Ir para o conteúdo principal
Google Pixel 7a Logic Board Replacement
O que você precisa
  1. Google Pixel 7a Logic Board Replacement, Prepare your phone for disassembly: passo 1, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Prepare your phone for disassembly: passo 1, imagem 2 %32
    • Allow your battery to drain below 25% before starting this repair. A charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone and fully power it down.
  2. Google Pixel 7a Logic Board Replacement, Remove the SIM card tray: passo 2, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the SIM card tray: passo 2, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Remove the SIM card tray: passo 2, imagem 3 %32
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • Press the SIM eject tool into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  3. Google Pixel 7a Logic Board Replacement, Soften the adhesive: passo 3, imagem 1 %32
    • Apply a heated iOpener to the bottom edge of the rear cover for three minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover.
    • Only heat the phone enough so it's just hot to the touch. Extreme heat can damage the screen, rear cover, or battery.
  4. Google Pixel 7a Logic Board Replacement, Secure an Anti-Clamp: passo 4, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Secure an Anti-Clamp: passo 4, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Secure an Anti-Clamp: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Slide the arms over the bottom edge of the phone, with one suction cup on the rear cover and one on the screen.
    • Squeeze the cups together to create suction.
  5. Google Pixel 7a Logic Board Replacement, Use the Anti-Clamp to create a gap: passo 5, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Use the Anti-Clamp to create a gap: passo 5, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Use the Anti-Clamp to create a gap: passo 5, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  6. Google Pixel 7a Logic Board Replacement, Insert an opening pick using the Anti-Clamp: passo 6, imagem 1 %32
    • While the heat from an iOpener is sufficient to separate the rear cover, it might cool down while you set up the Anti-Clamp. Reheat the rear cover if you need more time to set it up.
    • Place an object under your phone so it rests level while between the Anti-Clamp's arms.
    • Wait one minute, or until the adhesive separates, for a gap to form along the bottom edge of the phone.
    • Insert an opening pick into the gap between the rear cover and the frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat with a hair dryer or heat gun if the rear cover cools down.
    • Remove the suction cups from the phone using their pull-tabs and set the Anti-Clamp aside.
  7. Google Pixel 7a Logic Board Replacement, Insert an opening pick using a suction handle: passo 7, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Insert an opening pick using a suction handle: passo 7, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Insert an opening pick using a suction handle: passo 7, imagem 3 %32
    • If you've already inserted an opening pick using the Anti-Clamp, skip this step.
    • Apply a suction handle to the center of the bottom edge of the rear cover.
    • Pull up on the suction handle with a strong, steady force until a gap forms between the rear cover and frame.
    • Insert the tip of an opening pick into the gap.
    • Remove the suction handle.
  8. Google Pixel 7a Logic Board Replacement, Adhesive information: passo 8, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Adhesive information: passo 8, imagem 2 %32
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you slice the adhesive.
  9. Google Pixel 7a Logic Board Replacement, Angle the opening pick: passo 9, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Angle the opening pick: passo 9, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Angle the opening pick: passo 9, imagem 3 %32
    • Angle the opening pick upward so the tip faces away from the frame.
    • From here on, keep all opening picks angled upward while slicing until the rear cover is fully removed.
    • Slide your pick to the bottom left corner of the rear cover.
    • Leave this pick in place to prevent the adhesive from resealing.
  10. Google Pixel 7a Logic Board Replacement, Separate the bottom edge adhesive: passo 10, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Separate the bottom edge adhesive: passo 10, imagem 2 %32
    • Insert a second opening pick in the bottom left corner.
    • Slide the new pick to the bottom right corner of the rear cover to separate the bottom edge adhesive.
  11. Google Pixel 7a Logic Board Replacement, Soften the right edge adhesive: passo 11, imagem 1 %32
    • Apply a heated iOpener to the right edge of the rear cover for two minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover. Remember to not overheat the phone.
  12. Google Pixel 7a Logic Board Replacement, Separate the right edge adhesive: passo 12, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Separate the right edge adhesive: passo 12, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Separate the right edge adhesive: passo 12, imagem 3 %32
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the wireless charging coil.
    • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
    • Insert a third opening pick in the bottom right corner of the rear cover.
    • Slide your pick up the right edge of the rear cover to separate its adhesive. Stop when you reach the camera bar.
  13. Google Pixel 7a Logic Board Replacement, Soften the left edge adhesive: passo 13, imagem 1 %32
    • Apply a heated iOpener to the left edge of the rear cover for two minutes.
  14. Google Pixel 7a Logic Board Replacement, Separate the left edge adhesive: passo 14, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Separate the left edge adhesive: passo 14, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Separate the left edge adhesive: passo 14, imagem 3 %32
    • Don't insert your pick deeper than 3 mm along the left edge to avoid damaging the wireless charging coil and rear cover foam pad.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Insert a fourth opening pick in the bottom left corner of the rear cover.
    • Slide your pick up the left edge of the rear cover to separate the adhesive. Stop when you reach the camera bar.
  15. Google Pixel 7a Logic Board Replacement, Soften the top edge adhesive: passo 15, imagem 1 %32
    • Apply a heated iOpener to the top edge of the rear cover for two minutes.
  16. Google Pixel 7a Logic Board Replacement, Separate the antenna bracket adhesive: passo 16, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Separate the antenna bracket adhesive: passo 16, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Separate the antenna bracket adhesive: passo 16, imagem 3 %32
    • There's a thick strip of adhesive along the antenna housing.
    • Insert a fifth opening pick in the top left corner of the rear cover between 8 mm and 10 mm (0.3–0.4 in) deep, or just over halfway between the tip of the pick and the iFixit logo.
    • If you can't insert the pick, start with the small gap near the camera bar from the previous pick.
    • Slide your pick halfway across the top edge to separate the antenna bracket adhesive. Stop at the halfway point along the top edge.
  17. Google Pixel 7a Logic Board Replacement, Separate the remaining top edge adhesive: passo 17, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Separate the remaining top edge adhesive: passo 17, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Separate the remaining top edge adhesive: passo 17, imagem 3 %32
    • Pull your opening pick out to a depth of 3 mm.
    • Slide your pick to the top right corner to slice the rest of the top edge adhesive.
    • Don't insert your pick deeper than 3 mm to avoid damaging the antenna housing graphite tape.
  18. Google Pixel 7a Logic Board Replacement, Rotate your top edge opening picks: passo 18, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Rotate your top edge opening picks: passo 18, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Rotate your top edge opening picks: passo 18, imagem 3 %32
    • Remember to angle your picks upward and away from the frame during this step.
    • Roll the top edge pick so its flat edge is under the rear cover.
    • Roll the picks on each side of the camera bar so their flat edges are under the camera bar.
  19. Google Pixel 7a Logic Board Replacement, Pry up the camera bar: passo 19, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Pry up the camera bar: passo 19, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Pry up the camera bar: passo 19, imagem 3 %32
    • There's a long strip of adhesive securing the rear cover below the camera bar.
    • Use the opening picks under the camera bar to pry the top edge of the rear cover from the frame.
    • Pry back and forth until the camera bar loosens.
    • Be careful not to bend the rear cover. Only pry enough to loosen the adhesive near the camera bar. If the adhesive feels stubborn, rotate the rear cover side-to-side to further loosen the adhesive.
  20. Google Pixel 7a Logic Board Replacement, Finish separating the adhesive: passo 20, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Finish separating the adhesive: passo 20, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Finish separating the adhesive: passo 20, imagem 3 %32
    • Slide the opening picks from the camera bar down the long edges of the rear cover to separate any adhesive that may have resealed.
  21. Google Pixel 7a Logic Board Replacement, Remove the rear cover: passo 21, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the rear cover: passo 21, imagem 2 %32
    • Remove the rear cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your rear cover.
  22. Google Pixel 7a Logic Board Replacement, Soften the flash unit adhesive: passo 22, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Soften the flash unit adhesive: passo 22, imagem 2 %32
    • Apply a heated iOpener to the flash unit for one minute to soften the adhesive securing it to the logic board cover.
    • Alternatively, you can use a hair dryer or heat gun to warm the flash.
    • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
  23. Google Pixel 7a Logic Board Replacement, Separate the flash unit adhesive: passo 23, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Separate the flash unit adhesive: passo 23, imagem 2 %32
    • Be careful not to slip and tear the flash cable, as it's very fragile.
    • Slide your pick under the right edge of the flash to separate the adhesive securing it to the cover.
  24. Google Pixel 7a Logic Board Replacement, Clean the logic board cover: passo 24, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Clean the logic board cover: passo 24, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Clean the logic board cover: passo 24, imagem 3 %32
    • If the copper tape lifted away with the flash, use tweezers or your fingers to remove the black foam residue from the logic board cover.
  25. Google Pixel 7a Logic Board Replacement, Remove the old copper tape: passo 25, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the old copper tape: passo 25, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Remove the old copper tape: passo 25, imagem 3 %32
    • Be careful not to damage the battery with your tool during this step.
    • Apply a heated iOpener to the underside of the flash for one minute.
    • Hold the neck of the flash cable steady and use tweezers to peel and remove the copper tape from the flash unit.
    • If the copper tape stayed on the logic board cover and you have a replacement, remove the old tape now.
  26. Google Pixel 7a Logic Board Replacement, Unfasten the logic board cover: passo 26, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Unfasten the logic board cover: passo 26, imagem 2 %32
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • While the Pixel 7a uses Torx Plus screws, standard Torx drivers may still work. If your kit came with standard Torx bits, use the T2 bit to remove 1IP Torx Plus screws, and the T3 Torx bit to remove 3IP Torx Plus screws. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the thirteen 4.3 mm screws securing the logic board cover.
    • Use a 1IP Torx Plus driver to remove the 1.5 mm screw securing the right edge of the cover.
  27. Google Pixel 7a Logic Board Replacement, Unclip the logic board cover: passo 27, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Unclip the logic board cover: passo 27, imagem 2 %32
    • Insert an opening pick between the bottom right corner of the logic board cover and the frame.
    • Pry up to release the clip securing the cover.
  28. Google Pixel 7a Logic Board Replacement, Free the flash unit: passo 28, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Free the flash unit: passo 28, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Free the flash unit: passo 28, imagem 3 %32
    • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
    • During reassembly, thread the flash through its cutout as you lower the logic board into place.
  29. Google Pixel 7a Logic Board Replacement, Remove the wireless charging assembly: passo 29, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the wireless charging assembly: passo 29, imagem 2 %32
    • Remove the wireless charging assembly.
  30. Google Pixel 7a Logic Board Replacement, Remove the connector cover: passo 30, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the connector cover: passo 30, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Remove the connector cover: passo 30, imagem 3 %32
    • Use your 1IP Torx Plus driver to remove the 1.5 mm screw securing the connector cover.
    • Use tweezers or your fingers to remove the cover.
    • During reassembly, place the upper left corner of the cover under the hook on the logic board before installing its screw.
  31. Google Pixel 7a Logic Board Replacement: passo 31, imagem 1 %32
    • The Verizon model (G0DZQ) Google Pixel 7a has an extra cable and connector for the 5G mmWave antenna. Unless otherwise mentioned, the rest of the guide procedure is the same for either type of phone.
  32. Google Pixel 7a Logic Board Replacement, Disconnect the battery: passo 32, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Disconnect the battery: passo 32, imagem 2 %32
    • Insert the flat end of a spudger under the top edge of the battery press connector.
    • Pry straight up to disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  33. Google Pixel 7a Logic Board Replacement, Unfasten the earpiece speaker: passo 33, imagem 1 %32
    • Use your 3IP Torx Plus driver to remove the 4.3 mm screw securing the earpiece speaker to the frame.
  34. Google Pixel 7a Logic Board Replacement, Remove the earpiece speaker: passo 34, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the earpiece speaker: passo 34, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Remove the earpiece speaker: passo 34, imagem 3 %32
    • Lift the bottom edge of the earpiece speaker upward.
    • Pull the speaker toward the bottom of the phone to free the red gasket from its cutout in the frame.
    • Remove the speaker.
  35. Google Pixel 7a Logic Board Replacement, Unfasten the antenna housing: passo 35, imagem 1 %32
    • Use your 3IP Torx Plus driver to remove the two 4.3 mm screws securing the antenna housing to the frame.
    • During reassembly, hold the housing down while you fasten the screws.
  36. Google Pixel 7a Logic Board Replacement, Unclip the antenna housing: passo 36, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Unclip the antenna housing: passo 36, imagem 2 %32
    • Insert an opening pick between the top left corner of the antenna housing and the frame.
    • Pry up to release the clips securing the housing.
    • During reassembly, hold the graphite film out of the way before inserting the housing.
  37. Google Pixel 7a Logic Board Replacement, Remove the antenna housing: passo 37, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the antenna housing: passo 37, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Remove the antenna housing: passo 37, imagem 3 %32
    • Lift the bottom leg of the antenna housing and pull the top edge out from the frame.
    • Remove the housing.
  38. Google Pixel 7a Logic Board Replacement, Disconnect the 5G mmWave antenna: passo 38, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Disconnect the 5G mmWave antenna: passo 38, imagem 2 %32
    • Verizon models: Use the point of your spudger to pry up and disconnect the 5G mmWave press connector.
  39. Google Pixel 7a Logic Board Replacement, Heat the front-facing camera tape: passo 39, imagem 1 %32
    • Apply a heated iOpener to the front-facing camera for one minute to soften the copper tape adhesive.
    • Alternatively, you can use a hair dryer or heat gun to soften the adhesive. Only heat the tape until it's warm to the touch.
  40. Google Pixel 7a Logic Board Replacement, Peel the front-facing camera tape: passo 40, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Peel the front-facing camera tape: passo 40, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Peel the front-facing camera tape: passo 40, imagem 3 %32
    $3.99
    • Be careful not to touch the rear camera lenses.
    • Insert the tip of an opening pick under the front-facing camera's copper tape.
    • Slowly peel up the tape from the logic board.
    • If the tape feels stuck, use a sharp tool such as angled tweezers to scrape up the edge of the tape until you can insert a pick underneath.
  41. Google Pixel 7a Logic Board Replacement, Separate the front-facing camera cable adhesive: passo 41, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Separate the front-facing camera cable adhesive: passo 41, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Separate the front-facing camera cable adhesive: passo 41, imagem 3 %32
    • Be careful not to touch the front-facing camera lens with your tool.
    • Insert the tip of your opening pick between the right edge of the front-facing camera cable and the frame.
    • If the pick can't slide under the cable, lightly heat the cable with a hair dryer or heat gun to soften the adhesive underneath.
    • Slide your pick underneath the cable to separate the adhesive securing it to the frame.
  42. Google Pixel 7a Logic Board Replacement, Disconnect the logic board: passo 42, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Disconnect the logic board: passo 42, imagem 2 %32
    • Use the point of a spudger or your fingernail to pry up and disconnect the press connector just above the battery.
    • This connector is responsible for the power button, volume buttons, flash unit, and upper microphone.
  43. Google Pixel 7a Logic Board Replacement, Free the top edge of the logic board: passo 43, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Free the top edge of the logic board: passo 43, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Free the top edge of the logic board: passo 43, imagem 3 %32
    • Insert your opening pick between the top right edge of the logic board and the frame.
    • Pry up to free the logic board from its recess.
    • Insert your pick in the gap near the white antenna cable and pry up the top left edge of the logic board.
  44. Google Pixel 7a Logic Board Replacement, Free the bottom edge of the logic board: passo 44, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Free the bottom edge of the logic board: passo 44, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Free the bottom edge of the logic board: passo 44, imagem 3 %32
    • The logic board is delicate. Be careful not to bend it as you free the lower edge from the frame.
    • Lift the top edge of the logic board from the frame.
    • Pull the top edge of the logic board to the right of the frame so the cutouts of the board lift over the vibration motor and protrusions in the frame.
    • As you pull, guide the charging port out of its recess in the frame.
    • Don't fully remove the logic board yet, as it's still connected to the frame by the screen cable.
    • During reassembly, push the logic board toward the bottom of the frame and press the charging port down until the bottom edge sits flush with its protrusion in the frame.
    • Make sure the flash, front-facing camera, and press connector don't become trapped under the frame.
  45. Google Pixel 7a Logic Board Replacement, Lay down the logic board: passo 45, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Lay down the logic board: passo 45, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Lay down the logic board: passo 45, imagem 3 %32
    • The logic board might fall out of place during this step. Hold it steady, but avoid gripping it by any of the camera lenses or connectors.
    • Apply your suction handle to the left side of the screen with the handle facing down.
    • Prop up the phone so it stands upright.
    • If you don't have a suction handle, prop up the phone against a sturdy object, such as a heavy box or thick book.
    • Tilt the logic board down and lay it flat. Move any cables out of the way, if necessary.
    • Be careful not to touch the thermal pads on the underside of the logic board.
  46. Google Pixel 7a Logic Board Replacement, Remove the screen connector cover: passo 46, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the screen connector cover: passo 46, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Remove the screen connector cover: passo 46, imagem 3 %32
    • Use your 3IP Torx Plus driver to remove the 2 mm screw securing the screen connector cover.
    • Remove the cover.
    • During reassembly, hook the bottom edge of the cover into its slot on the logic board before installing its screw.
  47. Google Pixel 7a Logic Board Replacement, Disconnect the screen: passo 47, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Disconnect the screen: passo 47, imagem 2 %32
    • Use the flat end of your spudger to pry up and disconnect the screen press connector.
    • The tension in this cable makes it tricky to reconnect. If necessary, hold the neck of the cable in place with tweezers and align it over the socket before pressing down to secure it.
  48. Google Pixel 7a Logic Board Replacement, Remove the logic board: passo 48, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the logic board: passo 48, imagem 2 %32
    • Remove the logic board from the frame.
  49. Google Pixel 7a Logic Board Replacement, Transfer the front sensor gasket: passo 49, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Transfer the front sensor gasket: passo 49, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Transfer the front sensor gasket: passo 49, imagem 3 %32
    • If the front sensor rubber gasket stayed on the frame or became misaligned, remove it and set it aside.
    • During reassembly, place the gasket over the front sensor on the logic board, with the smaller cutout toward the top.
    • Avoid touching the sensor with your fingers or tool.
  50. Google Pixel 7a Logic Board Replacement, Replace the thermal pad: passo 50, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Replace the thermal pad: passo 50, imagem 2 %32
    • If you're reusing your logic board and the thermal pad is damaged, remove the old thermal pad, clean the surface, and apply a new one.
    • If you have a new logic board and it doesn't come with a thermal pad pre-installed, apply the new thermal pad now.
  51. Google Pixel 7a Logic Board Replacement, Disconnect the front-facing camera: passo 51, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Disconnect the front-facing camera: passo 51, imagem 2 %32
    • Use the point of a spudger or your fingernail to pry up and disconnect the front-facing camera press connector.
  52. Google Pixel 7a Logic Board Replacement, Remove the front-facing camera: passo 52, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the front-facing camera: passo 52, imagem 2 %32
    • Remove the front-facing camera.
  53. Google Pixel 7a Logic Board Replacement, Disconnect the rear cameras: passo 53, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Disconnect the rear cameras: passo 53, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Disconnect the rear cameras: passo 53, imagem 3 %32
    • Use the flat end of your spudger to pry up and disconnect both rear camera press connectors from the logic board.
  54. Google Pixel 7a Logic Board Replacement, Remove the conductive fabric: passo 54, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the conductive fabric: passo 54, imagem 2 %32
    • If your work surface is dirty or uneven, put the logic board on a towel or lint-free cloth to protect it.
    • Flip the logic board over.
    • Use tweezers to peel the silver conductive fabric connecting the rear camera bracket to the logic board.
  55. Google Pixel 7a Logic Board Replacement, Remove the rear camera assembly: passo 55, imagem 1 %32 Google Pixel 7a Logic Board Replacement, Remove the rear camera assembly: passo 55, imagem 2 %32 Google Pixel 7a Logic Board Replacement, Remove the rear camera assembly: passo 55, imagem 3 %32
    • Remove the rear camera assembly.
    • During reassembly, angle the assembly downward so the press connectors go under the logic board and the tab on the left of the bracket goes above the logic board.
    • The thin arm of the logic board is very delicate. Be careful not to strain it when positioning the rear camera assembly.
  56. Google Pixel 7a Logic Board Replacement: passo 56, imagem 1 %32 Google Pixel 7a Logic Board Replacement: passo 56, imagem 2 %32
    • The logic board is all that remains.
Conclusão
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
4 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
95.775 Reputação
Autoria de 466 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 15.897 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 47
Últimos 30 dias: 277
Ao todo: 5,149
