Ir para o conteúdo principal
Moto Z Battery Replacement
O que você precisa
  1. Moto Z Battery Replacement, Display Assembly: passo 1, imagem 1 %32
    • Heat an iOpener and apply it to the left edge of the phone for at least 90 seconds.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
    Pergunte ao FixBot
    Comentar
  2. Moto Z Battery Replacement: passo 2, imagem 1 %32 Moto Z Battery Replacement: passo 2, imagem 2 %32
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • To avoid damage, do not cut in the following areas:
    • The OLED panel
    • The home button
    • The flash unit
    Pergunte ao FixBot
    Comentar
  3. Moto Z Battery Replacement: passo 3, imagem 1 %32 Moto Z Battery Replacement: passo 3, imagem 2 %32 Moto Z Battery Replacement: passo 3, imagem 3 %32
    • Apply a suction cup as close to the heated edge as possible.
    • Lift on the suction cup and insert the tip of an opening pick into the gap.
    • Do not insert the pick more than 1/16" (1.5 mm). Over-inserting the pick may damage the OLED panel.
    Pergunte ao FixBot
    Comentar
  4. Moto Z Battery Replacement: passo 4, imagem 1 %32 Moto Z Battery Replacement: passo 4, imagem 2 %32 Moto Z Battery Replacement: passo 4, imagem 3 %32
    • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
    • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
    • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  5. Moto Z Battery Replacement: passo 5, imagem 1 %32
    • Repeat the heating, lifting, and cutting steps for the remaining long edge of the phone.
    Pergunte ao FixBot
    Comentar
  6. Moto Z Battery Replacement: passo 6, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  7. Moto Z Battery Replacement: passo 7, imagem 1 %32 Moto Z Battery Replacement: passo 7, imagem 2 %32
    • Insert an opening pick into the flash side corner of the phone and carefully slice around the flash unit.
    • Do not insert the pick more than 1/16" (1.5 mm) into the edge.
    • Once you are done cutting, leave the pick in the corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  8. Moto Z Battery Replacement: passo 8, imagem 1 %32 Moto Z Battery Replacement: passo 8, imagem 2 %32 Moto Z Battery Replacement: passo 8, imagem 3 %32
    • Insert an opening pick into the remaining top corner of the phone.
    • Carefully slice through the adhesive across the top of the phone.
    • Do not insert the pick beyond 1/2" (12.5 mm).
    Pergunte ao FixBot
    Comentar
  9. Moto Z Battery Replacement: passo 9, imagem 1 %32
    • Apply a heated iOpener to the bottom edge of the phone for at least 90 seconds.
    Pergunte ao FixBot
    Comentar
  10. Moto Z Battery Replacement: passo 10, imagem 1 %32 Moto Z Battery Replacement: passo 10, imagem 2 %32 Moto Z Battery Replacement: passo 10, imagem 3 %32
    • Insert an opening pick into a bottom corner and slice towards the home button, stopping before you reach it.
    • Once you're done with the corner, leave a pick in place to prevent the adhesive from sealing.
    • Repeat the process for the other bottom corner.
    Pergunte ao FixBot
    Comentar
  11. Moto Z Battery Replacement: passo 11, imagem 1 %32 Moto Z Battery Replacement: passo 11, imagem 2 %32
    • Carefully twist the first opening pick slightly to help release the edge adhesive.
    • Repeat the same process for each remaining pick, moving them as necessary and twisting slightly to release the adhesive.
    Pergunte ao FixBot
    Comentar
  12. Moto Z Battery Replacement: passo 12, imagem 1 %32 Moto Z Battery Replacement: passo 12, imagem 2 %32 Moto Z Battery Replacement: passo 12, imagem 3 %32
    • Lift the earpiece end of the display up to provide access to the display cables.
    • Do not open the display beyond 90 degrees, and always support the display panel.
    Pergunte ao FixBot
    Comentar
  13. Moto Z Battery Replacement: passo 13, imagem 1 %32 Moto Z Battery Replacement: passo 13, imagem 2 %32 Moto Z Battery Replacement: passo 13, imagem 3 %32
    • Use the point of a spudger to pry the display cable shield up.
    • Remove the display cable shield.
    Pergunte ao FixBot
    Comentar
  14. Moto Z Battery Replacement: passo 14, imagem 1 %32 Moto Z Battery Replacement: passo 14, imagem 2 %32
    • Use the point of the spudger to lift and disconnect the display cable connector from its socket.
    Pergunte ao FixBot
    Comentar
  15. Moto Z Battery Replacement: passo 15, imagem 1 %32 Moto Z Battery Replacement: passo 15, imagem 2 %32
    • Remove the display assembly.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the flash lens) or remove adhesive backings from the new part before installing.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Use the Motorola Moto Z display adhesive to reseal your phone. Follow this guide for instructions on how to apply adhesive to the replacement screen.
    Pergunte ao FixBot
    Comentar
  16. Moto Z Battery Replacement, Battery: passo 16, imagem 1 %32 Moto Z Battery Replacement, Battery: passo 16, imagem 2 %32 Moto Z Battery Replacement, Battery: passo 16, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to peel the black tape securing the battery to the frame.
    • If your replacement battery did not come with this piece of tape, transfer it from the old battery to the replacement battery.
    Pergunte ao FixBot
    Comentar
  17. Moto Z Battery Replacement: passo 17, imagem 1 %32
    • Lay a heated iOpener on the back of the phone as shown for as least 90 seconds.
    Pergunte ao FixBot
    Comentar
  18. Moto Z Battery Replacement: passo 18, imagem 1 %32 Moto Z Battery Replacement: passo 18, imagem 2 %32 Moto Z Battery Replacement: passo 18, imagem 3 %32
    • Using a pair of tweezers or your fingers, grab the black battery pull tab and slowly pull it upwards until the corner is loose.
    • Do not fully remove the battery as it is still connected by a flex cable.
    Pergunte ao FixBot
    Comentar
  19. Moto Z Battery Replacement: passo 19, imagem 1 %32 Moto Z Battery Replacement: passo 19, imagem 2 %32
    • Follow this step only if your battery tab has broken. Otherwise, skip to the next step.
    • Insert a spudger into the bottom edge of the battery and slowly pry the corner up.
    Pergunte ao FixBot
    Comentar
  20. Moto Z Battery Replacement: passo 20, imagem 1 %32 Moto Z Battery Replacement: passo 20, imagem 2 %32 Moto Z Battery Replacement: passo 20, imagem 3 %32
    • Carefully swing the battery towards the right edge.
    • Lay the battery flat against the work surface while taking care not to strain the battery cable.
    Pergunte ao FixBot
    Comentar
  21. Moto Z Battery Replacement: passo 21, imagem 1 %32 Moto Z Battery Replacement: passo 21, imagem 2 %32 Moto Z Battery Replacement: passo 21, imagem 3 %32
    • Use the point of a spudger to pry up the battery connector bracket.
    • The bracket is held in place by some adhesive and tabs.
    • Remove the battery connector bracket.
    • When you reinstall the bracket, make sure to align the tabs on the bracket with the indents on the left edge of the frame.
    Pergunte ao FixBot
    Comentar
  22. Moto Z Battery Replacement: passo 22, imagem 1 %32 Moto Z Battery Replacement: passo 22, imagem 2 %32
    • Using the point of a spudger, pry up the battery connector from its socket.
    Pergunte ao FixBot
    Comentar
  23. Moto Z Battery Replacement: passo 23, imagem 1 %32
    Tesa 61395 Tape
    $8.95
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery:
    • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Apply pre-cut adhesive strips or double-sided tape to the exposed, silver part of the battery compartment, not on the black foam layer.
    • Press the battery firmly into place for 5-10 seconds.
    Pergunte ao FixBot
    Comentar
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto Z Answers community for troubleshooting help.
33 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
343.490 Reputação
Autoria de 915 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 27.589 guias
29Comentários do guia
Kindly link me to the suitable adhesive tape for sticking back the screen…
Thank you
Anwesh Maile - Responder Compartilhar
Hi Anwesh,
You can use Tesa tape for that purpose.
Arthur Shi - Responder Compartilhar
I have a Moto Z Droid from Verizon. You have instruction for the Moto Z and Moto Z Droid Force. Battery replacement on the Droid Force is much easier. How do I know which one I have?
Budbradley - Responder Compartilhar
Hi Budbradley,
According to Phonearena, it looks like one easy way to tell is the rear camera:
The Z has a 13MP camera, while the Z Force Droid has a 21MP rear camera.
The built-in internal storage are also different:
The Z has 32GB while the Z Force Droid has 64GB.
Hopefully you can check your specs with those and figure out which version you have.
The hardest step in this guide is when you remove adhesive glue behind the LCD panel.
Second is clean residue glue [For this i use lint-free cloth soak with alcohol and rub on glue]
One more note - Moto original battery is su..k. Mine is degrade in 6 moths.
Rawin Juangrat - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 105
Ao todo: 47,488
