Ir para o conteúdo principal
8BitDo Ultimate Wireless Joystick Module Replacement
O que você precisa
  1. 8BitDo Ultimate Wireless Joystick Module Replacement, Case: passo 1, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement, Case: passo 1, imagem 2 %32
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Pergunte ao FixBot
    Comentar
  2. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 2, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 2, imagem 2 %32
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Pergunte ao FixBot
    Comentar
  3. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 3, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 3, imagem 2 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 3, imagem 3 %32
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Pergunte ao FixBot
    Comentar
  4. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 4, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 4, imagem 2 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 4, imagem 3 %32
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. 8BitDo Ultimate Wireless Joystick Module Replacement, Joystick's Module: passo 5, imagem 1 %32
    • Grip each analog stick cap firmly and pull straight up to remove them.
    Pergunte ao FixBot
    Comentar
  6. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 6, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 6, imagem 2 %32
    • Remove the three 5 mm Phillips #00 screws securing the midframe to the back shell, then lift it straight out.
    Pergunte ao FixBot
    Comentar
  7. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 7, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 7, imagem 2 %32
    • Turn to the backside of the circuit board for clear access to the solder joints.
    • Desolder all of the outlined solder joints.
    • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Garcia
Membro desde: 04/03/26
473 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 52
Ao todo: 169
