Ir para o conteúdo principal
Wire Stripping
O que você precisa
    1. Wire Stripping, Wire Stripping: passo 1, imagem 1 %32
      • Match your gauge of wire to the gauge on a wire stripper.
      • Some wire strippers will have two gauge sizes for the same hole, one for solid wire and one for stranded. Make sure you use the right one for the wire you are stripping!
      Pergunte ao FixBot
      Comentar
    2. Wire Stripping: passo 2, imagem 1 %32
      • Place the wire stripper about a 1/4” from the end of the wire and squeeze down.
      • You can strip more than 1/4" at a time, but the effort becomes harder. About 1/2-5/8" (13-16 mm) is the most you should probably attempt.
      Pergunte ao FixBot
      Comentar
    3. Wire Stripping: passo 3, imagem 1 %32
      • While squeezing, pull the stripper toward the end of the wire. This should expose some of the wire by removing its insulation.
      Pergunte ao FixBot
      Comentar
Conclusão
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
23 outras pessoas executaram este guia.
nat coll
Membro desde: 09/27/12
859 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 7-53, Forte Fall 2012 Membro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membros
Autoria de 47 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 87
Últimos 30 dias: 341
Ao todo: 13,129
