Ir para o conteúdo principal
Reflowing Xbox 360 Motherboard
O que você precisa
  1. Reflowing Xbox 360 Motherboard, Hard Drive: passo 1, imagem 1 %32 Reflowing Xbox 360 Motherboard, Hard Drive: passo 1, imagem 2 %32
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
    Pergunte ao FixBot
    Comentar
  2. Reflowing Xbox 360 Motherboard, Bottom Vent: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    Pergunte ao FixBot
    Comentar
  3. Reflowing Xbox 360 Motherboard: passo 3, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 3, imagem 2 %32 Reflowing Xbox 360 Motherboard: passo 3, imagem 3 %32
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
    Pergunte ao FixBot
    Comentar
  4. Reflowing Xbox 360 Motherboard: passo 4, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 4, imagem 2 %32
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
    Pergunte ao FixBot
    Comentar
  5. Reflowing Xbox 360 Motherboard: passo 5, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 5, imagem 2 %32
    • Repeat the same process to release the two center clips on the bottom vent.
    Pergunte ao FixBot
    Comentar
  6. Reflowing Xbox 360 Motherboard: passo 6, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 6, imagem 2 %32
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
    Pergunte ao FixBot
    Comentar
  7. Reflowing Xbox 360 Motherboard: passo 7, imagem 1 %32
    • Remove the bottom vent from the 360.
    Pergunte ao FixBot
    Comentar
  8. Reflowing Xbox 360 Motherboard, Faceplate: passo 8, imagem 1 %32 Reflowing Xbox 360 Motherboard, Faceplate: passo 8, imagem 2 %32
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
    Pergunte ao FixBot
    Comentar
  9. Reflowing Xbox 360 Motherboard: passo 9, imagem 1 %32
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
    Pergunte ao FixBot
    Comentar
  10. Reflowing Xbox 360 Motherboard: passo 10, imagem 1 %32
    • Remove the faceplate from the front face of the console.
    Pergunte ao FixBot
    Comentar
  11. Reflowing Xbox 360 Motherboard, Top Vent: passo 11, imagem 1 %32 Reflowing Xbox 360 Motherboard, Top Vent: passo 11, imagem 2 %32
    • Stand the console vertically with the top edge facing up.
    • The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
    Pergunte ao FixBot
    Comentar
  12. Reflowing Xbox 360 Motherboard: passo 12, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 12, imagem 2 %32
    • Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
    • You may also use the long finger of an Xbox 360 opening tool to accomplish this task.
    Pergunte ao FixBot
    Comentar
  13. Reflowing Xbox 360 Motherboard: passo 13, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 13, imagem 2 %32 Reflowing Xbox 360 Motherboard: passo 13, imagem 3 %32
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the top vent. Their locations are highlighted in red.
    Pergunte ao FixBot
    Comentar
  14. Reflowing Xbox 360 Motherboard: passo 14, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 14, imagem 2 %32
    • To release the clips, work from the middle of the top vent.
    • While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
    Pergunte ao FixBot
    Comentar
  15. Reflowing Xbox 360 Motherboard: passo 15, imagem 1 %32
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
    Pergunte ao FixBot
    Comentar
  16. Reflowing Xbox 360 Motherboard: passo 16, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 16, imagem 2 %32
    • The last clip is hidden underneath the rubber foot nearest the back of the console.
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
    • Remove the top vent from the 360.
    Pergunte ao FixBot
    Comentar
  17. Reflowing Xbox 360 Motherboard, Lower Case: passo 17, imagem 1 %32
    • Stand the console vertically with the top edge facing down.
    • Carefully peel the warranty sticker off the console.
    Pergunte ao FixBot
    Comentar
  18. Reflowing Xbox 360 Motherboard: passo 18, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 18, imagem 2 %32 Reflowing Xbox 360 Motherboard: passo 18, imagem 3 %32
    • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
    • Use the flat end of a spudger to release the following latches:
    • Above the front-facing USB ports.
    • Beneath the front-facing USB ports.
    • Above the Memory Unit slots.
    Pergunte ao FixBot
    Comentar
  19. Reflowing Xbox 360 Motherboard: passo 19, imagem 1 %32
    • Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
    Pergunte ao FixBot
    Comentar
  20. Reflowing Xbox 360 Motherboard: passo 20, imagem 1 %32
    • Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
    Pergunte ao FixBot
    Comentar
  21. Reflowing Xbox 360 Motherboard: passo 21, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 21, imagem 2 %32
    • The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
    Pergunte ao FixBot
    Comentar
  22. Reflowing Xbox 360 Motherboard: passo 22, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 22, imagem 2 %32 Reflowing Xbox 360 Motherboard: passo 22, imagem 3 %32
    • Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
    • While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
    Pergunte ao FixBot
    Comentar
  23. Reflowing Xbox 360 Motherboard: passo 23, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 23, imagem 2 %32
    • While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
    • The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
    Pergunte ao FixBot
    Comentar
  24. Reflowing Xbox 360 Motherboard: passo 24, imagem 1 %32
    • Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
    • Push the upper and lower cases apart to fully release the retaining clips.
    Pergunte ao FixBot
    Comentar
  25. Reflowing Xbox 360 Motherboard: passo 25, imagem 1 %32
    • Orient the console so that the front portion is facing downwards.
    • Grasp the back portion of the lower case and lift it upwards to separate it from the console.
    • Be careful not to excessively bend the lower case near the power plug, as it can crack easily.
    Pergunte ao FixBot
    Comentar
  26. Reflowing Xbox 360 Motherboard, Eject Button: passo 26, imagem 1 %32 Reflowing Xbox 360 Motherboard, Eject Button: passo 26, imagem 2 %32
    • Use the tip of a spudger to release the clip securing the eject button to the metal casing.
    • Insert the flat end of a spudger between the eject button and the optical drive.
    • Pry the eject button off its retaining posts and remove it from the 360.
    • This can also be accomplished using an Xbox 360 opening tool.
    Pergunte ao FixBot
    Comentar
  27. Reflowing Xbox 360 Motherboard, Upper Case: passo 27, imagem 1 %32
    • Remove the six silver 64 mm T10 Torx screws securing the upper case to the metal casing.
    Pergunte ao FixBot
    Comentar
  28. Reflowing Xbox 360 Motherboard: passo 28, imagem 1 %32
    • Orient the console so that the upper case is facing upwards.
    • Lift the upper case straight up and remove it from the console.
    Pergunte ao FixBot
    Comentar
  29. Reflowing Xbox 360 Motherboard, Optical Drive: passo 29, imagem 1 %32
    • Peel the silver tape securing the optical drive to the metal casing.
    Pergunte ao FixBot
    Comentar
  30. Reflowing Xbox 360 Motherboard: passo 30, imagem 1 %32
    • Slightly lift the optical drive upwards to gain clearance to disconnect the SATA and power connectors located on the backside of the optical drive.
    • Don't try to completely remove the optical drive just yet. Two cables still connect it to the motherboard.
    Pergunte ao FixBot
    Comentar
  31. Reflowing Xbox 360 Motherboard: passo 31, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 31, imagem 2 %32
    • Grab the power connector by its cables and pull it straight out of its socket on the optical drive.
    • Disconnect the SATA data connector from its socket on the optical drive by pulling it straight away.
    Pergunte ao FixBot
    Comentar
  32. Reflowing Xbox 360 Motherboard: passo 32, imagem 1 %32
    • Lift the optical drive assembly out of the metal casing.
    Pergunte ao FixBot
    Comentar
  33. Reflowing Xbox 360 Motherboard, Cooling Fan Duct: passo 33, imagem 1 %32 Reflowing Xbox 360 Motherboard, Cooling Fan Duct: passo 33, imagem 2 %32
    • Insert the flat end of a spudger into the small rectangular opening on the top of the cooling fan duct.
    • Carefully release the fan duct retaining clip and remove the fan duct from the Xbox.
    • The clip can alternatively be released using the metal finger of an Xbox 360 opening tool.
    Pergunte ao FixBot
    Comentar
  34. Reflowing Xbox 360 Motherboard, Dual Fans: passo 34, imagem 1 %32 Reflowing Xbox 360 Motherboard, Dual Fans: passo 34, imagem 2 %32
    • While lifting the metal chassis strip above the dual fans, pull the fans toward the center of the motherboard.
    • Do not completely remove the dual fan assembly yet. Its cable is still attached to the motherboard.
    Pergunte ao FixBot
    Comentar
  35. Reflowing Xbox 360 Motherboard: passo 35, imagem 1 %32
    • Lift the dual fan connector straight up from its socket on the motherboard.
    • Some fan connectors have a locking tab. If yours has a locking tab, be sure to depress it while disconnecting the fan from the motherboard.
    • Remove the dual fan assembly from the console.
    Pergunte ao FixBot
    Comentar
  36. Reflowing Xbox 360 Motherboard, Motherboard: passo 36, imagem 1 %32 Reflowing Xbox 360 Motherboard, Motherboard: passo 36, imagem 2 %32 Reflowing Xbox 360 Motherboard, Motherboard: passo 36, imagem 3 %32
    • Use the flat end of a spudger to release the clips securing the RF module shield along the top and the left edge of the RF module.
    • It may be easier to use your fingernail to release the clips from the RF module.
    • Remove the RF module shield from the console.
    Pergunte ao FixBot
    Comentar
  37. Reflowing Xbox 360 Motherboard: passo 37, imagem 1 %32
    • Remove three 5.6 mm T8 Torx screws securing the RF module to the metal chassis.
    Pergunte ao FixBot
    Comentar
  38. Reflowing Xbox 360 Motherboard: passo 38, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 38, imagem 2 %32
    • Grasp the RF module and lift it straight up to disconnect it from its socket on the motherboard.
    • Remove the RF module from the console.
    Pergunte ao FixBot
    Comentar
  39. Reflowing Xbox 360 Motherboard: passo 39, imagem 1 %32
    • Remove the following screws securing the motherboard to the metal casing:
    • Nine gold 11 mm T10 Torx screws.
    • Eight black 5.6 mm T8 Torx screws.
    • If you are reassembling your Xbox 360 after installing the Red Ring of Death Fix Kit, the eight T8 Torx screws circled in orange are not reused.
    Pergunte ao FixBot
    Comentar
  40. Reflowing Xbox 360 Motherboard: passo 40, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 40, imagem 2 %32
    • Turn the Xbox over, being careful not to let the motherboard fall out of the chassis.
    • Lift the motherboard assembly from its front edge.
    • Be careful not to damage the sockets as you rotate the motherboard away from the metal casing.
    • Remove the motherboard assembly from the metal casing.
    Pergunte ao FixBot
    Comentar
  41. Reflowing Xbox 360 Motherboard, GPU Heat Sink: passo 41, imagem 1 %32
    • Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink.
    • Pry the X clamp away from its retaining post until it is lifted above the small groove cut into the retaining post.
    Pergunte ao FixBot
    Comentar
  42. Reflowing Xbox 360 Motherboard: passo 42, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 42, imagem 2 %32
    • Insert your screwdriver parallel to the motherboard between the X clamp and its retaining post.
    • Twist the screwdriver to fully release the X clamp from its retaining post.
    • Repeat this process for all four corners of the X clamp.
    • When removing the last corner of the X clamp and holding the motherboard upside down, be sure to catch the GPU heat sink to avoid damage from it falling.
    Pergunte ao FixBot
    Comentar
  43. Reflowing Xbox 360 Motherboard: passo 43, imagem 1 %32
    • To reinstall the X clamp, first start by attaching two corners to the posts on the heat sink.
    • While holding the third arm of the X clamp down against the post attached to the heat sink, use a small flathead screwdriver to pry the X clamp away from the heat sink post.
    • As you pry, press down on the arm of the X clamp until you "walk" it down into the retaining groove cut into the post attached to the heat sink.
    • Repeat this process for the fourth arm of the X clamp.
    Pergunte ao FixBot
    Comentar
  44. Reflowing Xbox 360 Motherboard: passo 44, imagem 1 %32
    • Remove the GPU heat sink.
    • Before reinstalling the GPU heat sink, be sure to apply a new layer of thermal paste.
    • If you need to mount the heat sink back onto the motherboard, we have a thermal paste guide that makes replacing the thermal compound easy.
    Pergunte ao FixBot
    Comentar
  45. Reflowing Xbox 360 Motherboard, Motherboard: passo 45, imagem 1 %32 Reflowing Xbox 360 Motherboard, Motherboard: passo 45, imagem 2 %32
    • If necessary, insert your screwdriver parallel to the motherboard between the X clamp and its retaining post. Twist the screwdriver to fully release the X clamp from its retaining post.
    • When removing the last corner of the X clamp and holding the motherboard upside down, be sure to catch the CPU heat sink to avoid damage from it falling.
    • Remove the CPU heat sink from the motherboard. When reinstalling the CPU heat sink, be sure to apply a new layer of thermal paste.
    Pergunte ao FixBot
    Comentar
  46. Reflowing Xbox 360 Motherboard: passo 46, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 46, imagem 2 %32
    • Disconnect the optical drive power and SATA cables from the motherboard.
    Pergunte ao FixBot
    Comentar
  47. Reflowing Xbox 360 Motherboard: passo 47, imagem 1 %32
    • If replacing the motherboard transfer the four thermal pads on the underside of the motherboard to your new motherboard.
    • Motherboard remains.
    • The DVD drive and the motherboard are "married" when they leave the factory. If you replace one you must replace the other. If you put any old DVD drive onto a motherboard that it is not "married" to it will only play DVDs, no games. It is possible to alter the keys so that they match.
    Pergunte ao FixBot
    Comentar
  48. Reflowing Xbox 360 Motherboard, Reflowing Xbox 360 Motherboard: passo 48, imagem 1 %32 Reflowing Xbox 360 Motherboard, Reflowing Xbox 360 Motherboard: passo 48, imagem 2 %32 Reflowing Xbox 360 Motherboard, Reflowing Xbox 360 Motherboard: passo 48, imagem 3 %32
    • Before heating up the motherboard, be sure to clean the old thermal paste off both the CPU and GPU until they are as clean as the processors seen in the first picture. The process for cleaning the processors can be found here.
    • Lay the motherboard with the processor side facing down on the flat metal bottom of the the bare chassis (with its open side facing down) as seen in the second picture. Allow the tall USB socket to hang over the edge of the chassis so the board sits flat.
    • Use a heat gun on the LOW setting to heat the entire back of the motherboard for one minute. Be sure to continually sweep the heat gun back and forth across the face of the motherboard to evenly heat it.
    Pergunte ao FixBot
    Comentar
  49. Reflowing Xbox 360 Motherboard: passo 49, imagem 1 %32
    • After heating the back of the motherboard for one minute, flip the motherboard over and lay it on the chassis as shown.
    • If you have installed the RROD fix kit already, keep the two small black heat sinks included in the kit stuck to their respective chips. The tape that is used to attach them to the chips on the board is extremely strong and attempting to remove them may damage the chips underneath. The heating process will not damage the heat sinks in any way.
    Pergunte ao FixBot
    Comentar
  50. Reflowing Xbox 360 Motherboard: passo 50, imagem 1 %32 Reflowing Xbox 360 Motherboard: passo 50, imagem 2 %32
    • With your heat gun set to HIGH, evenly heat the area boxed in red for four minutes.
    • When using the heat gun on high, it is extremely important to continually move the heat gun so the stream of hot air evenly heats up the desired area.
    • Avoid directly heating the many cylindrical electrolytic capacitors located near the area boxed in red.
    • After heating the area boxed in red for four minutes, turn off your heat gun and allow the motherboard to cool down to room temperature without moving or disturbing it in any way.
    • At this point, we strongly recommend installing our Red Ring of Death Fix Kit to safeguard against future failure.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions from Step 48 in reverse order.
209 outras pessoas executaram este guia.
23Comentários do guia
Is there a similar guide for XBOX 360s?
Juan F Botero - Responder Compartilhar
Yes, there is - and It worked for me!
Yellow Light of Death Repair
Dave - Responder Compartilhar
Is there a similar guide for the E series?
THOMAS LANG - Responder Compartilhar
What temperature ranges should I be aiming for? I have a variable temp head gun and no idea of what temperatures are best for both stages.
Josh - Responder Compartilhar
The heat gun they are using has a 570 F low-setting. While that doesn't give you an EXACT temperature, it should give you some idea of what they're using.
Sam Archer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 83
Últimos 30 dias: 402
Ao todo: 292,445
