Ir para o conteúdo principal
Nintendo Switch Lite Fan Replacement
O que você precisa
  1. Nintendo Switch Lite Fan Replacement, Remove the back panel screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Switch Lite Fan Replacement, Remove the top and bottom back panel screws: passo 2, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Remove the top and bottom back panel screws: passo 2, imagem 2 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Switch Lite Fan Replacement, Release the clips securing the back panel: passo 3, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Release the clips securing the back panel: passo 3, imagem 2 %32
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Switch Lite Fan Replacement, Continue releasing the clips around the device: passo 4, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Continue releasing the clips around the device: passo 4, imagem 2 %32
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Switch Lite Fan Replacement, Twist to release the clips: passo 5, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Twist to release the clips: passo 5, imagem 2 %32
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
    Pergunte ao FixBot
    Comentar
  6. Nintendo Switch Lite Fan Replacement, Slide and pry around the corners: passo 6, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Slide and pry around the corners: passo 6, imagem 2 %32
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
    Pergunte ao FixBot
    Comentar
  7. Nintendo Switch Lite Fan Replacement: passo 7, imagem 1 %32 Nintendo Switch Lite Fan Replacement: passo 7, imagem 2 %32
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
    Pergunte ao FixBot
    Comentar
  8. Nintendo Switch Lite Fan Replacement, Remove the back panel: passo 8, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Remove the back panel: passo 8, imagem 2 %32 Nintendo Switch Lite Fan Replacement, Remove the back panel: passo 8, imagem 3 %32
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
    Pergunte ao FixBot
    Comentar
  9. Nintendo Switch Lite Fan Replacement, Remove the shield plate: passo 9, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the four screws securing the shield plate:
    • Three 3.1 mm screws
    • One 4.5 mm screw
    Pergunte ao FixBot
    Comentar
  10. Nintendo Switch Lite Fan Replacement: passo 10, imagem 1 %32 Nintendo Switch Lite Fan Replacement: passo 10, imagem 2 %32 Nintendo Switch Lite Fan Replacement: passo 10, imagem 3 %32
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
    Pergunte ao FixBot
    Comentar
  11. Nintendo Switch Lite Fan Replacement, Disconnect the interconnect cable: passo 11, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Disconnect the interconnect cable: passo 11, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  12. Nintendo Switch Lite Fan Replacement: passo 12, imagem 1 %32 Nintendo Switch Lite Fan Replacement: passo 12, imagem 2 %32
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  13. Nintendo Switch Lite Fan Replacement, Disconnect the battery: passo 13, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Disconnect the battery: passo 13, imagem 2 %32
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
    Pergunte ao FixBot
    Comentar
  14. Nintendo Switch Lite Fan Replacement, Remove the heat sink: passo 14, imagem 1 %32
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    Pergunte ao FixBot
    Comentar
  15. Nintendo Switch Lite Fan Replacement: passo 15, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    Pergunte ao FixBot
    Comentar
  16. Nintendo Switch Lite Fan Replacement: passo 16, imagem 1 %32 Nintendo Switch Lite Fan Replacement: passo 16, imagem 2 %32 Nintendo Switch Lite Fan Replacement: passo 16, imagem 3 %32
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    Pergunte ao FixBot
    Comentar
  17. Nintendo Switch Lite Fan Replacement, Remove the fan: passo 17, imagem 1 %32 Nintendo Switch Lite Fan Replacement, Remove the fan: passo 17, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  18. Nintendo Switch Lite Fan Replacement: passo 18, imagem 1 %32 Nintendo Switch Lite Fan Replacement: passo 18, imagem 2 %32
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  19. Nintendo Switch Lite Fan Replacement: passo 19, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 4.8 mm screws securing the fan.
    Pergunte ao FixBot
    Comentar
  20. Nintendo Switch Lite Fan Replacement: passo 20, imagem 1 %32 Nintendo Switch Lite Fan Replacement: passo 20, imagem 2 %32 Nintendo Switch Lite Fan Replacement: passo 20, imagem 3 %32
    • Remove the fan.
    • Take care not to snag the fan cable on the motherboard as you remove the fan.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
9 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
42.897 Reputação
Autoria de 82 guias
2Comentários do guia
I used this guide to put my new fan in and let me just say THANK YOU!!! All I could find was ones for regular Switches on YouTube and not the Lite. The only problem I had was I'm not sure which side of the cable on the fan should be facing up. I looked on your website and the fan listen on here has one side with a gold part at the end where you insert it into the connector. Is that the side that goes up?
Skylar Neville - Responder Compartilhar
Many thanks for this guide it helped me so much it was pretty straight forward to do but attaching the fan ribbon/power cord and trying not to strip the tiny screws heads was probably the hardest bits really
FMG_MADLOO87 (MADLOO) - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 91
Últimos 30 dias: 446
Ao todo: 25,677
