Ir para o conteúdo principal
Apple Watch Series 5 Battery Replacement
O que você precisa
  1. Apple Watch Series 5 Battery Replacement, Display Opening: passo 1, imagem 1 %32 Apple Watch Series 5 Battery Replacement, Display Opening: passo 1, imagem 2 %32
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  2. Apple Watch Series 5 Battery Replacement: passo 3, imagem 1 %32
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
  3. Apple Watch Series 5 Battery Replacement: passo 4, imagem 1 %32 Apple Watch Series 5 Battery Replacement: passo 4, imagem 2 %32 Apple Watch Series 5 Battery Replacement: passo 4, imagem 3 %32
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the force touch sensor.
  4. Apple Watch Series 5 Battery Replacement: passo 5, imagem 1 %32 Apple Watch Series 5 Battery Replacement: passo 5, imagem 2 %32
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  5. Apple Watch Series 5 Battery Replacement: passo 6, imagem 1 %32 Apple Watch Series 5 Battery Replacement: passo 6, imagem 2 %32 Apple Watch Series 5 Battery Replacement: passo 6, imagem 3 %32
    • It's likely that the force touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
  6. Apple Watch Series 5 Battery Replacement: passo 7, imagem 1 %32 Apple Watch Series 5 Battery Replacement: passo 7, imagem 2 %32
    • Avoid tensioning the display cables when folding the screen to the back.
    • Carefully lift the display open like a book.
  7. Apple Watch Series 5 Battery Replacement, Battery: passo 8, imagem 1 %32 Apple Watch Series 5 Battery Replacement, Battery: passo 8, imagem 2 %32
    • Lift the screen until there's enough space to access the battery.
    • Insert an opening pick between the battery and the Taptic Engine.
    • A regular opening pick works fine with the 44 mm version of the Apple Watch Series 5. However if you own the 40 mm version and don't have enough space you can customize your opening pick with scissors.
  8. Apple Watch Series 5 Battery Replacement, Pry up the Battery: passo 9, imagem 1 %32 Apple Watch Series 5 Battery Replacement, Pry up the Battery: passo 9, imagem 2 %32 Apple Watch Series 5 Battery Replacement, Pry up the Battery: passo 9, imagem 3 %32
    • Slide the opening pick along the edge of the battery to loosen the adhesive.
    • The battery adhesive is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
    • Avoid damaging the display cables, and especially the force touch cable, which covers the battery in one corner during the prying procedure.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  9. Apple Watch Series 5 Battery Replacement: passo 10, imagem 1 %32
    • Carefully lift the battery to a 75-degree angle.
    • Remove the 1.1 mm-long Y000 screw.
  10. Apple Watch Series 5 Battery Replacement, Remove The Metal Plate: passo 11, imagem 1 %32 Apple Watch Series 5 Battery Replacement, Remove The Metal Plate: passo 11, imagem 2 %32
    • Use a pair of tweezers to remove the metal plate covering the battery connector.
  11. Apple Watch Series 5 Battery Replacement, Disconnect the battery: passo 12, imagem 1 %32 Apple Watch Series 5 Battery Replacement, Disconnect the battery: passo 12, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
    • Follow the resealing guide to reseal your watch after reassembly.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
17 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
184.262 Reputação
Autoria de 680 guias
Equipe
iFixit Membro de iFixit
Community
Membros da 136
Autoria de 15.118 guias
7 comentários
Since WatchOS 7 removed 3D Touch functionality on all Force Touch enabled watches, will damaging or disconnecting the Force Touch gasket affect the functionality of the watch or will the software brick it?
AStupidMidge - Responder
Any tips for applying the adhesive strip without removing the screen? Is removing the screen recommended to seat it properly?
David Mifsud - Responder
Does the resealing adhesive strip go in between the screen and force touch gasket, or the force touch gasket and the case?
Hi David,
here is a general resealing guide that might help you. Depending on your force touch replacement part you‘ll need one two or no adhesive strips.
If your force touch was never removed you need to place new adhesive on top of it the adhere the screen. If your force touch has adhesive on the bottom side it is the same. Adhere the force touch into the watch frame and place adhesive on top of it to adhere the screen. If there is adhesive on the top of the force touch you need to place the adhesive strip beneath.
If your force touch didn‘t come with any adhesive preinstalled you need adhesive tape below to secure it to the watch frame and on top to secure the screen.
Dominik Schnabelrauch -
Hi @schnabel , thank you for you reply. I am in the middle of replacing the battery. I managed to save the force touch sensor from getting damaged, but I need to be re-adhere it to both surfaces. Can I use 2 of these adhesive strips on either side?
Apple Watch (44 mm Series 4/5) Adhesive Strip
David Mifsud -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 179
Últimos 7 dias: 1,054
Últimos 30 dias: 3,175
Duração total: 47,259
