Introdução
This guide demonstrates how to do a hand sewn blanket stitch to apply a patch over a hole in a Patagonia Snap-T®. The blanket stitch is known for its durability and decorative appeal, and is commonly used to secure raw fabric edges or attach patches.
Hand sewn repairs are a fun and effective way to extend the life of gear at home. DIY repairs won't void the Patagonia warranty—they're actually encouraged!
Patagonia items can also be taken in to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
Related Tutorials
Related Articles
O que você precisa
Locate the hole or tear that requires patching.
If possible, stitch the tear closed before attaching the patch.
If the tear is too large to be stitched closed, see the last step in this guide for details on creating an underpatch.
Position the fabric patch over the hole and pin it in place, ensuring the hole is centered.
Thread the needle with a length of thread approximately 24 inches (~61 cm) long and tie a knot at one end of the thread. For more details see Needles and Thread.
Insert the needle up from the backside so it emerges just beside the edge of the patch without piercing through it.
Pull tight so the thread knot is flush against the back of the fabric.
Insert the needle into the patch diagonally, 1/4 inch (~6 mm) inward from the edge and 1/4 inch (~6 mm) forward in the direction of the stitch path.
Pull the needle and thread through to the back. Don't pull the thread tight, leaving a small loop.
Pierce the needle from the backside, coming up just beside the edge of the patch, 1/4 inch (~6 mm) down from the first edge stitch made in Step 4.
Pass the needle through the small loop created in the last step.
Pull the thread tight to secure it.
This completes the first blanket stitch!
To create the blanket stitch without flipping between the front and backside, complete the previous two steps in one motion:
Start with the thread emerging along the edge of the patch.
Insert the needle into the patch 1/4 inch (~6 mm) in from the edge and bring it out at the edge of the patch directly adjacent. The needle will be perpendicular to the patch edge.
Pull the needle and thread through, ensuring the needle passes through the loop formed by the stitch.
This video shows how to complete the blanket stitch in one movement by following the instructions in the previous step.
Once within 1/2 inch (~13 mm) of a patch corner, create a corner stitch:
Insert the needle into the patch at the corner, 1/4 inch (~6 mm) in from both edges.
Then bring the needle out at the corner edge, passing through the thread loop.
Then continue stitching down the next side of the patch.
After stitching around the entire patch and coming within 1/4 inch (~6 mm) of the starting stitch, create a final blanket stitch with the needle emerging at the initial stitch point from Step 4.
Pass the needle through the thread loop and pull the thread tight.
Insert the needle back down into fabric in the same spot, ensuring the loop is secured with the stitch. Pull the thread tight.
Make a secure knot on the backside of the fabric using one of the techniques from Knot Thread to the Fabric (2 Ways).
Trim any excess thread.
Ensure that the patch is securely attached and that the stitches hold firmly without any gaps or looseness.
UNDERPATCH: If the tear is too large to be stitched closed in Step 2 and there's concern the exposed tear will get caught while the garment is being worn, create an underpatch first. An underpatch is a smaller patch that is sewn over the hole on the backside before the main patch is sewn on the front.
