choose to disconnect it:
    • The ZR button cable is locked in place by a small ZIF connector on the motherboard. Use tweezers or a spudger to flip up the ZIF connector lock.
    • Use tweezers to gently pull the ZR button flex cable out of the ZIF connector socket. The midframe is now disconnected and can be removed.
    Pergunte ao FixBot
    Comentar
  11. Right Joy-Con Joystick Replacement, Disconnect the joystick: passo 11, imagem 1 %32 Right Joy-Con Joystick Replacement, Disconnect the joystick: passo 11, imagem 2 %32 Right Joy-Con Joystick Replacement, Disconnect the joystick: passo 11, imagem 3 %32
    • The joystick cable is also locked into place by a ZIF connector. Use tweezers or a spudger to flip the ZIF lock upward and carefully disconnect the cable.
    Pergunte ao FixBot
    Comentar
  12. Right Joy-Con Joystick Replacement: passo 12, imagem 1 %32
    • Remove the two 3.5 mm Phillips #00 screws from the joystick.
    Pergunte ao FixBot
    Comentar
  13. Right Joy-Con Joystick Replacement, Remove the joystick: passo 13, imagem 1 %32 Right Joy-Con Joystick Replacement, Remove the joystick: passo 13, imagem 2 %32 Right Joy-Con Joystick Replacement, Remove the joystick: passo 13, imagem 3 %32
    • Carefully remove the joystick from its housing.
    • There is a thin black gasket around the hole where the joystick pokes through the Joy-Con. Do your best not to disturb this gasket as you remove the joystick!
    • Once the Joy-Con is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick. Additionally, you may need to power cycle your Switch by holding down the power button for 10-15 seconds until it turns off, then turning it back on.
    Pergunte ao FixBot
    Comentar
  14. Right Joy-Con Joystick Replacement, Install the Gulikit joystick ring sticker: passo 14, imagem 1 %32 Right Joy-Con Joystick Replacement, Install the Gulikit joystick ring sticker: passo 14, imagem 2 %32
    • If you've replaced the joystick with a Gulikit module and it came with a joystick ring sticker, follow the next two steps to install it.
    • Use your fingers to pull the thumbstick off of the Gulikit joystick module.
    Pergunte ao FixBot
    Comentar
  15. Right Joy-Con Joystick Replacement: passo 15, imagem 1 %32 Right Joy-Con Joystick Replacement: passo 15, imagem 2 %32 Right Joy-Con Joystick Replacement: passo 15, imagem 3 %32
    • Peel the ring sticker from its liner.
    • If the sticker center is still attached, separate and remove it from the ring.
    • Set the ring sticker in the joystick recess and press it with your fingers for a few seconds to attach it.
    Pergunte ao FixBot
    Comentar
Conclusão
544 outras pessoas executaram este guia.
Equipe
The.idoc.repair Membro de The.idoc.repair
Business
1 Membro
Autoria de 9 guias
69Comentários do guia
A good guide though for the antenna instead of disconnecting the cable it would be easier to simply slide out the plate and wire from the side of the battery tray
Tyler Karabin - Responder Compartilhar
Agree with Tyler - no need to disconnect the antenna.
Thanks for the guide!
David K - Responder Compartilhar
The antenna and battery don’t need to be disconnected, you can easily move them out of the way.
When reassembling, reconnecting the ribbon cable for the RL button is fiddly, easier if you can avoid disconnecting it as well. Just rotate the plastic battery plate a quarter turn counterclockwise to get it out of the way and access the analog stick.
You can test the controller immediately after seating the joystick to make sure the ribbon cable is properly connected.
Peter Amstutz - Responder Compartilhar
In agreement with the others, antenna definitely doesn’t need to be removed. Also noticed that the Y000 bit worked a lot better than the Y00 for the outside screws.
Steve Cazier - Responder Compartilhar
Hello I have followed the guide succesfully for the most part, however the joy con doesn’t seem to power up after reconnecting the battery and the anthenna. I even tried swapping the batteries between joy- cons and battery from the right one does work in the left one. The right joy con doesn’t turn on even with the other battery inserted. Any ideas?
kajterman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 106
Últimos 7 dias: 735
Últimos 30 dias: 3,784
Ao todo: 456,188
