Ir para o conteúdo principal
Adjusting Singer Brilliance 6180
O que você precisa
  1. Adjusting Singer Brilliance 6180, Needle Position: passo 1, imagem 1 %32 Adjusting Singer Brilliance 6180, Needle Position: passo 1, imagem 2 %32
    • If the position of the needle is not correct, some errors will occur, which can make the user very annoyed.
    • The exact position of the needle is extremely important on a sewing machine. The looper needs to pass the needle in a very small distance to pull out the thread, if this does not work exactly, there will be many errors such as loops, broken needles, broken threads and banging noises,
    • The two photos show the correct position of the needle in the needle plate. It must be exactly in the middle of the hole plate on the side and in the sewing direction. (If the needle plate is not shifted.)
  2. Adjusting Singer Brilliance 6180, Remove left cover: passo 2, imagem 1 %32 Adjusting Singer Brilliance 6180, Remove left cover: passo 2, imagem 2 %32 Adjusting Singer Brilliance 6180, Remove left cover: passo 2, imagem 3 %32
    • To access the adjustment plate and screw, you need to remove the left cover.
    • Loosen the Phillips screw # 2 on the back a little, it must not be removed.
    • Remove the Phillips # 2 screw on the left side.
    • Pull the cover towards the left to remove it.
  3. Adjusting Singer Brilliance 6180, Method 1: Adjusting the needle carrier: passo 3, imagem 1 %32 Adjusting Singer Brilliance 6180, Method 1: Adjusting the needle carrier: passo 3, imagem 2 %32 Adjusting Singer Brilliance 6180, Method 1: Adjusting the needle carrier: passo 3, imagem 3 %32
    • The needle carrier is attached at the top with a 2 mm Allen screw. Loosen the screw to slightly move the cantilever. It's pretty tight the first time, be careful.
    • To move the needle carrier, tap very lightly, e.g. with the handle of a screwdriver, on the axis of the needle carrier.
    • If you tap the front of the axle, the needle moves towards you, the distance between the needle and the looper increases.
    • If you tap on the back of the axle, the needle will move away from you and the distance between the needle and the looper will decrease.
    • Lower the needle all the way down. You should just be able to slip a piece of paper between the needle and the looper tip. (Picture 3). The needle must be able to slide easily to the left and right when zigzagging.
    • Tighten the Allen screw again.
    • Check that the machine sews cleanly again, especially with zigzag stitches. If all is well, check the lateral displacement and go straight to step 8.
  4. Adjusting Singer Brilliance 6180, Method 2: Adjusting the Needle Carrier: passo 4, imagem 1 %32 Adjusting Singer Brilliance 6180, Method 2: Adjusting the Needle Carrier: passo 4, imagem 2 %32 Adjusting Singer Brilliance 6180, Method 2: Adjusting the Needle Carrier: passo 4, imagem 3 %32
    • The cantilever slides past a plate. You can adjust the position of the needle by slightly bending this plate.
    • The setting plate is marked yellow in the first picture. It has to be taken out and bent very slightly.
    • First unscrew the rod for the thread run with a flat screwdriver.
    • The adjustment plate is now accessible.
    Hat super geklappt. Noch eine Frage: die Justierschraube der Einstellplatt muss bei mir etwas lockerer sitzen, da die Maschine sonst keine Programme wählen kann und nur einen Gradstich macht. Soll das so sein? Lg Carmen
    Carmen Görmar - Responder
    Weiß nicht so recht. Ist es die Schraube, welches das Plättchen festhält? (im nächsten Schritt rot markiert?) Die war bei mir total fest. Das Plättchen muss halt leicht hin und her gleiten können, die Gleitflächen sollten gefettet werden. Ich würde es beobachten, wenn die Maschine sauber läuft ist ja alles gut. Die Schraube aus Schritt 7 sitzt in der Tat nicht so fest, ursprünglich ist sie mit einer Art Siegelwachs gesichert.
    Glückwunsch zur Reparatur!
    VauWeh -
  5. Adjusting Singer Brilliance 6180: passo 5, imagem 1 %32 Adjusting Singer Brilliance 6180: passo 5, imagem 2 %32
    • The adjustment plate is fixed with a Phillips screw. Gently twist it out.
    • Use a well-fitting Phillips screwdriver and press firmly as you unscrew. The screw is quite tight and the screw head must not be damaged under any circumstances.
    Top Anleitung. Danke! Nadel ist jetzt in der vertikalen Ausrichtung wieder genau mittig. Aber irgendwas muss ich falsch gemacht haben: links rechts lässt sie sich nun gar nicht mehr bewegen. Also alle Stivumuster außer Nummer 1 gehen nicht mehr weil das Ding jetzt sehr starr ist. Habe ich zu viel gebogen? Aber wie gesagt: vertikal ist sie genau mittig.
    schurzgasschweisser79 - Responder
    Ja, das Plättchen muss sich bewegen können, kann man mit der Hand probieren. Löse mal die Schraube ein wenig. Eventuell muss das Plättchen doch wieder gaaaanz wenig zurück gebogen werden. Ein bisschen Fett hilft auch.
    Ich bin inzwischen mit der 6180 nicht mehr zufrieden. Das ist wirklich eine zickige Maschine. Habe noch eine uralte Pfaff. Die kann zwar nicht viel, aber das zuverlässig seit Jahrzehnten.
    VauWeh -
    Hm, ja. Ich hatte auch befürchtet, dass es vielleicht zu arg gebogen wurde und dadurch der Anpressdruck zu hoch ist: Die Schraube selbst ist nämlich nur locker angezogen (lockerer als zuvor würde ich sagen). Andererseits ist die Nadel genau in der Mitte, das heisst eigentlich sollte das ja passen. Hm. Ich denke ich lasse es für’s Erste so. Brauche eh keine besonderen Stichmuster
  6. Adjusting Singer Brilliance 6180: passo 6, imagem 1 %32
    • Push the needle carrier a little forward from behind to relieve the adjustment plate, then simply lift it up using a pair of tweezers.
  7. Adjusting Singer Brilliance 6180: passo 7, imagem 1 %32 Adjusting Singer Brilliance 6180: passo 7, imagem 2 %32
    • This is what the setting plate looks like. It regulates the position in sewing direction.
    • To adjust, you have to bend the lower part of the plate slightly outwards. Use two pliers to do this.
    • The bending is really minimal. You may have to remove the plate again if the needle isn't yet in the right position.
    • Reinstall the plate and check the position of the needle in sewing direction.
    • When you fasten the screw, the plate - and with it the needle - must remain movable to the side, otherwise there will be no zigzag stitch, etc. Grease the sliding surfaces. You may have to take it out again and bend it back very slightly.
    Danke für die Anleitung. Bis hierher bin ich ohne Probleme gekommen, allerdings schaffe ich es nicht die Platte so einzubauen das sie mit angezogener Schraube sich nach rechts und links bewegt . (Kein ZickZack mehr möglich?) Auch mit Fett leider nicht. In welche Richtung muss ich denn genau biegen? Wenn das Plättchen so wie bei Schritt 6 vor mir liegt….das gelb eingerahmte Eckchen nach rechts oder nach hinten? Ich verzweifel langsam mit der Maschine ?
    Anja - Responder
    Wenn du die Schraube anziehst, wird das Plättchen gegen die Gleitkante gepresst. Den Druck musst du wegnehmen. Also den gelb markierten Teil ganz wenig zu dir biegen. Ich habe auch schon dran gedacht, ein Stück Papier vor das Plättchen zu legen, vielleicht ginge das auch? Tja, es ist halt keine W6, Bernina, Janome…. Ich denke langsam auch an eine Neue.
    VauWeh -
    Danke für die schnelle Hilfe. Das mit dem Papier dahinter hab ich gestern probiert :-) ging leider nicht. Fett leider auch nicht :-( Die Maschine ist meiner Freundin und ich wollte ihr ein gefallen tun. Ich habe schon mehrere zum Laufen gebracht aber diese bringt mich an den Rand der Verzweiflung. Ich habe zwei alte pfaff. Die eine ist über 33 Jahre alt. Ist schon ne andere Hausnummer. Und längst nicht so zickig wie diese hier. Ich habe meiner Freundin zu einer neuen geraten, da ich vermute, das sie auf Dauer mir dieser nicht glücklich wird. Aber bis sie eine gescheite zusammen gespart hat wäre es schön, diese solange zum Laufen zu bringen (zur Zeit näht sie mit meiner Ersatz pfaff). Ich wollte mal schauen ob ich das plättchen als Ersatzteile bekomme da ich es vermutlich so verbogen habe das wir mit nem neuen eher Chancen haben. Weißt du zufällig wie sich das nennt?
    Anja -
    Nee, leider nicht. Bei dem Neupreis gibt es sicher wenig Unterstützung durch Werkstätten und Ersatzteile. Wenn sie läuft ist es schon ein Vergnügen, aber wehe, wenn sie streikt.
    VauWeh -
    Hallo ich habe die Einstellung vorgenommen und es hat alles geklappt. Neues Problem die Schraube löst sich nun immer wieder nach einiger Zeit. Kann man sie irgendwie oder mit irgendwas fixieren?
    Viele Grüße
    Sabine
    Sabine - Responder
    Eine Schraubensicherung wie z.B. Loctite blau sollte funktionieren. Härtet nach 24 Stunden aus, kann bei Bedarf aber auch wieder gelöst werden.
    VauWeh -
  8. Adjusting Singer Brilliance 6180, Adjust lateral shift: passo 8, imagem 1 %32 Adjusting Singer Brilliance 6180, Adjust lateral shift: passo 8, imagem 2 %32
    • The lateral position of the needle is easier to adjust. A black banjo bolt is used for this purpose. This position is set at the factory and does not normally need to be readjusted.
    • The hollow screw is secured from the factory with red color. You may have to remove it. To get to the screw better, you can unhook the transverse return spring.
    • Adjust the screw using a 1.4 mm Allen key. Observe how the lateral position of the needle changes.
    Hatte auch das Problem, dass nach dem Verbiegen des Plättchens nur noch der Geradstich möglich war. Das Plättchen war nach dem Biegen verzogen. Nach dem Auflegen auf eine flache Metallplatte und leichten Schlägen mit dem Hammer war das Plättchen wieder gerade und nach dem Einbau näht die Maschine wieder wie sie soll. Danke noch mal für die Anleitung.
    Wilhelm Herwig - Responder
  9. Adjusting Singer Brilliance 6180, Tip: passo 9, imagem 1 %32
    • One last hint: sewing starts better if you lower the needle using the handwheel into the throat plate after each switch-on; the motors adjust themselves with a brief click. Lift the needle up again and you're good to go - until the next time you turn it off.
    The sewing on one side is brilliant the other sewing is rubbish what can we do about it
    Alison Stewart - Responder
    On one side it's doing restrictions good on the other side it's not stitching
    Inspect and clean the bobbin. Is the tension of the thread ok? Replace the needle?
    VauWeh -
Conclusão
11 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
VauWeh
Membro desde: 10/19/15
250.941 Reputação
Autoria de 283 guias
Equipe
Repair is War on Entropy Membro de Repair is War on Entropy
Community
29 Membros
Autoria de 1.759 guias
16 comentários
Hallo Anleitung ist super. Leider näht meine Maschine seither nur noch gerade Stiche. Egal was ich einstelle….was ist schief gelaufen? Kann jmd helfen?
Sabine - Responder
Ja. Wie in den anderen Kommentaren auch schon geschrieben: das Plättchen muss seitlich verschiebbar bleiben, damit die Nadel hin und her wandern kann . Probiere es mit viel Gefühl ganz wenig zurück zu biegen. Man merkt, wie das Plättchen festgeht, wenn man die Schraube anzieht. Das darf halt nicht sein. weiße Hebel muss die Nadel verschieben können. Die Einstellung ist wirklich knifflig, es ist eine zickige Maschine…
VauWeh -
Tausend Dank für die Anleitung!!!
Ich war schon so verzweifelt und wollte mir eine neue Nähmaschine kaufen. (Hatte meine damals bei Lidl gekauft. Garantie und Gewährleistung ist längst abgelaufen und Einschicken erschien mir zu umständlich.)
Und dann das hier…
Sie läuft wieder absolut mittig, Zick-Zack ist auch kein Problem, einfach herrlich!
Viele liebe Grüße
Mare lei - Responder
Freut mich sehr, wieder ein sensibles Maschinchen gerettet. Ich habe den Verdacht, dass das passiert, wenn man während des Transports am Stoff zieht und nicht nur die Nadel verbogen wird.
VauWeh -
Guten Tag Ich habe gerade die gleiche Maschine und der Faden kommt nicht mehr hoch . der Greifer Zeitpunkt ist um 9mm nach links verschoben .Bei Bernina, Pfaff, kann man den Greifer mit einer Schraube ,hinter der Maschine lösen und so um ein Zahnrad verstellen.
Bei der Brillianz habe ich nach der Gehäuseöffnung gesehen das am Boden das weisse runde abdeckblättchen zum Greifer einsteller führt.
Mit einem 7mm SWISS-Gryp Nuss -Schraubendreher kann man diese lösen und den Greifer auf die richtige Position stellen ,danach diese Schraube wieder genug anziehen
Ich habe auch den Fehler gemacht und das ganzr Gehäuse geöffnet Gruss Paul Lehmann
paul lehmann - Responder
das weisse runde abdeckblättchen ..?
wo ist das denn ???
Rudi Giesen -
Hallo Paul, dank dir habe ich jetzt das Plättchen gefunden und gelöst. Bekomme darn aber keine Schraube zu packen...muss wohl doch das Gehäuse abnehmen.... Gruß Sabine
sabine.miermann -
Thanks for the detail guide. However, it's a NOT how to centered the needle. According to the Singer Service manual: "Loosen screw a fixing shaft linked with support bracket", "Slide needle bar support in either direction", then centered the needle. I followed this guide and my zigzag function didn't work.
Lisa ward - Responder
Meine Singer Brillance ist auf einmal so laut. Hört sich an wie ein quitschender Keilriemen. Kann mir bitte jemand einen Tipp geben.
veronikastrauss - Responder
Hey:)
Also bei mir läuft es leider nicht so glimpflich. Ich habe die Platte wieder zurückgebogen aber dennoch lässt sich die Nadel nicht zur Seite verstellen. Damit sich die Nadel seitlich bewegt muss ich die Schraube so sehr lockern dass das Plättchen fast rausfällt… außerdem ist die Nadel nach ganz links ausgerichtet statt mittig. Leider kann ich jetzt gar nichts mehr einstellen:/
Würde mich auf eine Antwort freuen, da ich eigentlich an einem Weihnachtsgeschenk arbeite.
Liebe Grüße
Maricel Bruszies - Responder
Achje. Zickiges Gerät. Die seitliche Einstellung geht eigentlich ziemlich gut mit einem Inbusschlüssel an der schwarzen Hohlschraube. Ansonsten kann ich nur sagen: nochmals probieren. Also Plättchen ausbauen und ganz leicht, wirklich sehr leicht, zurück biegen. Weiter oben hat jemand beschrieben, dass er das Plättchen auf eine Oberfläche gelegt und darauf geklopft hat, vielleicht ein Holz dazwischen legen. Gutes Gelingen, es funktioniert oft - aber leider nicht immer.
VauWeh -
Hat bei mir super funktioniert. In anderen Foren hieß es nur, dass das etwas für den Fachmann oder den Elektroschrott sei.
Vielen Dank!
Burkhard Schäfer - Responder
My sewing machine just revs. There is something stopping the needle from going up and down. When it did spring into action the thread was bunched under the fabric. It is stuck at present. Any advice?
nikipower - Responder
Meine Maschine näht mit der Nadelstellung in der Mitte und rechts ganz normal. Stelle ich die Nadel aber nach links, klappt entweder schon der erste Stich nicht oder sie lässt ständig Stiche aus. Woran kann das denn liegen? Und was kann ich tun? Hat da jemand eine Idee? Kann ich da auch was tun, justieren wie oben beschrieben?
Andrea Beese - Responder
Puhh, herzlichen Dank, ich hatte meine Maschine von Lidl entnervt nun 2-3 Jahre in der Ecke stehen, aber möchte und muss wirklich gerne nähen. Wollte mir schon eine Neue kaufen, lerne langsam die Feinheiten und werde es mal ausprobieren, aber es macht mir auch Angst. Werde zunächst noch an den offensichtlichen Schrauben und Einstellungen arbeiten. Sie ist kaum benutzt, da die Fadenspannung immer wieder versagte. Ich werde auch mal das Garn wechseln, es reisst ständig.
Johanne Maria Liesegang - Responder
Daaanke! Es hat mir sehr geholfen und ich fühle mich nun wie eine Handwerkermeisterin :D
Janina Meyer - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 53
Últimos 30 dias: 279
Ao todo: 22,882
