Ir para o conteúdo principal
Google Pixel 6 Pro Rear Camera Replacement
O que você precisa
  1. Google Pixel 6 Pro Rear Camera Replacement, Safety precautions: passo 1, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Safety precautions: passo 1, imagem 2 %32
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 6 Pro Rear Camera Replacement, Anti-Clamp instructions: passo 2, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Anti-Clamp instructions: passo 2, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement, Anti-Clamp instructions: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Pro Rear Camera Replacement: passo 3, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement: passo 3, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement: passo 3, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Pro Rear Camera Replacement: passo 4, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement: passo 4, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement: passo 4, imagem 3 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Pro Rear Camera Replacement, Loosen the display adhesive: passo 5, imagem 1 %32
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  6. Google Pixel 6 Pro Rear Camera Replacement, Insert an opening pick: passo 6, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Insert an opening pick: passo 6, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement, Insert an opening pick: passo 6, imagem 3 %32
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Pro Rear Camera Replacement, Slice the adhesive: passo 7, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Slice the adhesive: passo 7, imagem 2 %32
    • Insert a second opening pick at the bottom edge and slide it to the bottom right corner of the screen to slice the adhesive.
  8. Google Pixel 6 Pro Rear Camera Replacement: passo 8, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement: passo 8, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement: passo 8, imagem 3 %32
    • The screen of the Google Pixel 6 Pro is not only held in place by adhesive but also small plastic pins. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (~3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Pro Rear Camera Replacement: passo 9, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement: passo 9, imagem 2 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Pro Rear Camera Replacement: passo 10, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement: passo 10, imagem 2 %32
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. Google Pixel 6 Pro Rear Camera Replacement, Open up the phone assembly: passo 11, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Open up the phone assembly: passo 11, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement, Open up the phone assembly: passo 11, imagem 3 %32
    • Avoid straining the display cable during the following procedure.
    • Carefully fold the screen to the left side of the phone assembly like you would open the front cover of a book.
  12. Google Pixel 6 Pro Rear Camera Replacement, Unfasten the display bracket screw: passo 12, imagem 1 %32
    Magnetic Project Mat
    $16.96
    • While the Pixel 6 Pro uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx T3 screwdriver to remove the 2.0 mm-long 3IP Torx Plus screw securing the display cable metal bracket.
  13. Google Pixel 6 Pro Rear Camera Replacement, Remove the display cable bracket: passo 13, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the display cable bracket: passo 13, imagem 2 %32
    • Use a pair of tweezers to remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
  14. Google Pixel 6 Pro Rear Camera Replacement, Disconnect the display cable: passo 14, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Disconnect the display cable: passo 14, imagem 2 %32
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  15. Google Pixel 6 Pro Rear Camera Replacement, Screen information: passo 15, imagem 1 %32
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  16. Google Pixel 6 Pro Rear Camera Replacement, Remove the screen: passo 16, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the screen: passo 16, imagem 2 %32
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the screen's front-facing camera hole and sensor cutout for any protective liners. Remove these liners before you close the phone up.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide in case you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
  17. Google Pixel 6 Pro Rear Camera Replacement, Loosen the graphite film adhesive: passo 17, imagem 1 %32
    • Apply a heated iOpener or a heat gun to the rear glass to loosen the adhesive underneath the graphite films on top of the battery. Apply the iOpener for at least two minutes.
    • Don't apply heat directly onto the battery. It is susceptible to heat damage and could cause a thermal event.
  18. Google Pixel 6 Pro Rear Camera Replacement, Remove the graphite film: passo 18, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the graphite film: passo 18, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the graphite film: passo 18, imagem 3 %32
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the bottom edge of the battery and the motherboard shield.
    • Remove the graphite film.
  19. Google Pixel 6 Pro Rear Camera Replacement, Peel off the graphite film: passo 19, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Peel off the graphite film: passo 19, imagem 2 %32
    • If you want to replace your battery it's enough to peel the bottom part of the graphite film off the battery. If you want to replace your rear camera you need to remove it completely. In case you only want to replace the earpiece speaker or the front facing camera, you can leave it in its place.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the top right corner of the battery.
    • Fold the graphite film in direction of the selfie camera to get free access to the battery.
  20. Google Pixel 6 Pro Rear Camera Replacement, Remove the graphite film: passo 20, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the graphite film: passo 20, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the graphite film: passo 20, imagem 3 %32
    • If the graphite film becomes hard to peel off, it has most likely cooled down. Reapply your iOpener or heat gun to the rear glass for 1-2 minutes to reheat it.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the left edge of the battery and the motherboard shield.
  21. Google Pixel 6 Pro Rear Camera Replacement, Unfasten the charging port bracket screws: passo 21, imagem 1 %32
    • Use a Torx T3 screwdriver to remove the two 5.1 mm-long 3IP Torx Plus screws securing the charging port metal bracket.
  22. Google Pixel 6 Pro Rear Camera Replacement, Remove the charging port bracket: passo 22, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the charging port bracket: passo 22, imagem 2 %32
    • Use a pair of tweezers to remove the charging port bracket.
  23. Google Pixel 6 Pro Rear Camera Replacement, Unfasten the motherboard cover screws: passo 23, imagem 1 %32
    • Use a Torx T3 screwdriver to remove the five 5.1 mm-long 3IP Torx Plus screws securing the motherboard cover.
  24. Google Pixel 6 Pro Rear Camera Replacement, Remove the motherboard cover: passo 24, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the motherboard cover: passo 24, imagem 2 %32
    • Use a pair of tweezers or your fingers to carefully remove the motherboard cover.
  25. Google Pixel 6 Pro Rear Camera Replacement, Disconnect the battery cable: passo 25, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Disconnect the battery cable: passo 25, imagem 2 %32
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  26. Google Pixel 6 Pro Rear Camera Replacement, Unfasten the camera connector cover screws: passo 26, imagem 1 %32
    • Use a Torx T3 screwdriver to remove the two 5.1 mm-long 3IP Torx Plus screws securing the camera connector cover.
  27. Google Pixel 6 Pro Rear Camera Replacement, Remove the camera connector cover: passo 27, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the camera connector cover: passo 27, imagem 2 %32
    • Use a pair of tweezers to remove the camera connector cover.
  28. Google Pixel 6 Pro Rear Camera Replacement, Unfasten the camera assembly screw: passo 28, imagem 1 %32
    • Use a Torx T3 screwdriver to remove the single 3.3 mm-long 3IP Torx Plus screw securing the camera assembly.
  29. Google Pixel 6 Pro Rear Camera Replacement, Peel off the copper foil: passo 29, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Peel off the copper foil: passo 29, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement, Peel off the copper foil: passo 29, imagem 3 %32
    • Use a pair of tweezer to carefully peel the top half of the copper foil off the metal spacer and fold it back.
    • During reassembly, make sure the copper foil is not touching any components besides the rear camera assembly and components it was originally adhered to.
  30. Google Pixel 6 Pro Rear Camera Replacement, Disconnect the telephoto cable: passo 30, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Disconnect the telephoto cable: passo 30, imagem 2 %32
    • Use a spudger to disconnect the telephoto cable by prying the connector straight up from its socket.
  31. Google Pixel 6 Pro Rear Camera Replacement, Disconnect the camera cables: passo 31, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Disconnect the camera cables: passo 31, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement, Disconnect the camera cables: passo 31, imagem 3 %32
    • Use a spudger to disconnect the cables of the wide and ultrawide cameras by prying their connectors straight up from their sockets.
  32. Google Pixel 6 Pro Rear Camera Replacement, Remove the camera assembly: passo 32, imagem 1 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the camera assembly: passo 32, imagem 2 %32 Google Pixel 6 Pro Rear Camera Replacement, Remove the camera assembly: passo 32, imagem 3 %32
    • Use a pair of tweezers or your fingers to carefully lift the camera assembly out of its recess and remove it.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
    • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
    • Make sure the lens surface is smudge and dust free before you install the camera assembly.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
246.823 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.638 guias
8Comentários do guia
I just read that the camera has to be "paired" with the motherboard using software. It may work after a replacement and not calibrating, but will not render as-good of pictures. This came from a leaked repair manual from google. What do you say of this? Also, do you need to re-use the graphite and copper tape? https://repair.wiki/w/Google_Pixel_6_Pro...
Michael Carton - Responder
it's actually says that swapping a camera between production models can cause issues because they are somehow paired to the mainboard but the GEO replacement ones exist specifically to get around this problem but it would seem what they have done is made it so you can't get a broken pixel 6pro take its good working camera and fix another pixel 6 pro with it because of the pairing issue from factory it's a massive d!ck move forces you to buy new camera if you want to replace a logic bord or camera instead of say using a broken phone for parts
jacob jim -
UPDATE:
I just replaced the camera and it will not work. I get an error message, and asks to force close or continue anyway. If you continue, it just crashes. As to the gold foil, I was able to peel it off another broken camera and re-use it. Why is Ifixit selling these parts if you CANNOT use them unless you are Assurion or UbreakIfix(the only authorized centers) who have their own supply of official parts straight from Google????? This is very deceptive and disingenuous from Ifixit.
good guide fairly simple hardest part really is getting the screen off/on its in my phone and works like new
the box it came in look like it got elbow dropped from the top rope was so flat I thought it was a brown envelope at fist no joke but be f*%ked it somehow survived the classic Aus post treatment and is working fine
jacob jim - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 56
Últimos 30 dias: 297
Ao todo: 11,642
