Ir para o conteúdo principal
Nintendo Switch Left Joy Con Sensor Rail Replacement
O que você precisa
  1. Nintendo Switch Left Joy Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 2 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 3 %32
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the Joy Con controllers: passo 2, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the Joy Con controllers: passo 2, imagem 2 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the Joy Con controllers: passo 2, imagem 3 %32
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the back-side screws: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the top and bottom screws: passo 4, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the top and bottom screws: passo 4, imagem 2 %32
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the center side screws: passo 5, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the center side screws: passo 5, imagem 2 %32
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    Pergunte ao FixBot
    Comentar
  6. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 6, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 6, imagem 2 %32
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    Pergunte ao FixBot
    Comentar
  7. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the kickstand well screw: passo 7, imagem 1 %32
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
    Pergunte ao FixBot
    Comentar
  8. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the rear panel: passo 8, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the rear panel: passo 8, imagem 2 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the rear panel: passo 8, imagem 3 %32
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel straight up from the bottom of the device and remove it.
    • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
    Pergunte ao FixBot
    Comentar
  9. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the microSD card reader: passo 9, imagem 1 %32
    • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
    Pergunte ao FixBot
    Comentar
  10. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 10, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 10, imagem 2 %32
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
    Pergunte ao FixBot
    Comentar
  11. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the shield plate: passo 11, imagem 1 %32
    • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
    Pergunte ao FixBot
    Comentar
  12. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 12, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 12, imagem 2 %32
    • If the console doesn't have this foam, skip this step.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
    Pergunte ao FixBot
    Comentar
  13. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 13, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 13, imagem 2 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 13, imagem 3 %32
    iFixit Thermal Putty
    $9.95
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
    Pergunte ao FixBot
    Comentar
  14. Nintendo Switch Left Joy Con Sensor Rail Replacement, Disconnect the battery: passo 14, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Disconnect the battery: passo 14, imagem 2 %32
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    Pergunte ao FixBot
    Comentar
  15. Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the left Joy Con sensor rail: passo 15, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement, Remove the left Joy Con sensor rail: passo 15, imagem 2 %32
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the Joy Con rail data cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  16. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 16, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 16, imagem 2 %32
    • Use a pair of tweezers to slide the Joy Con rail data cable out of its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  17. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 17, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 17, imagem 2 %32
    • Use your fingers or a pair of tweezers to lift the battery connector up and out of the way of the Joy Con rail's data cable.
    Pergunte ao FixBot
    Comentar
  18. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 18, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 18, imagem 2 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 18, imagem 3 %32
    • Use your fingers or a pair of tweezers to slide the Joy Con rail data cable out from under the motherboard.
    Pergunte ao FixBot
    Comentar
  19. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 19, imagem 1 %32
    • Use a JIS 00 driver to remove the four 3.7 mm screws securing the left Joy Con rail to the frame of the device.
    • These screws are torqued down and can be difficult to remove. To prevent them from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    Pergunte ao FixBot
    Comentar
  20. Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 20, imagem 1 %32 Nintendo Switch Left Joy Con Sensor Rail Replacement: passo 20, imagem 2 %32
    • Remove the left Joy Con sensor rail from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
80 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
42.851 Reputação
Autoria de 82 guias
9Comentários do guia
If this was a neon Switch, this would be the rail that gets attached with the blue or the red joy con?
felipemanzur21 - Responder Compartilhar
it would be the Blue joy con
Nick Heilman - Responder Compartilhar
I completed this guide, but the left joy con is still not being detected after the sensor rail was replaced with a sensor rail purchased on this site. The joy con in question will attach and sync with another console, so that leads me to believe it is a fault with the switch console itself. Is there something else that I can replace that would fix this issue?
Sean Douglas - Responder Compartilhar
Depending on where you get your replacement rail, it may not have the silver on the ribbon cable. No worries, as I did this repair 3 months ago (Jan) and had no issues at all.
To get the ribbon cable in place, I recommend first getting the battery wires out of the way, then slightly bending it and sliding it under that section of the Motherboard. If you do it right, the end of the ribbon cable will pop up and that can be slid into place. Took some fiddling but I eventually got it to work!
No matter what, never crease your ribbon cables!
Yakarot Sennin - Responder Compartilhar
I have a joycon where it will disconnect if it is slotted all the way down. I have to push it up about 1mm for it to stay connected. The joycon works perfectly on other Switch consoles. Any idea of what troubleshooting I can try before replacing the whole rail?
Azrael - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 81
Últimos 7 dias: 349
Últimos 30 dias: 1,371
Ao todo: 158,590
