Ir para o conteúdo principal
HyperX Cloud III Connecting Cable Replacement
O que você precisa
  1. HyperX Cloud III Connecting Cable Replacement, Ear Cushion: passo 1, imagem 1 %32 HyperX Cloud III Connecting Cable Replacement, Ear Cushion: passo 1, imagem 2 %32 HyperX Cloud III Connecting Cable Replacement, Ear Cushion: passo 1, imagem 3 %32
    • Pinch the side of one ear cushion with your thumb.
    • Slide it with your thumb to remove it completely from the outline.
    • Do the same on the other side of the headset if you want to replace both ear cushions.
    Pergunte ao FixBot
    Comentar
  2. HyperX Cloud III Connecting Cable Replacement, Connecting Cable: passo 2, imagem 1 %32 HyperX Cloud III Connecting Cable Replacement, Connecting Cable: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the four 9.4 mm-long screws securing the speaker plate to the earphone.
    • Use your fingers to pull and remove the black speaker plate.
    Pergunte ao FixBot
    Comentar
  3. HyperX Cloud III Connecting Cable Replacement: passo 3, imagem 1 %32 HyperX Cloud III Connecting Cable Replacement: passo 3, imagem 2 %32
    • Use the Phillips #2 screwdriver to remove the 9.4 mm-long single screw securing the head of the connecting cable.
    Pergunte ao FixBot
    Comentar
  4. HyperX Cloud III Connecting Cable Replacement: passo 4, imagem 1 %32 HyperX Cloud III Connecting Cable Replacement: passo 4, imagem 2 %32
    • Use the Phillips #2 screwdriver to remove the two 6.8 mm-long screws securing the motherboard.
    Pergunte ao FixBot
    Comentar
  5. HyperX Cloud III Connecting Cable Replacement: passo 5, imagem 1 %32 HyperX Cloud III Connecting Cable Replacement: passo 5, imagem 2 %32
    • Use tweezers to turn the motherboard backward, to desolder the connecting cables wires on this side.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow the steps instructions in reverse order.
Prior knowledge of soldering is required and working with wires is necessary.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 140
Ao todo: 301
