Ir para o conteúdo principal
Apple Watch Series 9 (45mm) Battery Replacement
O que você precisa
  1. Apple Watch Series 9 (45mm) Battery Replacement, Prepare your watch for disassembly: passo 1, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Prepare your watch for disassembly: passo 1, imagem 2 %32
    • Before starting this repair, remove your watch from the charger and let its battery drain completely—the watch should shut down from low battery. A charged lithium‑ion battery may catch fire if damaged.
    • Letting the battery drain completely also prevents accidentally turning your watch back on when gripping it during repair.
  2. Apple Watch Series 9 (45mm) Battery Replacement, Disassembly information: passo 2, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Disassembly information: passo 2, imagem 2 %32 Apple Watch Series 9 (45mm) Battery Replacement, Disassembly information: passo 2, imagem 3 %32
    • Throughout the rest of your repair:
    • Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
    • To remove a band, firmly press in the small, oval button on the underside of the watch and slide the band out of its groove.
    • Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
  3. Apple Watch Series 9 (45mm) Battery Replacement, Mark your opening picks: passo 3, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Mark your opening picks: passo 3, imagem 2 %32 Apple Watch Series 9 (45mm) Battery Replacement, Mark your opening picks: passo 3, imagem 3 %32
    • If inserted too far, an opening pick can damage your watch. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. Apple Watch Series 9 (45mm) Battery Replacement, Heat the screen: passo 4, imagem 1 %32
    • Strong adhesive secures the perimeter of the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the screen for two minutes to soften its adhesive.
    • Alternatively, you can use a hair dryer or heat gun—but be careful as extreme heat can damage the screen and/or battery.
  5. Apple Watch Series 9 (45mm) Battery Replacement, Insert an iFlex: passo 5, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Insert an iFlex: passo 5, imagem 2 %32 Apple Watch Series 9 (45mm) Battery Replacement, Insert an iFlex: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    iFlex Opening Tool
    $11.99
    • The gap between the screen and frame is extremely small. You'll need a thin tool such as an iFlex to create an initial gap.
    • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Consider wearing gloves to protect your hands.
    • Insert the iFlex at a downward angle between the bottom edge of the screen and frame.
  6. Apple Watch Series 9 (45mm) Battery Replacement, Pry up the screen: passo 6, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Pry up the screen: passo 6, imagem 2 %32
    • Prying up the screen may take multiple attempts. If you're having trouble, apply more heat and try again.
    • With one hand, push down firmly on the watch's frame to secure it in place.
    • With your free hand, hold the iFlex and push the edges up to make it more rigid.
    • The iFlex should be slightly "U" shaped.
    • Pry up the screen enough for the iFlex to lay flat on its own.
    • The iFlex doesn't need to be inserted far, as it can easily damage the screen cables near the bottom right corner of the watch.
    • Leave the iFlex inserted under the screen.
  7. Apple Watch Series 9 (45mm) Battery Replacement, Insert an opening pick: passo 7, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Insert an opening pick: passo 7, imagem 2 %32 Apple Watch Series 9 (45mm) Battery Replacement, Insert an opening pick: passo 7, imagem 3 %32
    • Do not insert your opening pick more than 3 mm under the screen when separating the adhesive, as you risk damaging your watches internals.
    • Keep the iFlex flat to maintain a gap between the screen and frame while inserting an opening pick.
    • Insert an opening pick between the screen and iFlex.
    • Remove the iFlex.
  8. Apple Watch Series 9 (45mm) Battery Replacement, Separate the bottom edge adhesive: passo 8, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Separate the bottom edge adhesive: passo 8, imagem 2 %32
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
  9. Apple Watch Series 9 (45mm) Battery Replacement, Separate the left edge adhesive: passo 9, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Separate the left edge adhesive: passo 9, imagem 2 %32
    • Slide the opening pick around the bottom left corner and up the left edge to separate the adhesive.
  10. Apple Watch Series 9 (45mm) Battery Replacement, Separate the top edge adhesive: passo 10, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Separate the top edge adhesive: passo 10, imagem 2 %32
    • Slide the opening pick around the top left corner and along the top edge to separate the adhesive.
  11. Apple Watch Series 9 (45mm) Battery Replacement, Separate the right edge adhesive: passo 11, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Separate the right edge adhesive: passo 11, imagem 2 %32
    • Slide the opening pick around the top right corner and stop at the top of the side button.
    • Don't slide your pick past the side button—you risk damage to the screen cables.
  12. Apple Watch Series 9 (45mm) Battery Replacement, Separate the remaining adhesive: passo 12, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Separate the remaining adhesive: passo 12, imagem 2 %32
    • Insert the long edge of an opening pick between the left edge of the screen and frame.
    • Twist the pick to lift the screen and separate any remaining adhesive.
  13. Apple Watch Series 9 (45mm) Battery Replacement, Swing open the screen: passo 13, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Swing open the screen: passo 13, imagem 2 %32 Apple Watch Series 9 (45mm) Battery Replacement, Swing open the screen: passo 13, imagem 3 %32
    • Pull the right edge of the screen over the digital crown.
    • If the screen feels stuck, go back around it with an opening pick to separate any adhesive.
    • Swing up the left edge of the screen so it's upright. The screen should be to the right of the digital crown.
    • During reassembly:
    • This is a good point to plug in your watch and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
    • Follow this guide to apply new screen adhesive and reseal your watch.
  14. Apple Watch Series 9 (45mm) Battery Replacement, Heat the battery adhesive: passo 14, imagem 1 %32
    • Heating the battery will soften the strong adhesive securing it, making the battery easier to remove.
    • Heat an iOpener and lay it on the battery for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer or heat gun—but be careful as extreme heat can damage the battery.
  15. Apple Watch Series 9 (45mm) Battery Replacement, Pry up the battery: passo 15, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Pry up the battery: passo 15, imagem 2 %32 Apple Watch Series 9 (45mm) Battery Replacement, Pry up the battery: passo 15, imagem 3 %32
    • Be careful not to puncture or bend the battery—it can leak dangerous chemicals and catch fire.
    • Insert an opening pick between the bottom edge of the battery and frame.
    • Pry up the battery with the opening pick until it starts to separate from the frame.
    • This requires time and constant pressure. If you're having trouble, apply more heat and try again.
    • Slide the pick farther under the battery and lift until all the adhesive is separated.
  16. Apple Watch Series 9 (45mm) Battery Replacement, Reposition the battery: passo 16, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Reposition the battery: passo 16, imagem 2 %32
    • Be careful not to strain or tear the battery cable during the rest of your repair.
    • Gently lift the battery out of its recess and set it next to your watch so you can access the battery cable.
  17. Apple Watch Series 9 (45mm) Battery Replacement, Remove the battery connector screw: passo 17, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Remove the battery connector screw: passo 17, imagem 2 %32
    • Use a tri‑point Y000 screwdriver to remove the 1.1 mm‑long screw securing the battery connector bracket.
  18. Apple Watch Series 9 (45mm) Battery Replacement, Remove the bracket: passo 18, imagem 1 %32
    • Use a pair of tweezers to remove the battery connector bracket.
  19. Apple Watch Series 9 (45mm) Battery Replacement, Disconnect the battery: passo 19, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Disconnect the battery: passo 19, imagem 2 %32
    • Insert the point of a spudger under the short end of the battery connector (opposite the cable) and pry it up.
  20. Apple Watch Series 9 (45mm) Battery Replacement, Remove the battery: passo 20, imagem 1 %32 Apple Watch Series 9 (45mm) Battery Replacement, Remove the battery: passo 20, imagem 2 %32
    Tesa 61395 Tape
    $2.99
    • Remove the battery.
    • To install a new battery:
    • Use a spudger and tweezers to remove all the old adhesive from the battery recess.
    • If your replacement battery doesn't have adhesive pre-installed, put strips of thin, double-sided tape on the logic board (not directly on the battery) where the old adhesive was. Do not remove any liners yet.
    • Reconnect the battery cable press connector to its socket on the motherboard.
    • Put the battery connector bracket into place and install its screw. Make sure the metal arm goes over the battery press connector.
    • Remove any liners from the battery adhesive or double-sided tape.
    • Firmly press the battery into place to secure it with the adhesive.
Conclusão
For optimal performance, calibrate your newly installed battery after completing your repair.
Uma outra pessoa concluiu este guia.
Spencer Day
Membro desde: 09/14/22
162.792 Reputação
Autoria de 1.043 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 24.166 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 59
Últimos 30 dias: 222
Ao todo: 3,572
