Ir para o conteúdo principal
Porter-Cable PCC710B Motor Replacement
O que você precisa
    1. Porter-Cable PCC710B Motor Replacement, Lever assembly: passo 1, imagem 1 %32
      • Place the tool on its side so the orange and white warning label barcodes are facing up.
      • The lever and battery base of the tool should point toward you.
      Pergunte ao FixBot
      Comentar
    2. Porter-Cable PCC710B Motor Replacement: passo 2, imagem 1 %32 Porter-Cable PCC710B Motor Replacement: passo 2, imagem 2 %32 Porter-Cable PCC710B Motor Replacement: passo 2, imagem 3 %32
      • Use a 5.5 mm nut driver to unscrew the Hex nut.
      • If the Hex nut is not unscrewing easily- you can use a 3 mm Hex head screwdriver to hold the other side of the screw still.
      Pergunte ao FixBot
      Comentar
    3. Porter-Cable PCC710B Motor Replacement: passo 3, imagem 1 %32
      • Flip the tool over and remove the black screw holding the tool together.
      • Get a good grip on the screw by using pliers to pull the screw out of the tool.
      Pergunte ao FixBot
      Comentar
    4. Porter-Cable PCC710B Motor Replacement: passo 4, imagem 1 %32 Porter-Cable PCC710B Motor Replacement: passo 4, imagem 2 %32 Porter-Cable PCC710B Motor Replacement: passo 4, imagem 3 %32
      • Pinch the lever with your fingers and pull it up and away from the tool. The lever pops right off! You can squeeze on the lever, and it will come off just as easily.
      • When replacing your new lever assembly, make sure the black torsion (the black staple-like hinge) is oriented correctly.
      Pergunte ao FixBot
      Comentar
    1. Porter-Cable PCC710B Motor Replacement, Housing: passo 5, imagem 1 %32 Porter-Cable PCC710B Motor Replacement, Housing: passo 5, imagem 2 %32 Porter-Cable PCC710B Motor Replacement, Housing: passo 5, imagem 3 %32
      • Lay the tool on its side so that the grey and orange warning labels are facing up upwards.
      • Use the JIS #1 screwdriver to remove the 10 screws holding the tool together.
      Pergunte ao FixBot
      Comentar
    2. Porter-Cable PCC710B Motor Replacement: passo 6, imagem 1 %32 Porter-Cable PCC710B Motor Replacement: passo 6, imagem 2 %32 Porter-Cable PCC710B Motor Replacement: passo 6, imagem 3 %32
      • Lift the case off to access the internals of the tool.
      Pergunte ao FixBot
      Comentar
    1. Porter-Cable PCC710B Motor Replacement, Spindle assembly: passo 7, imagem 1 %32 Porter-Cable PCC710B Motor Replacement, Spindle assembly: passo 7, imagem 2 %32 Porter-Cable PCC710B Motor Replacement, Spindle assembly: passo 7, imagem 3 %32
      • The outstretched arms of the spindle will be covered in grease - so grab a napkin to keep your hands clean!
      • Grasp the bottom of the spindle and pull it out towards you.
      • The spindle should come out easily. If not, lightly twist the object left and right while pulling it out.
      • You must grease the new spindle's arms before the install or else these parts will overheat and break. In addition, you'll have to maneuver the arms of the spindle around the head of the eccentric shaft. Finally, apply a light force to snap the spindle into place.
      Pergunte ao FixBot
      Comentar
    1. Porter-Cable PCC710B Motor Replacement, Eccentric shaft: passo 8, imagem 1 %32 Porter-Cable PCC710B Motor Replacement, Eccentric shaft: passo 8, imagem 2 %32 Porter-Cable PCC710B Motor Replacement, Eccentric shaft: passo 8, imagem 3 %32
      • Gently pull the motor out of the case.
      • To remove the eccentric shaft simply pull it off of the motor.
      • When replacing the eccentric shaft, you must grease it before the install or else it'll overheat and break. The black fan shaped part of the eccentric shaft should slide onto the thin rod of the motor until it clicks securely.
      Pergunte ao FixBot
      Comentar
    1. Porter-Cable PCC710B Motor Replacement, Motor: passo 9, imagem 1 %32 Porter-Cable PCC710B Motor Replacement, Motor: passo 9, imagem 2 %32 Porter-Cable PCC710B Motor Replacement, Motor: passo 9, imagem 3 %32
      • Gently remove the motor with your hands.
      • You'll have to pull out the circuit board and all of its connections too in order to properly work on the motor.
      • Be gentle, everything will come out easily without much effort.
      Pergunte ao FixBot
      Comentar
    2. Porter-Cable PCC710B Motor Replacement: passo 10, imagem 1 %32 Porter-Cable PCC710B Motor Replacement: passo 10, imagem 2 %32 Porter-Cable PCC710B Motor Replacement: passo 10, imagem 3 %32
      • You'll need your soldering equipment for the remaining steps.
      • Desolder the red wire from the motor and then the black wire.
      • Once the solder connection melts, pull the wires from the motor.
      • Once both connections are severed, wait 2-3 minutes for the ends of the wires to cool before handling them!
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 18
Ao todo: 631
