Ir para o conteúdo principal
Opening Procedure
O que você precisa
    1. Opening Procedure, Power down your watch: passo 1, imagem 1 %32 Opening Procedure, Power down your watch: passo 1, imagem 2 %32
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Pergunte ao FixBot
      Comentar
    2. Opening Procedure, Unfasten the back cover: passo 2, imagem 1 %32
      • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
      Pergunte ao FixBot
      Comentar
    3. Opening Procedure, Loosen the back cover adhesive: passo 3, imagem 1 %32
      • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Pergunte ao FixBot
      Comentar
    4. Opening Procedure, Pry up the back cover assembly: passo 4, imagem 1 %32 Opening Procedure, Pry up the back cover assembly: passo 4, imagem 2 %32 Opening Procedure, Pry up the back cover assembly: passo 4, imagem 3 %32
      • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
      • Pry upwards to loosen the back cover assembly. This may require some force.
      • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
      • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
      Pergunte ao FixBot
      Comentar
    5. Opening Procedure, Disconnect the sensor assembly cable: passo 5, imagem 1 %32 Opening Procedure, Disconnect the sensor assembly cable: passo 5, imagem 2 %32
      • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Pergunte ao FixBot
      Comentar
    6. Opening Procedure, Remove the back cover assembly: passo 6, imagem 1 %32 Opening Procedure, Remove the back cover assembly: passo 6, imagem 2 %32 Opening Procedure, Remove the back cover assembly: passo 6, imagem 3 %32
      • Remove the back cover assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
3 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
262.506 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 45.149 guias
2Comentários do guia
Whelp. I got it open thanks to this guide, but there's nothing I can see that would fix my main/power button not being responsive (thus the watch won't turn on anymore). Thanks anyway!
Hailey R - Responder Compartilhar
Heb de batterij van mijn Ticwatch Pro 3 ultra succesvol kunnen vervangen. Ik zou enkel de specialized watch adhesive tape nog moeten hebben voor deze horloge om hem terug waterproof te hebben?
Patrick Vercammen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 63
Ao todo: 2,436
