Ir para o conteúdo principal
Motherboard Removal
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Motherboard Removal, Safety Precautions: passo 1, imagem 1 %32 Motherboard Removal, Safety Precautions: passo 1, imagem 2 %32
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Motherboard Removal, Screen removal information: passo 2, imagem 1 %32 Motherboard Removal, Screen removal information: passo 2, imagem 2 %32 Motherboard Removal, Screen removal information: passo 2, imagem 3 %32
    • Before starting your repair, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
  3. Motherboard Removal, Anti-Clamp instructions: passo 3, imagem 1 %32 Motherboard Removal, Anti-Clamp instructions: passo 3, imagem 2 %32 Motherboard Removal, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over the right edge of your phone.
    • Position the suction cups near the middle of the right edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. Motherboard Removal: passo 4, imagem 1 %32 Motherboard Removal: passo 4, imagem 2 %32 Motherboard Removal: passo 4, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. Motherboard Removal: passo 5, imagem 1 %32 Motherboard Removal: passo 5, imagem 2 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp so it lays on the right edge of the phone.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. Motherboard Removal, Heat the right edge: passo 6, imagem 1 %32
    • Heat an iOpener and apply it to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  7. Motherboard Removal, Insert an opening pick: passo 7, imagem 1 %32 Motherboard Removal, Insert an opening pick: passo 7, imagem 2 %32 Motherboard Removal, Insert an opening pick: passo 7, imagem 3 %32
    • Apply a suction cup to the screen, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the bezel and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  8. Motherboard Removal, Reposition the opening pick: passo 8, imagem 1 %32 Motherboard Removal, Reposition the opening pick: passo 8, imagem 2 %32 Motherboard Removal, Reposition the opening pick: passo 8, imagem 3 %32
    • While still applying suction, pivot the pick upwards to a steep angle.
    • Carefully push the pick in while prying to reposition the opening pick into the bezel seam.
    • Only insert the pick up to 3.5 mm to avoid damaging the internals.
  9. Motherboard Removal, Release the right clips: passo 9, imagem 1 %32 Motherboard Removal, Release the right clips: passo 9, imagem 2 %32 Motherboard Removal, Release the right clips: passo 9, imagem 3 %32
    • Slide the pick along the right edge to release the plastic clips securing the bezel to the frame.
    • Position the pick at the top-right edge before moving to the next step.
  10. Motherboard Removal, Release the top right clips: passo 10, imagem 1 %32 Motherboard Removal, Release the top right clips: passo 10, imagem 2 %32 Motherboard Removal, Release the top right clips: passo 10, imagem 3 %32
    • Rotate the opening pick around the top-right corner of the phone to release the clips.
    • Leave the opening pick in the top-right corner to prevent the clips from re-locking.
    • Only insert the pick up to 4 mm to avoid damaging the internals.
  11. Motherboard Removal, Release the top clips: passo 11, imagem 1 %32 Motherboard Removal, Release the top clips: passo 11, imagem 2 %32 Motherboard Removal, Release the top clips: passo 11, imagem 3 %32
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the top edge to release the clips.
    • When slicing around the front camera, only insert the pick up to 3 mm to avoid damaging the lens.
  12. Motherboard Removal, Release the top left clips: passo 12, imagem 1 %32 Motherboard Removal, Release the top left clips: passo 12, imagem 2 %32 Motherboard Removal, Release the top left clips: passo 12, imagem 3 %32
    • Rotate the opening pick around the top-left corner of the phone to release the clips.
    • Leave the opening pick in the top-left corner to prevent the clips from re-locking.
  13. Motherboard Removal, Release the left clips: passo 13, imagem 1 %32 Motherboard Removal, Release the left clips: passo 13, imagem 2 %32 Motherboard Removal, Release the left clips: passo 13, imagem 3 %32
    • Slide the pick along the left edge to release the clips.
    • Only insert the pick up to 3 mm to avoid damaging the internals.
    • Repeat the rotating and sliding procedure for the remaining edge.
    • At this point, the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to release any remaining clips.
  14. Motherboard Removal, Reposition the screen: passo 14, imagem 1 %32 Motherboard Removal, Reposition the screen: passo 14, imagem 2 %32 Motherboard Removal, Reposition the screen: passo 14, imagem 3 %32
    • Don't try to remove the screen all the way yet. It's still connected to the frame by a flex cable.
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  15. Motherboard Removal, Remove the display cable bracket: passo 15, imagem 1 %32 Motherboard Removal, Remove the display cable bracket: passo 15, imagem 2 %32 Motherboard Removal, Remove the display cable bracket: passo 15, imagem 3 %32
    • The display cable bracket is secured with metal clips.
    • Use tweezers to bend the bottom side of the bracket upwards, releasing the metal clip.
    • Remove the display cable bracket.
    • During reassembly, insert the top side of the bracket first before pressing down the other side. Failure to do so could result in sparks and logic board damage.
  16. Motherboard Removal, Disconnect the display cable: passo 16, imagem 1 %32 Motherboard Removal, Disconnect the display cable: passo 16, imagem 2 %32 Motherboard Removal, Disconnect the display cable: passo 16, imagem 3 %32
    • Be very careful performing this step, as you risk damaging tiny components around the press connector.
    • Insert the tip of an opening pick under the bottom right edge of the display cable press connector, right above the nearby screw hole.
    • Pry up and disconnect the display cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Motherboard Removal, Screen information: passo 17, imagem 1 %32
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  18. Motherboard Removal, Remove the silver tape: passo 18, imagem 1 %32 Motherboard Removal, Remove the silver tape: passo 18, imagem 2 %32
    • Use tweezers to peel back the silver tape connecting the midframe and the top speaker.
    • Don't completely remove the tape. You only need to remove the bridge between the midframe and the top speaker.
  19. Motherboard Removal: passo 19, imagem 1 %32 Motherboard Removal: passo 19, imagem 2 %32 Motherboard Removal: passo 19, imagem 3 %32
    • Use tweezers to peel back the tape covering the two screws on both sides of the USB-C port.
  20. Motherboard Removal, Unfasten the midframe: passo 20, imagem 1 %32 Motherboard Removal, Unfasten the midframe: passo 20, imagem 2 %32
    • Use a T3 Torx screwdriver to remove the 16 screws securing the midframe to the frame:
    • Eight 4.3 mm screws
    • Five 2.9 mm screws
    • Two 4.9 mm screws
    • One 4.6 mm screw
  21. Motherboard Removal, Release the midframe clips: passo 21, imagem 1 %32 Motherboard Removal, Release the midframe clips: passo 21, imagem 2 %32
    • Insert a spudger between the top of the midframe and the frame, near the front camera.
    • Pry up with the spudger to release the top of the midframe from its clips.
  22. Motherboard Removal: passo 22, imagem 1 %32 Motherboard Removal: passo 22, imagem 2 %32
    • Insert a spudger between the bottom left of the midframe and the frame.
    • Pry up with the spudger to release the bottom of the midframe from its clips.
  23. Motherboard Removal, Remove the midframe: passo 23, imagem 1 %32 Motherboard Removal, Remove the midframe: passo 23, imagem 2 %32
    • Remove the midframe.
    • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  24. Motherboard Removal, Remove the thermal paste: passo 24, imagem 1 %32 Motherboard Removal, Remove the thermal paste: passo 24, imagem 2 %32 Motherboard Removal, Remove the thermal paste: passo 24, imagem 3 %32
    • Use the flat end of a spudger to scrape off the thermal paste.
    • Clean any remaining thermal paste with isopropyl alcohol and either a coffee filter or a lint-free cloth.
    • Repeat the cleaning process for the thermal paste on the midframe.
    • During reassembly, follow this guide for reapplying thermal paste to your device.
  25. Motherboard Removal, Disconnect the battery: passo 25, imagem 1 %32 Motherboard Removal, Disconnect the battery: passo 25, imagem 2 %32
    • Use a spudger to pry up and disconnect the battery's press connector.
  26. Motherboard Removal, Unfasten the 5G mmWave antenna bracket: passo 26, imagem 1 %32 Motherboard Removal, Unfasten the 5G mmWave antenna bracket: passo 26, imagem 2 %32
    • If your device doesn't have a 5G mmWave antenna, skip the next four steps.
    • Use a T3 Torx screwdriver to remove the 2.9 mm screw securing the 5G mmWave antenna bracket.
  27. Motherboard Removal, Remove the 5G mmWave antenna bracket: passo 27, imagem 1 %32 Motherboard Removal, Remove the 5G mmWave antenna bracket: passo 27, imagem 2 %32 Motherboard Removal, Remove the 5G mmWave antenna bracket: passo 27, imagem 3 %32
    • Use tweezers, or your fingers, to pull the bracket towards the right edge of the phone and disconnect its clip.
    • Remove the 5G mmWave antenna bracket.
  28. Motherboard Removal, Disconnect the 5G mmWave antenna: passo 28, imagem 1 %32 Motherboard Removal, Disconnect the 5G mmWave antenna: passo 28, imagem 2 %32
    • Use a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  29. Motherboard Removal: passo 29, imagem 1 %32 Motherboard Removal: passo 29, imagem 2 %32
    • Use tweezers, or your fingers, to remove the 5G mmWave antenna.
  30. Motherboard Removal, Remove the ultrawide rear camera: passo 30, imagem 1 %32 Motherboard Removal, Remove the ultrawide rear camera: passo 30, imagem 2 %32 Motherboard Removal, Remove the ultrawide rear camera: passo 30, imagem 3 %32
    • Use a spudger to pry up and disconnect the ultrawide rear camera's press connector.
    • Remove the ultrawide rear camera.
  31. Motherboard Removal, Remove the wide rear camera: passo 31, imagem 1 %32 Motherboard Removal, Remove the wide rear camera: passo 31, imagem 2 %32 Motherboard Removal, Remove the wide rear camera: passo 31, imagem 3 %32
    • Use a spudger to pry up and disconnect the wide rear camera's press connector.
    • Remove the wide rear camera.
  32. Motherboard Removal, Disconnect the volume and power button: passo 32, imagem 1 %32 Motherboard Removal, Disconnect the volume and power button: passo 32, imagem 2 %32
    • Use the flat end of a spudger to pry up the volume and power button press connector near the top left corner of the motherboard.
  33. Motherboard Removal, Unfasten the motherboard: passo 33, imagem 1 %32 Motherboard Removal, Unfasten the motherboard: passo 33, imagem 2 %32
    • Use a T3 Torx screwdriver to remove the 2.9 mm screw securing the motherboard.
  34. Motherboard Removal, Remove the motherboard: passo 34, imagem 1 %32 Motherboard Removal, Remove the motherboard: passo 34, imagem 2 %32 Motherboard Removal, Remove the motherboard: passo 34, imagem 3 %32
    • Insert a spudger between the top of the motherboard and the frame, near the front camera.
    • Pry up to lift the motherboard until you can grip it with your fingers.
  35. Motherboard Removal: passo 35, imagem 1 %32 Motherboard Removal: passo 35, imagem 2 %32 Motherboard Removal: passo 35, imagem 3 %32
    • Tilt the top of the motherboard upwards to release its plastic clips.
    • Remove the motherboard.
Conclusão
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 6a Answers community for help.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
219.654 Reputação
Autoria de 1.064 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 24.148 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 128
