Ir para o conteúdo principal
Google Pixel Watch 4 Back Sensor Glass Replacement
O que você precisa
    1. Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: passo 1, imagem 1 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: passo 1, imagem 2 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: passo 1, imagem 3 %32
      • Before starting your repair:
      • Remove your watch from the charger.
      • Press and hold the crown button, then tap Power off to shut down your watch.
      Pergunte ao FixBot
      Comentar
    2. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: passo 2, imagem 1 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: passo 2, imagem 2 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: passo 2, imagem 3 %32
      • Remove each watch band by depressing the release button and sliding the band out of its groove.
      Pergunte ao FixBot
      Comentar
    3. Google Pixel Watch 4 Back Sensor Glass Replacement: passo 3, imagem 1 %32
      • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
      Pergunte ao FixBot
      Comentar
    4. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: passo 4, imagem 1 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: passo 4, imagem 2 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: passo 4, imagem 3 %32
      • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
      • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
      • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
      • During reassembly:
      • Make sure the O‑rings are on the screws before installing them.
      • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
      • If there's a gap between the back glass and frame, remove the screws and reinstall them.
      Pergunte ao FixBot
      Comentar
    5. Google Pixel Watch 4 Back Sensor Glass Replacement, Separate the back sensor glass: passo 5, imagem 1 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Separate the back sensor glass: passo 5, imagem 2 %32
      • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
      Pergunte ao FixBot
      Comentar
    6. Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: passo 6, imagem 1 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: passo 6, imagem 2 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: passo 6, imagem 3 %32
      • Gently lift the back glass and flip it over the side of the watch opposite the crown.
      • Be careful not to strain the cable connecting the back sensor glass.
      Pergunte ao FixBot
      Comentar
    1. Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: passo 7, imagem 1 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: passo 7, imagem 2 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: passo 7, imagem 3 %32
      • Use a spudger to lift the small, hinged locking‑flap on the back sensor glass ZIF connector.
      Pergunte ao FixBot
      Comentar
    2. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: passo 8, imagem 1 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: passo 8, imagem 2 %32 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: passo 8, imagem 3 %32
      • Gently slide the cable out of its socket and remove the back sensor glass.
      • During reassembly, make sure the locking flap is lifted before sliding the cable fully into its connector—it should snap into place.
      Pergunte ao FixBot
      Comentar
Conclusão
Spencer Day
Membro desde: 09/14/22
200.637 Reputação
Autoria de 1.243 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 30
Últimos 30 dias: 155
Ao todo: 1,522
