Ir para o conteúdo principal
Nintendo Switch OLED Model Battery Replacement
O que você precisa
  1. Nintendo Switch OLED Model Battery Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 3 %32
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Battery Replacement, Remove the Joy Con controllers: passo 2, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the Joy Con controllers: passo 2, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement, Remove the Joy Con controllers: passo 2, imagem 3 %32
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Battery Replacement, Remove the top screw: passo 3, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the top screw: passo 3, imagem 2 %32
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
  4. Nintendo Switch OLED Model Battery Replacement, Remove the bottom screws: passo 4, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the bottom screws: passo 4, imagem 2 %32
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Battery Replacement, Remove the right screw: passo 5, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the right screw: passo 5, imagem 2 %32
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  6. Nintendo Switch OLED Model Battery Replacement, Remove the left screw: passo 6, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the left screw: passo 6, imagem 2 %32
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
  7. Nintendo Switch OLED Model Battery Replacement, Open the kickstand: passo 7, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Open the kickstand: passo 7, imagem 2 %32
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Battery Replacement, Remove the back-side screws: passo 8, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the back-side screws: passo 8, imagem 2 %32
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
  9. Nintendo Switch OLED Model Battery Replacement, Remove the rear case: passo 9, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the rear case: passo 9, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement, Remove the rear case: passo 9, imagem 3 %32
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
  10. Nintendo Switch OLED Model Battery Replacement, Remove the shield plate's tape: passo 10, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the shield plate's tape: passo 10, imagem 2 %32
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
  11. Nintendo Switch OLED Model Battery Replacement: passo 11, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement: passo 11, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Battery Replacement, Disconnect the primary Wi-Fi antenna: passo 12, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Disconnect the primary Wi-Fi antenna: passo 12, imagem 2 %32
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Battery Replacement, Reroute the primary antenna's coaxial cable: passo 13, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Reroute the primary antenna's coaxial cable: passo 13, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement, Reroute the primary antenna's coaxial cable: passo 13, imagem 3 %32
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Battery Replacement, Unfasten the primary Wi-Fi antenna: passo 14, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Unfasten the primary Wi-Fi antenna: passo 14, imagem 2 %32
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Battery Replacement, Remove the primary Wi-Fi antenna: passo 15, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the primary Wi-Fi antenna: passo 15, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement, Remove the primary Wi-Fi antenna: passo 15, imagem 3 %32
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Battery Replacement: passo 16, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement: passo 16, imagem 2 %32
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Battery Replacement, Disconnect the secondary Wi-Fi antenna: passo 17, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Disconnect the secondary Wi-Fi antenna: passo 17, imagem 2 %32
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Battery Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: passo 18, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: passo 18, imagem 2 %32
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Battery Replacement, Unfasten the secondary Wi-Fi antenna: passo 19, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Unfasten the secondary Wi-Fi antenna: passo 19, imagem 2 %32
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Battery Replacement, Remove the secondary Wi-Fi antenna: passo 20, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the secondary Wi-Fi antenna: passo 20, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement, Remove the secondary Wi-Fi antenna: passo 20, imagem 3 %32
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Battery Replacement: passo 21, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement: passo 21, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement: passo 21, imagem 3 %32
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Battery Replacement, Unfasten the shield plate: passo 22, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Unfasten the shield plate: passo 22, imagem 2 %32
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Battery Replacement: passo 23, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement: passo 23, imagem 2 %32
    iFixit Thermal Putty
    $9.95
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
  24. Nintendo Switch OLED Model Battery Replacement, Disconnect the battery: passo 24, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Disconnect the battery: passo 24, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the battery.
  25. Nintendo Switch OLED Model Battery Replacement, Apply isopropyl alcohol: passo 25, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Apply isopropyl alcohol: passo 25, imagem 2 %32
    iFixit Adhesive Remover
    $19.99
    • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol inside the battery well along the top edge to weaken the adhesive.
    • Make sure not to puncture the battery with the isopropyl alcohol's applicator.
    • If you are using adhesive remover, follow these preparation steps first.
  26. Nintendo Switch OLED Model Battery Replacement: passo 26, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement: passo 26, imagem 2 %32
    • Tilt the top edge of the device upward to allow the isopropyl alcohol to work its way underneath the battery.
    • Hold for 1-2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
  27. Nintendo Switch OLED Model Battery Replacement, Separate the battery's adhesive: passo 27, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Separate the battery's adhesive: passo 27, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement, Separate the battery's adhesive: passo 27, imagem 3 %32
    • Insert an opening pick into the gap between the battery and the wall of the battery well.
    • Carefully dig the tip of the opening pick underneath the battery and slide it along the edge to begin slicing the adhesive.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
  28. Nintendo Switch OLED Model Battery Replacement: passo 28, imagem 1 %32
    • Leave the opening pick in place and apply a few more drops of adhesive remover or isopropyl alcohol inside the battery well.
    • Tilt the top edge of the device upward and wait 1-2 minutes for the isopropyl alcohol to weaken the adhesive.
  29. Nintendo Switch OLED Model Battery Replacement: passo 29, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement: passo 29, imagem 2 %32
    • Continue sliding the opening pick deeper along the top edge of the battery, slicing more of the adhesive underneath.
  30. Nintendo Switch OLED Model Battery Replacement: passo 30, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement: passo 30, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement: passo 30, imagem 3 %32
    Plastic Cards
    $2.99
    • Once there's enough room, insert a plastic card underneath the battery and slowly pry the battery up.
    • Apply more isopropyl alcohol if you have difficulty prying.
    • Be careful not to bend the battery as you pry.
  31. Nintendo Switch OLED Model Battery Replacement, Remove the battery: passo 31, imagem 1 %32 Nintendo Switch OLED Model Battery Replacement, Remove the battery: passo 31, imagem 2 %32 Nintendo Switch OLED Model Battery Replacement, Remove the battery: passo 31, imagem 3 %32
    • Pry up with the plastic card to completely separate the battery's adhesive.
    • Remove the battery.
    • Use adhesive remover or isopropyl alcohol and a microfiber cloth to clean up any remaining adhesive left behind in the battery well before you install the new battery.
    • If your new battery does not come with pre-installed adhesive, follow this guide to install pre-cut adhesive on the bottom of the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
11 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
213.338 Reputação
Autoria de 1.040 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.639 guias
2Comentários do guia
Worked well. In step 9 I found I had to loosen all screws on the joycon sides as the case really wouldn’t move and it was hard to see where it was ”locked”. When tilting for the isoprop alocohol, really do not over tilt or the alocohol will leak out from the cable hole. The old adhesive under the battery was really strong - don’t give up but don’t expect removal to be easy. But be slow and careful and stick with it and it will come loose eventually. Finally, K5 Pro is not available where I live - used MX-6 instead and it appears to work fine. Other than that, thank you for the guide - very helpful and my switch is as new again.
Stefan - Responder
Es ist etwas schwer den Deckel der Switch abzubekommen, aber mit etwas hebeln geht der dann doch ab. Schwieriger war es jedoch den Akku vom Klebestreifen zu lösen. Ich habe von der Kabelseite die Plastikkarte ein wenig eingeschoben und dann immer von links nach rechts bewegt und dabei leicht rein geschoben. Ansonsten sind die Anleitung von IFIXIT sind Top und ich habe schon einiges danach selbst reparieren können. Schön das es euch gibt.
Rüdiger Jonas - Responder
Comentar
Visualizações:
Últimas 24 horas: 53
Últimos 7 dias: 387
Últimos 30 dias: 1,814
Ao todo: 61,890
