Ir para o conteúdo principal
How to Apply Thermal Paste to Phones
O que você precisa
    1. How to Apply Thermal Paste to Phones, Locate the thermal paste: passo 1, imagem 1 %32 How to Apply Thermal Paste to Phones, Locate the thermal paste: passo 1, imagem 2 %32
      • Look for existing thermal paste above or below the motherboard.
      • Thermal paste is often gray, but can be any color. It's opaque and thick, with a wet texture. Older thermal paste is drier.
      Pergunte ao FixBot
      Comentar
    2. How to Apply Thermal Paste to Phones, Clean the motherboard: passo 2, imagem 1 %32
      • Use the flat end of a spudger to scrape away large pieces of old thermal paste from your phone's motherboard.
      • Don't use sharp or metal tools. They can scratch the motherboard surface or puncture the battery in an accident.
      Pergunte ao FixBot
      Comentar
    3. How to Apply Thermal Paste to Phones, Clean the frame or cover: passo 3, imagem 1 %32
      • Scrape away large pieces of thermal paste from the frame or cover.
      Pergunte ao FixBot
      Comentar
    4. How to Apply Thermal Paste to Phones, Prepare the motherboard: passo 4, imagem 1 %32 How to Apply Thermal Paste to Phones, Prepare the motherboard: passo 4, imagem 2 %32 How to Apply Thermal Paste to Phones, Prepare the motherboard: passo 4, imagem 3 %32
      • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
      • Wipe away the residue using a coffee filter or lint-free cloth.
      Pergunte ao FixBot
      Comentar
    5. How to Apply Thermal Paste to Phones, Prepare the frame or cover: passo 5, imagem 1 %32
      • Clean the cover or frame using isopropyl alcohol and a coffee filter or lint-free cloth.
      Pergunte ao FixBot
      Comentar
    6. How to Apply Thermal Paste to Phones, Apply new thermal paste: passo 6, imagem 1 %32 How to Apply Thermal Paste to Phones, Apply new thermal paste: passo 6, imagem 2 %32
      • Apply a small bead of thermal paste to the motherboard in the same location as the old thermal paste.
      • Unlike full-size processors found in computers with heatsinks, phones need very little thermal paste.
      Pergunte ao FixBot
      Comentar
    7. How to Apply Thermal Paste to Phones, Continue reassembly: passo 7, imagem 1 %32
      • Return to your phone's guide to continue reassembly.
      • When you compress the thermal paste, it will evenly distribute and form a thermal bond with the processor.
      Pergunte ao FixBot
      Comentar
Conclusão
For other general electronics skills guides, click here.
29 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
105.740 Reputação
Autoria de 472 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 30.763 guias
5Comentários do guia
What kind of thermal paste is best for phones?
Brian K - Responder Compartilhar
Your phone is less demanding than a full-size CPU in terms of heat transfer, so you can use any regular compound thermal paste.
Clay Eickemeyer - Responder Compartilhar
Will applying thermal paste on smartphones be obsolete in the near future? I have a hint that my smartphone that is already 4 years old, now needs to renew its thermal paste because it overheats easily even while using lighter apps like the Calculator.
Koko Jeuru - Responder Compartilhar
Your phone is the same vintage as mine, and there was zero paste on mine (just a faint outline where it used to be). Just do it.
Animot - Responder Compartilhar
do i need to apply just cooling film because my moto g6 plus had a film which got teared while replacing battery
Wasim Shaikh - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 27
Últimos 7 dias: 187
Últimos 30 dias: 953
Ao todo: 29,995
