Ir para o conteúdo principal
iFixit Adhesive Remover Preparation
O que você precisa
  1. iFixit Adhesive Remover Preparation, iFixit Adhesive Remover Preparation: passo 1, imagem 1 %32 iFixit Adhesive Remover Preparation, iFixit Adhesive Remover Preparation: passo 1, imagem 2 %32
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
    Pergunte ao FixBot
    Comentar
  2. iFixit Adhesive Remover Preparation: passo 2, imagem 1 %32 iFixit Adhesive Remover Preparation: passo 2, imagem 2 %32 iFixit Adhesive Remover Preparation: passo 2, imagem 3 %32
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
15 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
344.141 Reputação
Autoria de 915 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 32.107 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 100
Últimos 30 dias: 442
Ao todo: 27,397
