Introdução
Follow this guide to replace a broken or cracked screen on a Pixel 4a.
The Pixel 4a’s unreinforced display panel is fragile. Pay special attention to the warnings in the opening procedure if you are reusing the screen.
Take note of the two seams on the edge of the phone:
Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
Before you begin, note the following areas on the screen:
Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
Place a suction cup as close to the right edge of the screen as possible.
Lift the suction cup with a strong steady force.
Insert the tip of an opening pick into the screen seam no more than 1 mm.
With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
Slide the pick along the right edge of the screen to cut the adhesive.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
Slide the opening pick around the bottom of the phone to cut the adhesive.
Leave the pick inserted along the bottom edge to prevent the adhesive from resealing.
Insert another opening pick into the bottom edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
Use the pick to slice through the left edge of the phone.
Leave the pick inserted along the left edge of the phone to prevent the adhesive from re-sealing.
Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
Use a pair of tweezers to carefully peel up the black tape covering the screen connector bracket.
Remove the screen.
Compare your replacement screen with the original. You may need to transfer additional components (such as speaker mesh) to the new part.
Scrape off remaining adhesive from the perimeter of the frame.
Follow this guide if you are using custom-cut adhesives.
If you are using double-sided tape such as Tesa tape, follow this guide.
4 outras pessoas concluíram este guia.
7 comentários
Where do you recommend that I purchase the Pixel4a screen replacement from? I found these two with Witrigs being cheaper, but not sure if either are reliable high quality screens.
