Circulation pump ohm readings
wdf320padw0 dishwasher does not cycle after water fill. Pulled the circulation pump and 200 setting shows OL. But at 200k shows 89-96 ohms. Bought 2 new pumps and the same readings occur.
Esta é uma boa pergunta?
Hi @abelsaiz
Looking at the wash/rinse strip circuit on p.4 of the tech sheet for the dishwasher, the wash motor should be 5-15 Ohms.
If you're measuring the wash motor directly on the motor terminals 1 & 3 with the harness wiring disconnected have you checked that you've got the correct wash motor?
According to Item #4 on p.13 of the parts list the wash motor part number is W10529161 which according to most suppliers has been superseded by W11133712 (example only)
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 38
Ao todo: 95
