Introdução
Use this guide to replace the screen in your Nintendo Switch OLED.
Unlike the original model's plastic cover and LCD backing, the Switch OLED's screen is a glass cover that's fused to an OLED display.
This means there's a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
For your safety, discharge the battery below 25% before disassembling your Switch. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
The Switch OLED uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Since normal thermal paste isn’t designed to bridge large gaps, the closest replacement is K5 Pro viscous thermal paste.
You'll need replacement adhesive in order to complete this repair.
O que você precisa
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
Use your finger to flip up the kickstand on the back of the device.
Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
Lift the rear case up from the top of the device and remove it.
Just a heads up that, even after removing the screws, the rear plate is still heavily clipped in place. I recommend using an opening pick or opening tool to carefully pry it up starting at the top and working your way down the sides. Once you get to the bottom, the speaker grilles are a little tricky. They're attached to the rear plate, but they can get stuck easily as you're removing the back plate.
Use the flat end of a spudger to separate a corner of the tape from the shield plate.
Don't remove the antenna tape or the wires from the tape! The antennae can come off with the large metal shield plate anyways, so why remove them separately?? Extra UNNECESSARY WORK!! Just unscrew the antennae modules themselves, and pop out the antenna wires from the mainboard. Then they will lift with the large metal plate. (Steps 10, 11, 15, 16 are unnecessary, just remove the screws only that hold them down)
Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
Use the point of a spudger to pry up and disconnect the battery.
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
Insert a spudger between the edge of the daughterboard and the motherboard.
Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
Remove the daughterboard.
Use an opening tool, spudger, or your fingernail to flip up the hinged locking flap on the display's ZIF connector.
Apply a heated iOpener to the right edge of the screen for 90 seconds to loosen the adhesive underneath.
Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the screen and the frame.
Insert an opening pick into the gap between the frame and the screen.
This step took quite a long time to complete. The adhesive on my switch was very strong, and required several repetitive cycles of heating and suctioning. One of the iFixit teardown videos of the OLED switch mentions using "consistent suction" to pull up the screen. I replaced the plastic lever on my suction cup with a metal chopstick. It helped with a very persistent and consistent pull that eventually separated the screen from the frame.
Same as comment above, this adhesive is very strong and rigid. The iOpener didnt work for me on this stage after many times. I finally I used a soldering heat gun set at 215 F for about 15 seconds. That worked really well because I was able to leave the suction cup attached and apply constant pull while the warm air was heating the adhesive. Once you get the first pick in there, the rest is much easier.
Slide the pick along the right edge of the screen to separate the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Apply a heated iOpener to the top edge of the device for 90 seconds to loosen the adhesive underneath.
Insert a new opening pick into the gap you created.
Rotate the opening pick around the top-right corner of the device.
Slide the new pick along the right edge of the device towards the top-left corner.
Repeat the heating and slicing process on the remaining edges to separate the adhesive.
Ferramenta utilizada neste passo:Tesa 61395 Tape$5.99
Lift the screen off the device, threading the display cable through the frame as you do.
Which width of sticky tape is needed? I’d like to have everything ready before I open it up!
Hi Claire!
We don't typically give widths because you could realistically use 1-4 mm tape or even two side-by-side layers of 1 mm if you don't want to buy 2 mm tape, but you're right that we should have limits or recommendations! For this repair, 2 mm tape should work well. You can also use multiple layers of 1 mm depending on what future repairs you want to use with the leftover tape.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
11 outras pessoas executaram este guia.
9 comentários
Amazing guide! Steps were easy to follow and allowed me to knock out my Switch OLED screen replacement in about 1.5-2 hours, including a few intermissions to clean the internals. The only thing I would add to this guide are a few steps at the end for removing the old adhesive, applying the new Tesa tape, folding/threading the ribbon cable on the new screen, and plugging the ribbon cable into the Switch to make this a true one-stop shop. The 1mm Tesa tape worked like a charm, although there is one side of the screen frame where you need to do three strips instead of one, you don't have to buy a bigger size just for that side. Thanks again iFixit! Y'all rock!
Hi Kyle.
Thank you for the appreciation and the tips! I changed the last step a bit to hopefully remind people to re-thread the display cable. We will consider making a dedicated reassembly step ;)
nope not doin this
I stripped a screw on my Nintendo Switch OLED, now there’s absolutely no way for me to open it, I wanted to replace my Nintendo Switch Card Cover, and now I can’t. I’m gonna have to get a new Switch now :(
Oh my goodness, I'm sorry to hear that! We've all been there. If you're willing to try something to remove the stripped screw, you can check out this guide for some strategies. Please let us know how it works out!
Thanks for these great instructions, much easier than following a video. I couldn’t find which width of Tesa tape to use, I used 2mm which worked fine. Was also unsure how much heat-conducting paste to use, so I guessed! My biggest problem ( nothing to do with the instructions); was that the old screen was so firmly stuck that it wouldn’t lift at all, it was only possible to remove it by breaking it some more. Anyway, new screen is now fitted, so my kids are going to be very happy to be able to use it in handheld mode again.
Hi,
Do you have this tutorial in Spanish?
Nice job!
Regrets from Honduras.
Sincerely,
Gerardo Carbajal
He seguido tus pasos al pie de la letra, pero he usado un secador de pelo para separar la pantalla, a distancia corta de la misma, solo en los bordes, con un tiempo inferior a 20 segundos. Antes de separar la pantalla antigua he probado la nueva y funcionaba correctamente aunque ambas presentaban el problema de no funcionar el tactil, aun asi segui en mi cruzada y monte la pantalla nueva sabiendo que ya funcionaba ( al menos la imagen ) y al tratar de encenderla la pantalla no mostraba imagen, pense que era la bateria y lo conecte a la corriente, al intentar de nuevo sono un bip pero no habia imagen, pense que habia cometido algun error asi probe la pantalla antigua y nada, sin imagen, a que podria deberse este problema?
