Ir para o conteúdo principal
Google Pixel Display Adhesive Installation
O que você precisa
  1. Google Pixel Display Adhesive Installation, Display Adhesive: passo 1, imagem 1 %32 Google Pixel Display Adhesive Installation, Display Adhesive: passo 1, imagem 2 %32 Google Pixel Display Adhesive Installation, Display Adhesive: passo 1, imagem 3 %32
    • Peel away and remove all the old display adhesive from the body of your phone.
    • Use the point of your spudger to scour away and remove any lingering adhesive.
    • Using metal tools can lead to scratching the glass!
    • If you are reinstalling your existing display, remove all the old adhesive from that as well.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    • While high-concentration isopropyl alcohol is generally safe for use with electronics, it can wear away the foam padding on the midframe. Be careful as you clean the narrow edges of the frame.
  2. Google Pixel Display Adhesive Installation: passo 2, imagem 1 %32 Google Pixel Display Adhesive Installation: passo 2, imagem 2 %32 Google Pixel Display Adhesive Installation: passo 2, imagem 3 %32
    • The replacement adhesive should only be applied to the edges of the frame, but may come with the center filled in.
    • To remove the unnecessary center section of the adhesive strip, carefully peel away the center portion of both the white (paper) and black (adhesive) layers, starting with the U-shaped cutout.
  3. Google Pixel Display Adhesive Installation: passo 3, imagem 1 %32 Google Pixel Display Adhesive Installation: passo 3, imagem 2 %32
    • Peel off and discard the remaining paper liner, exposing the adhesive underneath.
  4. Google Pixel Display Adhesive Installation: passo 4, imagem 1 %32 Google Pixel Display Adhesive Installation: passo 4, imagem 2 %32
    • Hold the adhesive sheet with the exposed adhesive facing down, and carefully align it into the lower edge of the phone.
    • Make sure the adhesive sheet is oriented correctly, with the rectangular cutout for the earpiece speaker at the top.
    • When it's correctly aligned, lower the rest of the adhesive sheet into the phone.
  5. Google Pixel Display Adhesive Installation: passo 5, imagem 1 %32 Google Pixel Display Adhesive Installation: passo 5, imagem 2 %32 Google Pixel Display Adhesive Installation: passo 5, imagem 3 %32
    • Firmly press the adhesive into place.
    • You can use the flat end of a spudger to press along the edges and other hard-to-reach areas.
  6. Google Pixel Display Adhesive Installation: passo 6, imagem 1 %32 Google Pixel Display Adhesive Installation: passo 6, imagem 2 %32
    • Peel off and discard the plastic liner, exposing the display adhesive.
  7. Google Pixel Display Adhesive Installation: passo 7, imagem 1 %32 Google Pixel Display Adhesive Installation: passo 7, imagem 2 %32
    • Once the new adhesive is exposed, do your best not to touch it—either with your hand, or the display. If you can, try to hold the display up and away from the rest of the phone (as shown in the step photo) while performing this step.
    • Re-attach the display cable connector.
    • Screw the connector bracket back in place.
    • Power on your phone to make sure your repair was successful.
    • Do not remove or adjust the display cable while the phone is powered on.
  8. Google Pixel Display Adhesive Installation: passo 8, imagem 1 %32
    • Once you are sure the display is functioning properly, carefully align it with the chassis and firmly press it into place.
    • To help the display adhesive bond more securely, heat the perimeter of the display and then place the phone face-up under a heavy stack of books for 30 minutes.
Conclusão
48 outras pessoas executaram este guia.
Taylor Dixon
Membro desde: 06/26/18
65.177 Reputação
Autoria de 94 guias
Equipe
Teardown Team Membro de Teardown Team
Community
Membros da 2
Autoria de 2.097 guias
2 comentários
What is the included tesa tape for?
Koelton Carere - Responder
The Tesa tape is to adhere the battery to the frame. You don't want anything moving around inside your phone--that can stress, damage, or disconnect ribbon connectors.
David Bauman -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 39
Últimos 30 dias: 170
Duração total: 16,774
